09-11-2017, 16:55 | #1 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | HTC 10 / U11 SD NOT MOUNTED solution HERE please If you are getting "SD NOT MOUNTED" on HTC 10 or U11, please follow these simple instructions: 1. Run XTC 2 Tool & connect clip to PC using microSD reader (as usual). 2. Open "Special unlock / IMEI" tab, leave "HTC 10 / HTC 10 KDDI" option selected. 3. Press "Copy files" 4. You should see "Please disconnect your clip and connect again". After this you should be able to use your clip on HTC 10 and U11. |
The Following 11 Users Say Thank You to xtc2clip For This Useful Post: |
09-12-2017, 11:44 | #4 (permalink) |
No Life Poster Join Date: Dec 2008 Location: TURKEY Age: 46
Member: 917368 Status: Offline Sonork: 1615575 Thanks Meter: 147 | 1. Checking phone connectivity... Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage. Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writesecureflag 0 ... (bootloader) HTC KEY CARD VERSION: 7 FAILPERMISSION DENY (NOT_FIND_SMART_IO) FAILED (remote: PERMISSION DENY (NOT_FIND_SMART_IO)) Execution time is 7(ms) Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage. Operation completed! Releasing adapter. Request completed |
03-22-2018, 19:37 | #10 (permalink) |
Junior Member Join Date: Sep 2017
Member: 2755105 Status: Offline Thanks Meter: 0 | buenas tardes tengo un conflito al intentar hacer el s-off de un htc U play Starting Ultra procedure Checking server connection... Communicating with the XTC 2 Clip ... Connecting to the server... Preparing enviroment... Communicating with phone... Starting operation Phone is in S-ON state Sorry, an error has occured, please report this code to support: ERROR:-1 |
03-23-2018, 08:54 | #11 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
04-11-2018, 11:25 | #13 (permalink) |
Member: 220603 Status: Offline Thanks Meter: 1,164 | |
The Following User Says Thank You to deepakgarg For This Useful Post: |
