01-18-2018, 15:07 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Algeria Age: 47
Member: 78657 Status: Offline Thanks Meter: 71 | HTC 530 restart !!! the customer come with hte phone in restart problem . i flash it but same result. how to solve it ? thank you. Code: Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_a16wl (bootloader) version: 1.0 (bootloader) imei: 990007221145201 (bootloader) version-main: 1.14.603.3 (bootloader) boot-mode: download (bootloader) version-baseband: 2.10.C13351@61013 (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 2PST30000 (bootloader) cid: 11111111 all: Execution time is 10(ms) Reading CID information ... (bootloader) cid: 11111111 OKAY Execution time is 8(ms) Reading MEID information ... (bootloader) meid: 99000722114520 OKAY Execution time is 8(ms) Reading IMEI1 information ... (bootloader) imei: 990007221145201 OKAY Execution time is 12(ms) Reading IMEI2 information ... (bootloader) imei2: OKAY Execution time is 12(ms) Reading secure flag information ... (bootloader) Device security level S-OFF OKAY Execution time is 11(ms) Reading serial number information ... (bootloader) Device Serial No. is HT67T0005900 OKAY Execution time is 8(ms) Read information completed. Code: Starting flash process... target rom version: 1.14.603.3 found large-zip header, file count: 19 processing file 1/19... sending 'zip' (61269 KB)... OKAY [ 6.470s] writing 'zip'... (bootloader) HOSD CL#867763 (bootloader) GPT (gpt_main_16g.img) is up-to-dated. [17408] (bootloader) Perform pre-update (bootloader) WARN Skip partition_info due to unmatched partition name (bootloader) WARN Skip backup_android-info.txt due to unmatched partitio (bootloader) n name (bootloader) get 17 images from zip(zip_type=3) (bootloader) start@17 (bootloader) apppreload.img@BYPASS (bootloader) aboot_signed.img@100% (bootloader) cota.img@BYPASS (bootloader) sbl1-8909-1.img@100% (bootloader) hosd_signed.img@100% (bootloader) rpm-8909-1.img@100% (bootloader) boot_signed.img@BYPASS (bootloader) recovery_signed.img@BYPASS (bootloader) wcnss.img@BYPASS (bootloader) rfg_1.img@BYPASS (bootloader) tz-8909-1.img@100% (bootloader) cmnlib32.img@100% (bootloader) keymaster.img@100% (bootloader) pg2fs_ship_signkey.img@BYPASS (bootloader) tp_HMX852XE.img@BYPASS (bootloader) splash1.nb0@BYPASS (bootloader) radio.img@BYPASS FAILED (remote: 90 hboot pre-update! please flush image again immediately ) finished. total time: 9.537s preupdate done, rebooting... Phone DISconnected Phone connected [HT67T0005900] *** Fastboot mode resending command... sending 'zip' (61269 KB)... OKAY [ 6.523s] writing 'zip'... (bootloader) HOSD CL#867763 (bootloader) GPT (gpt_main_16g.img) is up-to-dated. [17408] (bootloader) WARN Skip partition_info due to unmatched partition name (bootloader) WARN Skip backup_android-info.txt due to unmatched partitio (bootloader) n name (bootloader) get 17 images from zip(zip_type=3) (bootloader) start@17 (bootloader) apppreload.img@100% (bootloader) aboot_signed.img@100% (bootloader) cota.img@100% (bootloader) sbl1-8909-1.img@100% (bootloader) hosd_signed.img@100% (bootloader) rpm-8909-1.img@100% (bootloader) boot_signed.img@100% (bootloader) recovery_signed.img@100% (bootloader) wcnss.img@100% (bootloader) rfg_1.img@100% (bootloader) tz-8909-1.img@100% (bootloader) cmnlib32.img@100% (bootloader) keymaster.img@100% (bootloader) pg2fs_ship_signkey.img@100% (bootloader) splash1.nb0@100% (bootloader) tp_HMX852XE.img@BYPASS (bootloader) radio.img@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 8.641s] finished. total time: 15.165s processing file 2/19... sending 'zip' (46909 KB)... OKAY [ 5.217s] writing 'zip'... (bootloader) HOSD CL#867763 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_00@47% (bootloader) system.img_00@94% (bootloader) system.img_00@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 7.276s] finished. total time: 12.494s processing file 3/19... sending 'zip' (84059 KB)... OKAY [ 8.569s] writing 'zip'... (bootloader) HOSD CL#867763 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_01@44% (bootloader) system.img_01@88% (bootloader) system.img_01@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 7.860s] finished. total time: 16.430s processing file 4/19... sending 'zip' (75045 KB)... OKAY [ 7.816s] writing 'zip'... (bootloader) HOSD CL#867763 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_02@47% (bootloader) system.img_02@95% (bootloader) system.img_02@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 7.685s] finished. total time: 15.504s processing file 5/19... sending 'zip' (82564 KB)... OKAY [ 8.437s] writing 'zip'... (bootloader) HOSD CL#867763 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_03@46% (bootloader) system.img_03@92% (bootloader) system.img_03@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 