htc a55ml dtul e9pw wrong display 2 Attachment(s) Hi, i get this phone in hands htc e9+ after hard reset or firmware flash, start ok, but after set languaje, get big letters on screen and cant disable it. How i can fix?? |
Hello, What CID do you have? |
this is dot view flip cover mode mostly water damage problem |
Many thaks, i will check if can change or repair sensor. |
Or changing charging socket |
May Be it will help you install TWRP Recovery Goto System>App>hTCdotmatrix apk Delete this application if you dint get the file try to search in System>Priv-App>hTCdotmatrix apk i Solved the issue in HTC 820 it may be help you too if it helps please Hit the Thanks Button |
