Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > xtc2cliP
Old 10-26-2015, 16:19   #1 (permalink)
$ktelecom's Avatar
Member: 484060
Sonork: 100.1596821
Thanks Meter: 399
HTC 816D All Test Report 1 Short Done By xtc2Clip
All Test 1 Short Done By xtc2Clip
Reading Info
Reading information...
Using Fastboot mode...
Reading common information
(bootloader) version: 0.5
(bootloader) version-bootloader: 3.19.0.0000
(bootloader) version-baseband: 1.31.50.1103
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main: 1.61.720.1
(bootloader) version-misc: PVT SHIP S-ON
(bootloader) serialno: FA48LMZ01266
(bootloader) imei: 3527950627xxxxx
(bootloader) imei2: 3527950627xxxxx
(bootloader) meid: A1000037D9AC70
(bootloader) product: a5_dwg
(bootloader) platform: hTCBmsm8226
(bootloader) modelid: 0P9C51000
(bootloader) cidnum: HTC__038
(bootloader) battery-status: good
(bootloader) battery-voltage: 0mV
(bootloader) partition-layout: Generic
(bootloader) security: on
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
(bootloader) commitno-bootloader: be7179e5
(bootloader) hbootpreupdate: 11
(bootloader) gencheckpt: 0
Execution time is 15(ms)
all: Done!
Reading secure flag information
... (bootloader) secure_flag: 3
OKAY
Reading CID information
... (bootloader) cid: HTC__038
Execution time is 0(ms)
OKAY
Reading MEID information
... (bootloader) meid: A1000037Dxxxxx
OKAY
Read information completed.
S-OFF
Sending oem writesecureflag 0
... (bootloader) SecuritySDInit: counter = 3
(bootloader)  a5dwg_init_sd, SD card already power on
(bootloader)  a5dwg_init_sd, SD card io already power on
(bootloader) sdhci_open: id=0
(bootloader)  Initializing MMC host data structure and clock!
(bootloader) mmc slot#2 clock enabled
(bootloader) clock_config_mmc: slot 2, freq 192000000
(bootloader) GPLL0 is enabled
(bootloader) clock_update_cfg_sd is done
(bootloader) sd clock set done
(bootloader) sdhci_set_bus_width: bus width 0
(bootloader) sdhci_clk_supply: freq 400000
(bootloader) Error: Command never completed
(bootloader) Error: Command timeout error
(bootloader) Error: Command completed with errors
(bootloader) The response for CMD8 does not match the supplied value
(bootloader) Decoded CID fields:
(bootloader) Manufacturer ID: 7f
(bootloader) OEM ID: 0x0
(bootloader) Product Name: 5270
(bootloader) Product revision: 5.2
(bootloader) Product serial number: B4E
(bootloader) Manufacturing date: 2 2015
(bootloader) sdhci_clk_supply: freq 50000000
(bootloader) Decoded CSD fields:
(bootloader) cmmc_structure: 0
(bootloader) card_cmd_class: 5f5
(bootloader) write_blk_len: 512
(bootloader) read_blk_len: 512
(bootloader) r2w_factor: 4
(bootloader) sector_size: 128
(bootloader) c_size_mult:2
(bootloader) c_size: 506
(bootloader) nsac_clk_cycle: 100
(bootloader) taac_ns: 70000
(bootloader) tran_speed: 26000 kbps
(bootloader) erase_blk_len: 0
(bootloader) read_blk_misalign: 0
(bootloader) write_blk_misalign: 0
(bootloader) read_blk_partial: 1
(bootloader) write_blk_partial: 0
(bootloader) Card Capacity: 4153344 Bytes
(bootloader) sdhci_set_bus_width: bus width 1
(bootloader) Done initialization of the card
(bootloader) erase_grpsize: 49152
(bootloader) erase_grpmult: 257380728
(bootloader) wp_grpsize: 1
(bootloader) wp_grpen: 1
(bootloader) perm_wp: 0
(bootloader) temp_wp: 0
(bootloader) [Tuxera][Error] No exFAT partition found
(bootloader) writesecureflag: KeyCard remain count 10000
(bootloader) PID:290
(bootloader) Start Verify: 3
(bootloader) [PGFS] partition_update_pgfs: pg1fs_security
Execution time is 4187(ms)
OKAY
Operation finished
Phone DISconnected
write imei 1
10/26/2015 6:27:13 PM Operation finished
10/26/2015 6:27:17 PM Phone DISconnected
10/26/2015 6:27:22 PM Phone connected [FA48LMZ01266] *** Fastboot mode
10/26/2015 6:34:46 PM Sending oem writeimei 3555880477xxxxx
10/26/2015 6:34:47 PM ... (bootloader) Start Verify: 0
Execution time is 31(ms)
write imei2
10/26/2015 6:34:47 PM Operation finished
10/26/2015 6:34:52 PM Sending oem writeimei2 3555880477xxxxx
10/26/2015 6:34:52 PM ... (bootloader) Start Verify: 0
write meid
10/26/2015 6:34:52 PM Operation finished
10/26/2015 6:37:21 PM Sending oem writemeid A0000023Dxxxxx
10/26/2015 6:37:21 PM ... (bootloader) Start Verify: 0
Super CID
Sending oem writecid 11111111
(bootloader) Input CID is super CID
Execution time is 46(ms)
OKAY
Operation finished
Br,
$ktelecom
The Following User Says Thank You to $ktelecom For This Useful Post:
Page generated in 0.17615 seconds with 7 queries