8.109s] finished. total time: 16.548s processing file 6/19... sending 'zip' (85341 KB)... OKAY [ 8.696s] writing 'zip'... (bootloader) HOSD CL#867763 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_04@47% (bootloader) system.img_04@94% (bootloader) system.img_04@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 7.699s] finished. total time: 16.396s processing file 7/19... sending 'zip' (86726 KB)... OKAY [ 8.839s] writing 'zip'... (bootloader) HOSD CL#867763 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_05@44% (bootloader) system.img_05@88% (bootloader) system.img_05@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 7.920s] finished. total time: 16.760s processing file 8/19... sending 'zip' (73145 KB)... OKAY [ 7.541s] writing 'zip'... (bootloader) HOSD CL#867763 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_06@44% (bootloader) system.img_06@88% (bootloader) system.img_06@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 8.038s] finished. total time: 15.581s processing file 9/19... sending 'zip' (72433 KB)... OKAY [ 7.473s] writing 'zip'... (bootloader) HOSD CL#867763 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_07@43% (bootloader) system.img_07@87% (bootloader) system.img_07@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 7.969s] finished. total time: 15.443s processing file 10/19... sending 'zip' (90638 KB)... OKAY [ 8.986s] writing 'zip'... (bootloader) HOSD CL#867763 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_08@43% (bootloader) system.img_08@87% (bootloader) system.img_08@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 7.901s] finished. total time: 16.887s processing file 11/19... sending 'zip' (78472 KB)... OKAY [ 7.932s] writing 'zip'... (bootloader) HOSD CL#867763 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_09@43% (bootloader) system.img_09@87% (bootloader) system.img_09@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 7.900s] finished. total time: 15.833s processing file 12/19... sending 'zip' (86064 KB)... OKAY [ 8.663s] writing 'zip'... (bootloader) HOSD CL#867763 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_10@43% (bootloader) system.img_10@87% (bootloader) system.img_10@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 7.768s] finished. total time: 16.432s processing file 13/19... sending 'zip' (78432 KB)... OKAY [ 8.027s] writing 'zip'... (bootloader) HOSD CL#867763 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_11@44% (bootloader) system.img_11@88% (bootloader) system.img_11@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 7.873s] finished. total time: 15.901s processing file 14/19... sending 'zip' (79489 KB)... OKAY [ 8.232s] writing 'zip'... (bootloader) HOSD CL#867763 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_12@45% (bootloader) system.img_12@90% (bootloader) system.img_12@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 7.668s] finished. total time: 15.901s processing file 15/19... sending 'zip' (108985 KB)... OKAY [ 10.684s] writing 'zip'... (bootloader) HOSD CL#867763 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_13@43% (bootloader) system.img_13@87% (bootloader) system.img_13@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 7.816s] finished. total time: 18.500s processing file 16/19... sending 'zip' (87439 KB)... OKAY [ 8.788s] writing 'zip'... (bootloader) HOSD CL#867763 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_14@43% (bootloader) system.img_14@87% (bootloader) system.img_14@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 7.879s] finished. total time: 16.667s processing file 17/19... sending 'zip' (74081 KB)... OKAY [ 7.726s] writing 'zip'... (bootloader) HOSD CL#867763 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_15@43% (bootloader) system.img_15@87% (bootloader) system.img_15@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 7.910s] finished. total time: 15.638s processing file 18/19... sending 'zip' (60923 KB)... OKAY [ 6.511s] writing 'zip'... (bootloader) HOSD CL#867763 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_16@65% (bootloader) system.img_16@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 6.671s] finished. total time: 13.183s processing file 19/19... sending 'zip' (8909 KB)... OKAY [ 1.739s] writing 'zip'... (bootloader) HOSD CL#867763 (bootloader) get 2 images from zip(zip_type=3) (bootloader) start@2 (bootloader) dzdata_16g.img@100% (bootloader) boot_signed.img@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 3.639s] finished. total time: 5.378s rompack updated HBoot pre-update sequence Flash process completed. Restarting phone... rebooting... Execution time is 5(ms) Phone DISconnected |
