Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 02-08-2017, 04:30   #1 (permalink)
Little_Master's Avatar
Member: 1205146
Thanks Meter: 879
HTC Desire 530 Unlock Problem " Failed to Enable SIMLOCK " [SOLVED]
HTC Desire 530 is giving error on Unlocking.
Unlock Bootloader is DONE
Phone S-OFF is DONE
Custom Recovery is DONE.
When I put phone is FTM Mode and press SIMLOCK TOOL , it says :
" Chosen_item 2
Loading simlock tool ...
Failed to enable SIMLOCK "
I have tried couple of time, even with xtc clip i copied specail files couple of times, but still showing error.
Picture Attached
What is the solution ???
LITTLE MASTER
The Following User Says Thank You to Little_Master For This Useful Post:
Old 02-09-2017, 16:11   #2 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello,
You don't need to use this.
Please use "Special unlock/IMEI" tab.
The Following 4 Users Say Thank You to xtc2clip For This Useful Post:
Old 02-19-2017, 14:20   #3 (permalink)
Sudan-Mobiles's Avatar
Member: 281857
Thanks Meter: 214
Originally Posted by xtc2clip View Post
Hello,
SAME PROBLEM what should I do after s-off and copy files from special unlock tab .. ?
I insert clip in sd card off phone and press FTM phone phone went to same as picture
Old 02-21-2017, 18:30   #4 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello,
It means that files are not copied correctly, clip ejected too quick or no safe removal was done.
Try to repair FS:
http://forum.gsmhosting.com/vbb/f961...t-etc-1964648/
then copy files again, do Safe eject and then insert into phone and press "FTM".
This should work.
Old 02-21-2017, 22:42   #5 (permalink)
Member: 1655844
Thanks Meter: 25
Unlock this device is easy no needed special Knowledge to unlock this device... First tick OEM unlock, Unlock Bootloader, Flash TWRP, Boot to Bootloader, Reboot Recovery, in TWRP do a S-OFF, Copy Special/IMEI tab HTC Desire 530, Power off phone, Insert Clip in phone, Power on phone using Volume up and power 5 seconds, realease power button, but volume up pressed, phone enter to mode Diag after that the phone reboot automatically and you phone is unlock sim card done...
The Following 6 Users Say Thank You to mynos For This Useful Post:
Old 03-23-2017, 23:02   #6 (permalink)
Member: 241855
Sonork: 1623913
Thanks Meter: 89
Phone S-OFF is DONE
" Chosen_item 2
Picture Attached
LITTLE MASTER
same issue even after repair and format file system and i tried sprint tab nothing worked
The Following User Says Thank You to olubolajames For This Useful Post:
Old 03-23-2017, 23:14   #7 (permalink)
Member: 1205146
Thanks Meter: 879
My problem was solved.
The Memory Chip we insert inside the phone was not going in properly.
I changed that strip and redone whole procedure , It worked like Charm.
So I suggest you to change this strip and MAKE SURE its going 100% inside the phone .
LITTLE MASTER
Old 03-27-2017, 10:33   #8 (permalink)
Member: 281857
Thanks Meter: 214
LITTLE MASTER
I think you r wright because was change old orignal strip with new one and found its not work with many phones
Old 03-29-2017, 12:37   #9 (permalink)
Member: 241855
Sonork: 1623913
Thanks Meter: 89
LITTLE MASTER
i don't think it's the strips i have change to over 4 new once but still same error i guess the unlock still has a little bug maybe in next update xclip should check well.
The Following 2 Users Say Thank You to olubolajames For This Useful Post:
Old 03-31-2017, 07:10   #10 (permalink)
Member: 1205146
Thanks Meter: 879
I just unlocked 6 pcs more , there is no problem at all.
LITTLE MASTER
Old 04-03-2017, 23:50   #11 (permalink)
MiRoOo's Avatar
Member: 594436
Sonork: 100.1657777
Thanks Meter: 952
Ok, I've been facing the exact same issue, i tried almost every Flex i have but nothing changed, same problem,
After all, i tried to go another way, software unlock, then i found this thread,
Which is for 626 but it works on 530 without a single change,
You may want to give it a try,
Solution tested by me, and everything is working great,
My phone was locked at T-Mobile if you should know,
Best Regards
Old 04-13-2017, 18:21   #12 (permalink)
Member: 241855
Sonork: 1623913
Thanks Meter: 89
Originally Posted by little_master View Post
i just unlocked 6 pcs more , there is no problem at all.
little master
i just got new srips and still same error i tried 3 new once pls whats really wrong
Old 04-14-2017, 12:39   #13 (permalink)
Member: 2416253
Thanks Meter: 4,162
Repair filesystem of your clip also.
Old 09-17-2017, 14:15   #14 (permalink)
.:MobileLife:.'s Avatar
Member: 188260
Sonork: 100.1590438
Thanks Meter: 428
Hello,
Nice support worked for me
The Following User Says Thank You to .:MobileLife:. For This Useful Post:
Old 08-24-2018, 00:08   #15 (permalink)
Member: 1488472
Thanks Meter: 17
I have this problem
Page generated in 0.29686 seconds with 9 queries
