06-08-2017, 20:49 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: fontecno
Member: 1201378 Status: Offline Sonork: 100.1594717 Thanks Meter: 303 | Htc d820n cid-response Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 01.01.010_U10305041_08.01.41222_2 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 1.28.75.5 (bootloader) version-misc: PVT SHIP S-OFF (bootloader) serialno: HT55WYC00961 (bootloader) imei: 355195000000010 (bootloader) imei2: Not Support (bootloader) meid: 00000000000000 (bootloader) product: a51_ul (bootloader) platform: hTCBmsm8939 (bootloader) modelid: 0PFJ40000 (bootloader) cidnum: RESPONSE (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 0fb40ee2 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 (bootloader) mfg-name: 0001 all: Done! Execution time is 19(ms) Reading secure flag information ... (bootloader) secure_flag: 0 OKAY Execution time is 15(ms) Reading CID information ... (bootloader) cid: RESPONSE OKAY Execution time is 15(ms) Reading MEID information ... (bootloader) meid: 00000000000000 OKAY Execution time is 0(ms) Read information completed. I have try all this but still having the same problema Hello, NOTE: August 25, a new image has been uploaded. It will prevent Android from creating system files. Many customers are trying to format the clip with wrong fs, which leads to a corrupted file system. File system can also be corrupted by the wrong ejection from USB, etc. We have a procedure that you may use to restore your clip to factory state: 1) Download this application: Download Win32 Disk Imager from SourceForge.net 2) Download filesystem image: http://xtc2.net/downloads/image2017s.img (short version, faster flashing) http://xtc2.net/downloads/image2015.img (full version, in case short doesn't help) 3) Run Win32 Disk Imager 4) In the "Image file" select downloaded "image2015.img" 5) Connect XTC2Clip to the microSD reader. 6) Select the correct disk drive in the "Device" droplist. WARNING! Make a careful selection. If you choose a wrong drive, you can erase data on one of your disks. 7) Press "Write" and wait for the operation to complete. It may take 1-2 minutes. 8) Reconnect clip Done. Please recreate the files you need (e.g. sf.txt, etc) and you may start using the clip as usual. here the simple steps of animation video : |
06-13-2017, 08:01 | #5 (permalink) |
Freak Poster Join Date: Nov 2015 Location: Taipei, Taiwan
Member: 2487890 Status: Offline Thanks Meter: 72 | Is it hard to understand? http://imgur.com/a/WRWV3 |
