04-19-2016, 11:17 | #1 (permalink) |
No Life Poster Join Date: Jan 2013 Location: HUAWEI FRP KEY imei-code
Member: 1870489 Status: Offline Sonork: 100.1663831 Thanks Meter: 483 | Htc d816w flashing error Starting flash process... sending 'zip'... (45330 KB) OKAY writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) signature checking... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... Execution time is 50350(ms) FAIL22 loading zip info fail Please check if you flash par FAILED (remote: 22 loading zip info fail Please check if you flash par) Checking if phone will restart... Execution time is 10(ms) getvar:boot-mode FAILED (unknown status code) Flash process completed. Flash not successfull, reboot will not be done HELP ME |
04-19-2016, 11:25 | #4 (permalink) |
Freak Poster Join Date: Aug 2015
Member: 2438620 Status: Offline Thanks Meter: 156 | When you get error "Flash not successfull, reboot will not be done" click on "Flash phone" again basically your just flashing 2 times Last edited by brianhamp; 04-19-2016 at 11:31. |
04-19-2016, 11:30 | #5 (permalink) |
Member: 2438620 Status: Offline Thanks Meter: 156 | If that doesn't work Im not sure what it would be... Software,Hardware issue?? My past experience flashing with XTC2 clip is I flash twice and it works for me 100% of the time.. I really hope this works for you. |
04-19-2016, 12:10 | #8 (permalink) | |
Member: 1870489 Status: Offline Sonork: 100.1663831 Thanks Meter: 483 | Quote:
Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 1.13.3230.27.0303 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 2.34.401.2 (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: FA48YWW02254 (bootloader) imei: 352706063508614 (bootloader) imei2: 352706063508622 (bootloader) meid: 00000000000000 (bootloader) product: a5_dug (bootloader) platform: hTCBmsm8226 (bootloader) modelid: 0P9C70000 (bootloader) cidnum: HTC__J15 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: RUU (bootloader) commitno-bootloader: 09813c97 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 Execution time is 34(ms) all: Done! Reading secure flag information ... (bootloader) secure_flag: 3 Execution time is 11(ms) OKAY Reading CID information ... (bootloader) cid: HTC__J15 Execution time is 10(ms) OKAY Reading MEID information ... (bootloader) meid: 00000000000000 Execution time is 11(ms) OKAY Read information completed. | |
04-19-2016, 12:30 | #9 (permalink) |
Member: 2438620 Status: Offline Thanks Meter: 156 | Ok why don't you S-off the phone and set CID to super cid 11111111. This will eliminate alot of problems.... You have the XTC2 clip which is a very powerful device and between your device and our brains we can do this!!! I have faith in us and the XTC2 clip Last edited by brianhamp; 04-19-2016 at 12:35. |
01-16-2017, 21:57 | #12 (permalink) |
No Life Poster Join Date: Feb 2003 Location: HUR / R.S Age: 39
Member: 21750 Status: Offline Sonork: 100.62509 Thanks Meter: 73 | i have same problem with desire 820 Starting flash process... target rom version: 3.17.401.3 found large-zip header, file count: 8 processing file 1/8... sending 'zip' (49306 KB)... OKAY [ 3.192s] writing 'zip'... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... FAILED (remote: 22 loading zip info fail Please check if you flash par) finished. total time: 3.475s Flash process completed. Flash not successfull, reboot will not be done s-off change cid unlock or relock bootloader same problem any help ? |
06-01-2017, 11:13 | #13 (permalink) |
Freak Poster Join Date: Jan 2015 Location: Nepal
Member: 2321524 Status: Offline Sonork: 100.1679349 Thanks Meter: 33 | help me team where i did mistake plz Starting flash process... target rom version: 3.12.708.1 found large-zip header, file count: 6 processing file 1/6... sending 'zip' (45331 KB)... OKAY [ 2.682s] writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) signature checking... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... FAILED (remote: 22 loading zip info fail Please check if you flash par) finished. total time: 6.950s Flash process completed. Flash not successfull, reboot will not be done |
02-16-2018, 15:22 | #14 (permalink) | |
Freak Poster Join Date: Feb 2008
Member: 714291 Status: Offline Thanks Meter: 39 | Quote:
have you solved this problem I am experiencing same problem If solution is available please assist me Thank you | |
02-16-2018, 15:27 | #15 (permalink) |
Member: 714291 Status: Offline Thanks Meter: 39 | Reading information... Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 1.101.1102.17.0506 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: SH45JWW00577 (bootloader) imei: 352241061533620 (bootloader) imei2: Not Support (bootloader) meid: 00000000000000 (bootloader) product: a5_ul (bootloader) platform: hTCBmsm8226 (bootloader) modelid: 0P9C21000 (bootloader) cidnum: HTC__621 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: be7179e5 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! Execution time is 0(ms) Reading CID information ... (bootloader) cid: HTC__621 OKAY Execution time is 15(ms) Reading MEID information ... (bootloader) meid: 00000000000000 OKAY Execution time is 0(ms) Reading IMEI1 information ... (bootloader) imei: 352241061533620 OKAY Execution time is 0(ms) Reading IMEI2 information ... (bootloader) readimei2: Not Support OKAY Execution time is 0(ms) Reading secure flag information ... (bootloader) secure_flag: 3 OKAY Execution time is 15(ms) Reading serial number information ... (bootloader) [ERR] Command error !!! OKAY Execution time is 15(ms) Read information completed. |
