Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > xtc2cliP
Old 08-30-2017, 21:28   #1 (permalink)
bananin's Avatar
Member: 150844
Thanks Meter: 236
htc a55ml dtul e9pw wrong display
Hi, i get this phone in hands htc e9+ after hard reset or firmware flash, start ok, but after set languaje, get big letters on screen and cant disable it.
How i can fix??
Old 08-31-2017, 19:01   #2 (permalink)
Member: 2416253
Thanks Meter: 3,760
Hello,
What CID do you have?
Old 08-31-2017, 20:10   #3 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,073
this is dot view flip cover mode mostly water damage problem
The Following 2 Users Say Thank You to deepakgarg For This Useful Post:
Old 08-31-2017, 20:18   #4 (permalink)
bananin's Avatar
Member: 150844
Thanks Meter: 236
Many thaks, i will check if can change or repair sensor.
Old 09-02-2017, 12:20   #5 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 3,901
Or changing charging socket
Old 04-13-2018, 12:59   #6 (permalink)
Member: 2632191
Thanks Meter: 6
Thumbs up May Be it will help you
install TWRP Recovery
Goto System>App>hTCdotmatrix apk
Delete this application
if you dint get the file try to search in System>Priv-App>hTCdotmatrix apk
i Solved the issue in HTC 820 it may be help you too
if it helps please Hit the Thanks Button
The Following User Says Thank You to somumaradi For This Useful Post:
Page generated in 0.24274 seconds with 8 queries
