06-26-2018, 11:48 | #1 (permalink) |
Freak Poster Join Date: Mar 2015 Location: CDA
Member: 2359179 Status: Offline Thanks Meter: 34 | how to unlock m9 Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_himaulatt (bootloader) version: 1.0 (bootloader) serialno: FA53VYJ17649 (bootloader) current-slot: (bootloader) imei: xxxxxxxxxxxx (bootloader) version-main: 4.19.1530.1 (bootloader) boot-mode: download (bootloader) version-baseband: 01.01_U114401021_119.01.61125A_F (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 0PJA11000 (bootloader) cid: VIDEO001 all: Execution time is 10(ms) Reading CID information ... (bootloader) cid: VIDEO001 OKAY Execution time is 69(ms) Reading MEID information ... (bootloader) meid: OKAY Execution time is 6(ms) Reading IMEI1 information ... (bootloader) imei: xxxxxxxxxxxxxxxxxx OKAY Execution time is 7(ms) Reading IMEI2 information ... (bootloader) imei2: OKAY thanks |
06-26-2018, 19:48 | #3 (permalink) |
Freak Poster Join Date: Oct 2017 Location: Pakistan/Canada/UK
Member: 2769072 Status: Offline Thanks Meter: 126 | attach clip to pc go special unlock tab select model and copy file then attach clip to phone and click on FTM after few sec phone restart and unlock done |
06-26-2018, 20:05 | #4 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | If any problem than make s-off first in direct tab than follow unlock instructions in special unlock tab Sent from my iPhone using Tapatalk |
06-27-2018, 03:49 | #5 (permalink) | |
Member: 2359179 Status: Offline Thanks Meter: 34 | Quote:
Thanks. | |
06-27-2018, 13:39 | #7 (permalink) |
Member: 2359179 Status: Offline Thanks Meter: 34 | i try everything change the computer n reader but as i connect the clip i get this error u need to format the disk in drive e: before you can use then i try to repair with Win32DiskImager using this file image2015 or this file image2017s i am getting this error an error occurred when attempting to write data to handle error 23:data error (cylic redundancy check) and sometime this an error occurred when attempting to write data to handke. error121:the timeout period has expired any help and where is the supporter? |
06-27-2018, 18:19 | #8 (permalink) |
Member: 220603 Status: Offline Thanks Meter: 1,164 | Flex not connected properly or damaged Sent from my iPhone using Tapatalk |
The Following User Says Thank You to deepakgarg For This Useful Post: |
