02-13-2018, 07:51 | #1 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Around GSM World
Member: 17684 Status: Offline Sonork: 100.1612623 Thanks Meter: 43 | Htc s-0ff problem ... (bootloader) SecuritySDInit: counter = 2 (bootloader) m8_init_sd, SD card already power on (bootloader) [SPEW] GPIO 0 status is 0 (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: -16777216 (bootloader) erase_grpmult: 261078040 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) [JAVACARD_ERR] get Decrease Renew Cycle fail, SW= 6986 (bootloader) writesecureflag: Permission denied, value 8 OKAY Execution time is 4(s) Operation finished |
02-13-2018, 07:55 | #2 (permalink) |
Member: 17684 Status: Offline Sonork: 100.1612623 Thanks Meter: 43 | Write cid 1111111 also write cid result.Sending oem writecid 11111111 ... (bootloader) SecuritySDInit: counter = 3 (bootloader) m8_init_sd, SD card already power on (bootloader) [SPEW] GPIO 0 status is 0 (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: -16777216 (bootloader) erase_grpmult: 261077976 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) [JAVACARD_ERR] get Decrease Renew Cycle fail, SW= 6986 (bootloader) Start Verify: 3 (bootloader) Start Verify: 3 (bootloader) deinit_lcd (bootloader) mipi display off (bootloader) mdp_clock_off (bootloader) disable_mmss_clk done (bootloader) pll1_disable done (bootloader) TZ_HTC_SVC_DISABLE ret = -1610744452 (0x9FFDFD7C) (bootloader) [CRITICAL] SPMI write command failure: cmd_id = 0, error (bootloader) = 4 (bootloader) [CRITICAL] SPMI write command failure: cmd_id = 0, error (bootloader) = 4 (bootloader) [ERR] Cannot halt SPMI arbiter!! (bootloader) [INFO] Rebooting device |
02-13-2018, 08:06 | #4 (permalink) |
Member: 17684 Status: Offline Sonork: 100.1612623 Thanks Meter: 43 | Info reading info.Reading information... Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 1.29.214500021.12G (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 6.12.401.4 (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: SH43AWM04808 (bootloader) imei: 358714055637965 (bootloader) imei2: Not Support (bootloader) meid: 00000000000000 (bootloader) product: m8_ul (bootloader) platform: hTCBmsm8974 (bootloader) modelid: 0P6B10000 (bootloader) cidnum: HTC__J15 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 76df2b54 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! Execution time is 31(ms) Reading CID information ... (bootloader) cid: HTC__J15 OKAY Execution time is 62(ms) Reading MEID information ... (bootloader) meid: 00000000000000 OKAY Execution time is 62(ms) Reading IMEI1 information ... (bootloader) imei: 358714055637965 OKAY Execution time is 46(ms) Reading IMEI2 information ... (bootloader) readimei2: Not Support OKAY Execution time is 62(ms) Reading secure flag information ... (bootloader) secure_flag: 3 OKAY Execution time is 46(ms) Reading serial number information ... (bootloader) [ERR] Command error !!! OKAY Execution time is 46(ms) Read information completed. |
