01-26-2018, 06:40 | #1 (permalink) |
Freak Poster Join Date: Jan 2006 Location: SURESH ELECTRONICS, INDIA Age: 49
Member: 216081 Status: Offline Sonork: 100.1614205 Thanks Meter: 55 | HTC d628h flashing eror target rom version: 1.16.400.1 found large-zip header, file count: 8 processing file 1/8... sending 'zip' (150485 KB)... OKAY [ 8.676s] writing 'zip'... (bootloader) HOSD CL#788931 FAILED (remote: 4: SD_BATTERY_LOW, BATTERY LEVEL < (30%)) finished. total time: 12.166s Flash process completed. Flash not successfull, reboot will not be done read information: Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_v36bml_dugl (bootloader) version: 1.0 (bootloader) imei: 3572920719xxxxxx (bootloader) version-main: 1.16.400.1 (bootloader) boot-mode: RUU (bootloader) version-baseband: READ version-baseband ERROR (bootloader) version-bootloader: 1.01.0000 (bootloader) mid: 2PVG20000 (bootloader) cid: HTC__060 all: Execution time is 0(ms) Reading CID information ... (bootloader) cid: HTC__060 OKAY Execution time is 31(ms) Reading MEID information ... FAILREAD MEID ERROR FAILED (remote: READ MEID ERROR) Execution time is 0(ms) Reading IMEI1 information ... (bootloader) imei: 357292071998332 OKAY Execution time is 17(ms) Reading IMEI2 information ... FAILREAD IMEI2 ERROR FAILED (remote: READ IMEI2 ERROR) Execution time is 5(ms) Reading secure flag information ... (bootloader) Device security level S-ON OKAY Execution time is 15(ms) Reading serial number information ... (bootloader) Device Serial No. is OE69FBT07422 OKAY Execution time is 0(ms) Read information completed. On sdcard update same error "battery low". please help |
09-13-2020, 16:54 | #5 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Hello, If you get "BATTERY LOW" first make sure the battery is OK, because it may happen that the battery is worn and won't charge to the necessary 30% minimum, in this situation it's advised to replace the battery first and then perform flashing. |
