09-26-2016, 19:24 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Egypt Age: 35
Member: 629039 Status: Offline Sonork: 100.112945 Thanks Meter: 847 | htc d728h fail in flash Code: Starting flash process... target rom version: 1.08.401.3 found large-zip header, file count: 7 processing file 1/7... sending 'zip' (41705 KB)... OKAY [ 4.385s] writing 'zip'... (bootloader) HOSD CL#647213 (bootloader) GPT is up-to-dated. [524288] (bootloader) Perform pre-update (bootloader) start@14 (bootloader) tee1.img@100% (bootloader) tee2.img@100% (bootloader) preloader.bin@100% (bootloader) pg2fs_ship_signkey.img@BYPASS (bootloader) apppreload.img@BYPASS (bootloader) secro_verified.img@100% (bootloader) cota.img@BYPASS (bootloader) tp_HMX852XE_SECOND.img@BYPASS (bootloader) tp_HMX852XE_MAIN.img@BYPASS (bootloader) lk_verified.bin@100% (bootloader) hosd_verified.img@100% (bootloader) boot_verified.img@BYPASS (bootloader) recovery_verified.img@BYPASS (bootloader) logo_verified.bin@100% (bootloader) Perform hardware reset FAILED (remote: 90 hboot pre-update! please flush image again immediately) finished. total time: 6.667s preupdate done, rebooting... Phone DISconnected resending command... < waiting for device > sending 'zip' (41705 KB)... Phone connected [LC5CTZ703570] *** Fastboot mode OKAY [ 5.351s] writing 'zip'... (bootloader) HOSD CL#647213 (bootloader) GPT is up-to-dated. [524288] (bootloader) start@14 (bootloader) tee1.img@100% (bootloader) tee2.img@100% (bootloader) preloader.bin@100% (bootloader) pg2fs_ship_signkey.img@100% (bootloader) apppreload.img@50% (bootloader) apppreload.img@100% (bootloader) secro_verified.img@100% (bootloader) cota.img@100% (bootloader) lk_verified.bin@100% (bootloader) hosd_verified.img@100% (bootloader) boot_verified.img@100% (bootloader) tp_HMX852XE_SECOND.img@BYPASS (bootloader) recovery_verified.img@100% (bootloader) logo_verified.bin@100% (bootloader) tp_HMX852XE_MAIN.img@20% (bootloader) tp_HMX852XE_MAIN.img@45% (bootloader) tp_HMX852XE_MAIN.img@100% (bootloader) tp_HMX852XE_MAIN.img@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 24.190s] finished. total time: 29.542s processing file 2/7... sending 'zip' (342304 KB)... OKAY [ 29.002s] writing 'zip'... (bootloader) HOSD CL#647213 (bootloader) ERR ZIP signature checking failed... (bootloader) ERR [SD_UPDATE_ERR] sddownload failed: 8 (bootloader) ERR Update zip file failed. (bootloader) Update zip file OK (bootloader) ERR ZIP ERROR CODE, 8 (bootloader) end@Done FAILED (remote: 8: fail to flash via downloadzip) finished. total time: 42.495s HBoot pre-update sequence Flash process completed. Flash not successfull, reboot will not be done |
