Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > xtc2cliP
Old 10-11-2018, 06:20   #1 (permalink)
Pratheesh T K's Avatar
Member: 866865
Sonork: 1645198
Thanks Meter: 181
Htc A50cmg_dwg Imei Issue
I have an htc d728h
came as network problem
it show imei when i try *#06#
but it not show the same imei when show barecode from fastboot mode
Reading information...
Using Fastboot mode...
Reading common information
(bootloader) kernel: lk
(bootloader) product: htc_a50cmg_dwg
(bootloader) version: 1.0
(bootloader) imei: 000000000000000
(bootloader) version-main: 1.09.401.1
(bootloader) boot-mode: download
(bootloader) version-baseband: READ version-baseband ERROR
(bootloader) version-bootloader: 1.01.0000
(bootloader) mid: 2PQ830000
(bootloader) cid:
all:
Execution time is 5(ms)
Reading CID information
... (bootloader) cid:
OKAY
Execution time is 31(ms)
Reading MEID information
... FAILREAD MEID ERROR
FAILED (remote: READ MEID ERROR)
Execution time is 2(ms)
Reading IMEI1 information
... (bootloader) imei: 000000000000000
OKAY
Execution time is 0(ms)
Reading IMEI2 information
... FAILREAD IMEI2 ERROR
FAILED (remote: READ IMEI2 ERROR)
Reading secure flag information
... (bootloader) Device security level S-OFF
OKAY
Reading serial number information
... (bootloader) Device Serial No. is
OKAY
Read information completed.
how can i write the imei
Old 10-11-2018, 08:16   #2 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,147
use special unlock tab for this model
The Following User Says Thank You to deepakgarg For This Useful Post:
Old 10-24-2018, 21:00   #3 (permalink)
Member: 866865
Sonork: 1645198
Thanks Meter: 181
i tried that method
it show stage 1 to stage 4 done
found new imei 35...........
found new imei 2 35........
rebuild imei
process 5 done with 2 error
contact support with error 00000004
Old 10-24-2018, 21:02   #4 (permalink)
Member: 866865
Sonork: 1645198
Thanks Meter: 181
RESPONSE*FROM*IO € n‰™ia_r=#d /T„
ج fH†!t8D2{r8+ ϲfa‡QŠ0 3N/oO^,
UŽ–•›u†b Œ+bJ
U
œ~1 8oB^™%9jŠL
aœ@S–k˜hJ—
`z¨l…SCzŸY3#Q>S*T—z C<H:պ’‰J1J$B2aM=†š˲>€Œ>„Š. …O,Pg4S *ŠPlease wait...
Stage 3 done.
Process done 3 steps with 0 errors
Rebooting in 5 seconds ...
Rebooting in 4 seconds ...
Rebooting in 3 seconds ...
Rebooting in 2 seconds ...
Rebooting in 1 seconds ...
=============================RESPONSE*FROM*IO € ‰™/medc€+Q•y˜=;ằUT”<GȤO}“g?ŸKW[email protected]*Q_ cM+d5[ļ|2f*w ttMYPŽF:HQX|lH]”•MM‘ g‡—†&6ϩ…9I‘†zZ†2o„&EƒHRi! “i ޏ}k8€‰SkL’f1ŠPztu™†ofH J%/’ f1\to“<œ—N$׫@Please wait...
Stage 4 done.
Process done 5 steps with 2 errors
Code for support: 00000004
==RESPONSE*FROM*IO € ‰™/med†* #AId؍[c•…€!2ž$’—8$wǻgxBPŽm*0v>— {-[&ƒ3D>xHê,crî™|y#a*oX'=wŸP› @4›vy
Ž‡hϤλ‚~xm2gšw%\‹_Z–fL •s}z –qʦ‹sT)€ա=<MŠŠv
og||".^Ϳ~ ž/`™* 2'6L^hˆ™z…R C—q`Please wait...
Stage 4 done.
Found IMEI file, setting new IMEI to: 356258956947141
Found IMEI2 file, setting new IMEI2 to: 356258956947158
Rebuilding IMEI
Code for sRESPONSE*FROM*IO € ‰™/med€:%O˜†-eX‘,?~‰]1IG˜q_*žŠ‘…qIqŸr#D ,H
!m‡
Ţ/a#YCTˆ3Œ?‡|TL) ˜'ˆ*
9? PGr”ټ ܲ’$U—D7*7,خœ"_eں“U'94. ‚“]"$aŸI [icJ‹;>tŠx/S_P9D$Ž†‰ƒY“2 2'6L^hˆ™z…R C—q`(7:&DV˜`‰rcr@Q"%40N\ jxŠ›‡sb•PA5*$8FTbšp‹„•“ ,¥>@R+:dN_vm|‰” …›*$ÿ6H ;Z*^lO}~l
ƒ†‘—.<B)8P
fo~tL]‹™–‡Please wait...RESPONSE*FROM*IO €   ƒ ] ===============================
XTC 2 Clip - service tool v2.33
Detected release: A50CMG_DWG_L51_DESIRE_SENSE70
Detected model:
D728G DUAL SIM [MTK]
PreRESPONSE*FROM*IO € ‰™/med
ŠžeHP xC_š`!bN ~=IYHvYœ|s#I…3']rFK:@€G4r ~>YDSO’Fe?n\“ˆˆH
†› l^"u>M
Please wait...
Stage 4 done.
Found IMEI file, setting new IMEI to: RESPONSE*FROM*I
Found IMEI2 file, setting new IMEI2 to: RESPONSE*FROM*I
Rebuilding IMEI
this log from xtc 2 clip
Old 10-24-2018, 21:12   #5 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,147
Please repair clip
IMPORTANT: How to repair filesystem after format, etc
Than repeat process
Old 10-24-2018, 22:02   #6 (permalink)
Member: 866865
Sonork: 1645198
Thanks Meter: 181
Same Error Sir
RESPONSE*FROM*IO € ‰™/medx)–]iD8p‘OTH}٩Ž/‚}6X›4XVkp.U†|:u€ kW K—*rX7˜kV„Ĩ߾sbm1W†<
pSIŒ7”e>L*:‰|+“]a#IœY0FI:f—[ž†’'C`cSEˆ^‹5|=>5xš6ov
RŒŸHgts*Npqh 2'6L^hˆ™z…R C—q`(Please wait...
Stage 4 done.
Rebuilding IMEI
Old 10-25-2018, 07:45   #7 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,147
change flex and try again
Old 10-26-2018, 21:15   #8 (permalink)
Member: 866865
Sonork: 1645198
Thanks Meter: 181
I tried to change the flex from xtc clip
and still same error
Old 10-27-2018, 07:56   #9 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,147
make sure files were correctly copied from special tab selecting correct model
Page generated in 0.31432 seconds with 7 queries
