HTC Desire 12 PLUS not supported ? I want to read info and i get only this : Reading information... Using Fastboot mode... Reading common information (bootloader) version:0.5 (bootloader) battery-soc-ok:yes (bootloader) battery-voltage:4262000 (bootloader) variant:QRD eMMC (bootloader) unlocked:no (bootloader) secure:yes (bootloader) version-baseband: (bootloader) version-bootloader: (bootloader) display-panel: (bootloader) off-mode-charge:0 (bootloader) charger-screen-enabled:0 (bootloader) max-download-size: 0x1fe00000 (bootloader) partition-type:userdata:ext4 (bootloader) partition-size:userdata: 0x5d7af5e00 (bootloader) partition-type:logdump: (bootloader) partition-size:logdump: 0x4000000 (bootloader) partition-type:cota: (bootloader) partition-size:cota: 0x4000000 (bootloader) partition-type:apppreload: (bootloader) partition-size:apppreload: 0x14000000 (bootloader) partition-type:proinfo: (bootloader) partition-size:proinfo: 0x80000 (bootloader) partition-type:dpo: (bootloader) partition-size:dpo: 0x2000 (bootloader) partition-type:msadp: (bootloader) partition-size:msadp: 0x40000 (bootloader) partition-type:apdp: (bootloader) partition-size:apdp: 0x40000 (bootloader) partition-type:keymasterbak: (bootloader) partition-size:keymasterbak: 0x100000 (bootloader) partition-type:keymaster: (bootloader) partition-size:keymaster: 0x100000 (bootloader) partition-type:cmnlib64bak: (bootloader) partition-size:cmnlib64bak: 0x100000 (bootloader) partition-type:cmnlib64: (bootloader) partition-size:cmnlib64: 0x100000 (bootloader) partition-type:cmnlibbak: (bootloader) partition-size:cmnlibbak: 0x100000 (bootloader) partition-type:cmnlib: (bootloader) partition-size:cmnlib: 0x100000 (bootloader) partition-type:lksecappbak: (bootloader) partition-size:lksecappbak: 0x20000 (bootloader) partition-type:lksecapp: (bootloader) partition-size:lksecapp: 0x20000 (bootloader) partition-type:mcfg: (bootloader) partition-size:mcfg: 0x400000 (bootloader) partition-type:syscfg: (bootloader) partition-size:syscfg: 0x80000 (bootloader) partition-type:mdtp: (bootloader) partition-size:mdtp: 0x2000000 (bootloader) partition-type:dip: (bootloader) partition-size:dip: 0x100000 (bootloader) partition-type:mota: (bootloader) partition-size:mota: 0x80000 (bootloader) partition-type:limits: (bootloader) partition-size:limits: 0x8000 (bootloader) partition-type:oem: (bootloader) partition-size:oem: 0x10000000 (bootloader) partition-type:config: (bootloader) partition-size:config: 0x8000 (bootloader) partition-type:keystore: (bootloader) partition-size:keystore: 0x80000 (bootloader) partition-type:misc: (bootloader) partition-size:misc: 0x100000 (bootloader) partition-type:persist: (bootloader) partition-size:persist: 0x2000000 (bootloader) partition-type:cache:ext4 (bootloader) partition-size:cache: 0x10000000 (bootloader) partition-type:vendor: (bootloader) partition-size:vendor: 0x40000000 (bootloader) partition-type:system:ext4 (bootloader) partition-size:system: 0xc0000000 (bootloader) partition-type:devinfo: (bootloader) partition-size:devinfo: 0x100000 (bootloader) partition-type:recovery: (bootloader) partition-size:recovery: 0x4000000 (bootloader) partition-type:boot: (bootloader) partition-size:boot: 0x4000000 (bootloader) partition-type:abootbak: (bootloader) partition-size:abootbak: 0x100000 (bootloader) partition-type:aboot: (bootloader) partition-size:aboot: 0x100000 (bootloader) partition-type:splash: (bootloader) partition-size:splash: 0xb00000 (bootloader) partition-type:sec: (bootloader) partition-size:sec: 0x4000 (bootloader) partition-type:fsg: (bootloader) partition-size:fsg: 0x180000 (bootloader) partition-type:DDR: (bootloader) partition-size:DDR: 0x8000 (bootloader) partition-type:modemst2: (bootloader) partition-size:modemst2: 0x180000 (bootloader) partition-type:modemst1: (bootloader) partition-size:modemst1: 0x180000 (bootloader) partition-type:dsp: (bootloader) partition-size:dsp: 0x1000000 (bootloader) partition-type:devcfgbak: (bootloader) partition-size:devcfgbak: 0x40000 (bootloader) partition-type:devcfg: (bootloader) partition-size:devcfg: 0x40000 (bootloader) partition-type:tzbak: (bootloader) partition-size:tzbak: 0x200000 (bootloader) partition-type:tz: (bootloader) partition-size:tz: 0x200000 (bootloader) partition-type:rpmbak: (bootloader) partition-size:rpmbak: 0x80000 (bootloader) partition-type:rpm: (bootloader) partition-size:rpm: 0x80000 (bootloader) partition-type:sbl1bak: (bootloader) partition-size:sbl1bak: 0x80000 (bootloader) partition-type:sbl1: (bootloader) partition-size:sbl1: 0x80000 (bootloader) partition-type:ssd: (bootloader) partition-size:ssd: 0x2000 (bootloader) partition-type:fsc: (bootloader) partition-size:fsc: 0x400 (bootloader) partition-type:modem: (bootloader) partition-size:modem: 0x5400000 (bootloader) serialno:42b07517 (bootloader) kernel:lk (bootloader) product:BREPDUGL all: Execution time is 1(s) Reading CID information ... FAILunknown command FAILED (remote: unknown command) Execution time is 0(ms) Reading MEID information ... FAILunknown command FAILED (remote: unknown command) Execution time is 15(ms) Reading IMEI1 information ... FAILunknown command FAILED (remote: unknown command) Execution time is 15(ms) Reading IMEI2 information ... FAILunknown command FAILED (remote: unknown command) Execution time is 0(ms) Reading secure flag information ... FAILunknown command FAILED (remote: unknown command) Execution time is 15(ms) Reading serial number information ... FAILunknown command FAILED (remote: unknown command) Execution time is 15(ms) Read information completed. Phone is fully functional and I want only to know what CID is in the phone. Only info is shown about Product ID : BREPDUGL. |
Hi! Thanks for the information, can you please read info in download mode? |
Download mode ? What do you mean ? In fastboot mode there are only few modes to choose: Recovery mode Restart bootloader Start Boot to FFBM Powet off Thats all. There is no enter download mode to choose. This phone has got very similar fastboot menu to htc u12 plus. |
Thanks for the information, I will get back to you in PM as I need more information to negotiate with the team. |
Hi, I got the some problem! Will Htc desire 12 plus be support one day? |
We don't have support for this model yet, as it has a very limited number of interfaces. What kind of functions do you need for this model? Flash, simlock ? |
hi i have seme model nead frp remove ? |
http://forum.gsmhosting.com/vbb/13853508-post1.html |
Hey, is there a solution yet? I have the same problem here. U12+ without download mode. Boot partitions seem to be bricked. Thank you! |
do you answer only threads you like? why you take part in discussion in this thread, but left all 3 my threads for last 3 weeks without any answers? same as few last threads from other users! and also do not answer even on PM? Is it OK for you? |
