Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 12-23-2016, 08:50   #1 (permalink)
Member: 956406
Thanks Meter: 55
HTC Desire 530 for unlock
Hello . When I try to S-OF on step 5 give me
Please wait, preparing your phone...
Sorry, adb server is out of date. killing...
* daemon started successfully *
error: device offline
is not yet supported.
This is the phone...
Reading information...
Using Fastboot mode...
Reading common information
(bootloader) kernel: lk
(bootloader) product: htc_a16ul
(bootloader) version: 1.0
(bootloader) imei: 354773076004153
(bootloader) version-main: 1.10.161.5
(bootloader) boot-mode: download
(bootloader) version-baseband: 01.01_U113251281_53.05.60302G
(bootloader) version-bootloader: 1.0.0.0000
(bootloader) mid: 2PST10000
(bootloader) cid: VODAP001
all:
Execution time is 83(ms)
Reading secure flag information
... (bootloader) Device security level S-ON
OKAY
Execution time is 60(ms)
Reading CID information
... (bootloader) cid: VODAP001
OKAY
Execution time is 13(ms)
Reading MEID information
... (bootloader) meid:
OKAY
Execution time is 16(ms)
Read information completed.
Can or can not unlock this phone with XTC2Clip ?...and if can how exactlly ? Thanks in advance .
Old 12-23-2016, 17:09   #2 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello,
Yes you can. S-OFF first, and then use "Special unlock / IMEI".
As you your first message - JUST CLICK S-OFF ONE MORE TIME.
The Following User Says Thank You to xtc2clip For This Useful Post:
Old 12-23-2016, 23:10   #3 (permalink)
DeyviBox's Avatar
Member: 1637268
Sonork: 100.1606882
Thanks Meter: 18
Sending oem writesecureflag 0
... (bootloader) HTC KEY CARD VERSION: 7
FAILPERMISSION DENY (VERIFY_FAIL)
FAILED (remote: PERMISSION DENY (VERIFY_FAIL))
Execution time is 3(s)
Operation finished
Old 12-23-2016, 23:16   #4 (permalink)
DeyviBox's Avatar
Member: 1637268
Sonork: 100.1606882
Thanks Meter: 18
Starting bootloader unlock procedure
Phone detected, reading token...
Token detected successfully
Checking server connection...
Communicating with the XTC 2 Clip ...
Connecting to the server...
Waiting for the server to process request, it may take up to 5 minutes...
Your request was processed successfully! Unlock token has been obtained
Sending flash unlocktoken "C:\Program Files\XTC 2 Tool\\unlocktoken_HT66SBR01761.bin"
sending 'unlocktoken' (0 KB)... OKAY
writing 'unlocktoken'... (bootloader) flash unlocktoken
(bootloader) [KillSwitch] : /dev/block/bootdevice/by-name/frp
(bootloader) [KillSwitch] Last Byte is 0X01, enable unlock
(bootloader) unlock token check successfully
OKAY
Execution time is 1(s)
Please continue the unlock process on your phone.
Phone DISconnected
Phone connected [HT66SBR01761] *** Fastboot mode
Phone DISconnected
Phone connected [9885e64b5555584748] *** ADB mode
Phone DISconnected
Old 12-24-2016, 14:28   #5 (permalink)
Member: 2416253
Thanks Meter: 4,162
Please be so kind to provide description to your logs...
Old 12-25-2016, 14:36   #6 (permalink)
Member: 155397
Thanks Meter: 21
DESİRE 530 S-OFF OK OK OK OK THANK YOU
24/12/2016 18:50:47 Please wait, preparing your phone...
24/12/2016 18:50:48 HTC Desire 530 detected
24/12/2016 18:50:48 Android release: 6.0.1
24/12/2016 18:50:49 Checking server connection...
24/12/2016 18:50:49 Communicating with the XTC 2 Clip ...
24/12/2016 18:50:55 Connecting to the server...
24/12/2016 18:50:55 Please wait, processing your request...
24/12/2016 18:51:04 Finished. Your phone will be S-OFF on restart.
24/12/2016 18:51:05 Phone DISconnected
24/12/2016 18:51:54 Phone connected [FA63JBR01664] *** ADB mode
24/12/2016 18:53:17 Sending reboot-bootloader
Old 12-25-2016, 18:15   #7 (permalink)
Member: 1215266
Thanks Meter: 129
How to into FTM ??????
Old 12-28-2016, 12:14   #8 (permalink)
Member: 2606705
Thank you very much for answering when you enter "Special Unlock / Imei" in step 1 the files are copied to the micro sd of xtc 2 clip are copied perfectly.
Step two is to enter the FTM mode and it's there that you will not let me in on you
How to enter the FTM?
Old 01-28-2017, 19:30   #9 (permalink)
mobile-phone-service's Avatar
Member: 599385
Sonork: 100.1583205
Thanks Meter: 82
And why the HTC Desire 530 is not going in to FTM mode?????Just restarts???
Old 02-08-2017, 17:32   #10 (permalink)
Member: 255466
Thanks Meter: 12
3 different 530 not going to FTM mode, somebody can explain this??
Old 02-10-2017, 22:58   #11 (permalink)
Member: 255466
Thanks Meter: 12
Nobody knows??? strange....
Old 02-12-2017, 16:21   #12 (permalink)
Member: 2416253
Thanks Meter: 4,162
You cannot enter FTM unless phone is S-OFF.
First S-OFF, then the reset.
Old 09-24-2018, 08:49   #13 (permalink)
Member: 448264
Thanks Meter: 78
Can't unlock,europina firmware, phone is s-off, bootloader unlocked, twrp flashed
In FTM mode 1 sec show diag screen then screen black few hours
Old 09-24-2018, 12:45   #14 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
http://forum.gsmhosting.com/vbb/13330056-post26.html
The Following 2 Users Say Thank You to deepakgarg For This Useful Post:
Old 06-02-2021, 18:28   #15 (permalink)
chlakh11787's Avatar
Member: 378892
Thanks Meter: 51
Originally Posted by calitox View Post
This is my log....
Please download this:
https://xtc2.net/downloads/2PSTDIAG
Replace file on the clip and repeat operation (do NOT use copy files button, just insert clip and reboot to FTM)
Report Post
uote:
can you upload pls i have sam problem unlocke
Page generated in 0.21357 seconds with 10 queries
