09-14-2017, 14:34 | #16 (permalink) |
Crazy Poster Join Date: May 2008
Member: 775376 Status: Offline Sonork: 6620 Thanks Meter: 4 | Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_hiaewhl (bootloader) version: 1.0 (bootloader) max-download-size: 1164800000 (bootloader) serialno: HT5AHSZ03787 (bootloader) slot-count: 0 (bootloader) current-slot: (bootloader) imei: 990005704630384 (bootloader) version-main: 2.18.651.2 (bootloader) boot-mode: download (bootloader) version-baseband: 1.1.C40062.1@61213 (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 2PQ930000 (bootloader) cid: 11111111 all: Execution time is 10(ms) Reading CID information ... (bootloader) cid: 11111111 OKAY Execution time is 50(ms) Reading MEID information ... (bootloader) meid: 99000570463038 OKAY Execution time is 0(ms) Reading IMEI1 information ... (bootloader) imei: 990005704630384 OKAY Execution time is 0(ms) Reading IMEI2 information ... (bootloader) imei2: OKAY Execution time is 0(ms) Reading secure flag information ... (bootloader) Device security level S-OFF OKAY Execution time is 10(ms) Reading serial number information ... (bootloader) Device Serial No. is HT5AHSZ03787 OKAY Execution time is 0(ms) Read information completed. |
09-17-2017, 14:43 | #17 (permalink) |
Member: 775376 Status: Offline Sonork: 6620 Thanks Meter: 4 | Originally Posted by MD MILON HOSSAN View Post my file download your sapport site.fast flash this file 2PQ9IMG_HIA_AERO_WHL_N70_SENSE80GP_SPCS_MR_Sprint_ WWE_2.18.651.2_Radio_1.1.C40062.1@61213_15.00_CNV_ CNV_AERO_SPCS_1.15_003_release_494945_partial_2_4 but same problem flashing set show hosd_signed img fail pl sir solition |
09-20-2017, 06:11 | #20 (permalink) |
Member: 775376 Status: Offline Sonork: 6620 Thanks Meter: 4 | Starting flash process... target reported max download size of 1164800000 bytes sending 'zip' (98962 KB)... OKAY [ 5.143s] writing 'zip'... (bootloader) HOSD CL#861755 (bootloader) GPT (gpt_main_32g.img) is up-to-dated. [17408] (bootloader) Perform pre-update (bootloader) WARN Skip partition_info due to unmatched partition name (bootloader) get 23 images from zip(zip_type=3) (bootloader) start@23 (bootloader) apppreload.img@BYPASS (bootloader) aboot_signed.img@100% (bootloader) cota.img@BYPASS (bootloader) dzdata_32g.img@BYPASS (bootloader) sbl1-8952-1.img@100% (bootloader) ERR [hosd] CRC ERROR (bootloader) ERR should be 0xea8b3d95, calculated 0xabb42669 (bootloader) hosd_signed.img@FAIL (bootloader) rpm-8952-1.img@100% (bootloader) boot_signed.img@BYPASS (bootloader) recovery_signed.img@BYPASS (bootloader) adsp.img@BYPASS (bootloader) dsp.img@BYPASS (bootloader) wcnss.img@BYPASS (bootloader) rfg_1.img@BYPASS (bootloader) fsc.img@BYPASS (bootloader) tz-8952-1.img@100% (bootloader) hyp-8952-1.img@100% (bootloader) cmnlib32.img@100% (bootloader) keymaster.img@100% (bootloader) pg2fs_ship_signkey.img@100% (bootloader) sensor_hub.img@BYPASS (bootloader) tp_SYN3708.img@BYPASS (bootloader) splash1.nb0@BYPASS (bootloader) radio.img@BYPASS (bootloader) ERR [SD_UPDATE_ERR] int do_update_zip_buf(int): unzip_and_f (bootloader) lash_images fail, err 11 (bootloader) ERR [SD_UPDATE_ERR] update_fb_ZIP_buf: fail to flash zip: 1 (bootloader) ERR [SD_UPDATE_ERR] sddownload failed: 11 (bootloader) ERR Update zip file failed. (bootload er) Update zip file OK (bootloader) ERR ZIP ERROR CODE, 11 (bootloader) end@Done FAILED (remote: 11 RU_CHECKSUM_FAIL invalid rom-pack ) finished. total time: 13.156s HBoot pre-update sequence Flash process completed. Flash not successfull, reboot will not be done pl sir help me Last edited by MD MILON HOSSAN; 09-20-2017 at 06:20. |
09-20-2017, 06:32 | #21 (permalink) |
Member: 775376 Status: Offline Sonork: 6620 Thanks Meter: 4 | [QUOTE=MD MILON HOSSAN;12690462]Originally Posted by MD MILON HOSSAN View Post my file download your sapport site.fast flash this file 2PQ9IMG_HIA_AERO_WHL_N70_SENSE80GP_SPCS_MR_Sprint_ WWE_2.18.651.2_Radio_1.1.C40062.1@61213_15.00_CNV_ CNV_AERO_SPCS_1.15_003_release_494945_partial_2_4 but same problem flashing set show apppreload.signed img fail 11ru_checksum_fail invalid rom pack pleace sir urgent solition |
09-20-2017, 06:35 | #22 (permalink) |
Member: 775376 Status: Offline Sonork: 6620 Thanks Meter: 4 | [QUOTE=MD MILON HOSSAN;12690462]Originally Posted by MD MILON HOSSAN View Post my file download your sapport site.fast flash this file 2PQ9IMG_HIA_AERO_WHL_N70_SENSE80GP_SPCS_MR_Sprint_ WWE_2.18.651.2_Radio_1.1.C40062.1@61213_15.00_CNV_ CNV_AERO_SPCS_1.15_003_release_494945_partial_2_4 but same problem flashing set show apppreload.signed img fail 11ru_checksum_fail invalid rom pack pleace sir urgent solition Report Post Edit/Delete Message |
09-20-2017, 10:46 | #23 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Hello, Do you have A9 Sprint? 2 possible problems: - Your phone is not Sprint, and you are trying to flash Sprint firmware inside and, most likely: - EMMC is damaged, as the checksum during flashing didn't match. |
