12-01-2017, 22:09 | #3 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Roumania
Member: 691388 Status: Offline Thanks Meter: 371 | download from support "0PFJIMG_A51_UL_M60_DESIRE_SENSE70_MR_HTC_Europe_3 .17.401.3_Radio_01.01.010_U10305041_08.01.50512_re lease_476105_signed_2_4" and flash it over RUU. If u get error, try same version but "_partial_2_4.zip" Last instance if stil no luck, use "0PFJIMG_A51_UL_L50_DESIRE_SENSE60_MR_HTC_Europe_2 .10.401.2_R_Radio_01.01.010_U10305041_08.01.50512_ release_453024_signed_2_4.zip You are trying to flash K44... |
The Following User Says Thank You to maremestera For This Useful Post: |
12-02-2017, 09:15 | #5 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Romania Age: 37
Member: 120579 Status: Offline Thanks Meter: 182 | i tried with the sd mode, I push copy files and 820n reboots and gets stuck in recovery.... touchscreen not working. I see there it`s 820s , the dual-sim one. Is it the same ? |
12-02-2017, 11:56 | #6 (permalink) | |
Member: 120579 Status: Offline Thanks Meter: 182 | Quote:
still not working ... What Am I doing wrong ? | |
12-02-2017, 12:07 | #8 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | there is no need to flash your phone to network unlock just use sdmode to unlock http://forum.gsmhosting.com/vbb/f961...-step-1964502/ |
12-02-2017, 14:05 | #9 (permalink) |
Member: 120579 Status: Offline Thanks Meter: 182 | Ok, so I copy imei and tick "lock" choosing 0-unlocked with the imei below I choose save to drive Afterwards, I remove the sd from the sd-reader, insert in the phone and boot to Hboot Phone laaags a lot and I finally choose SIMLOCK Open MCCMNC file fail Open CID file fail Open IMEI file fail.... What am I doing wrong? |
12-02-2017, 14:08 | #10 (permalink) | |
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
D820n is qualcomm connect clip to pc and press read from drive and check | |
12-02-2017, 15:26 | #12 (permalink) |
Member: 220603 Status: Offline Thanks Meter: 1,164 | try repair xtc2clip system http://forum.gsmhosting.com/vbb/f961...t-etc-1964648/ if still same or other error please try changing flex |
12-02-2017, 15:33 | #13 (permalink) | |
I just did that... and repaired the flex ... I had a broken line Now phone accepts full firmware in RUU. Trying to unlock it now. | |
