htc desire 650 frp remove please help eading information... Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 3.0.U205611@61117G (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 1.02.401.3 (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: FA73V1200052 (bootloader) imei: 3551260821xxxx (bootloader) imei2: 3551950000xxx (bootloader) meid: 00000000000000 (bootloader) product: a17_uhl (bootloader) platform: hTCBmsm8226 (bootloader) modelid: 2PYR12000 (bootloader) cidnum: HTC__034 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: RUU (bootloader) commitno-bootloader: f36e56e3 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! Starting FRP unlock procedure Phone detected, reading token... Flashing cannot be done in this mode, please reboot to RUU mode (use RUU button) and repeat flashing! Error: Unexpected token format (1): ... (bootloader) INFO< Please cut following message > (bootloader) INFO<<<< Identifier Token Start >>>> (bootloader) INFO57463454F595E18B6F7CFA05448F04E5 (bootloader) INFO15530D9D584EDE34B0DE21094E9B29B1 (bootloader) INFO1321E54C84357556A588EA618B6A4CD6 (bootloader) INFOD4DD585538870F2558D3131E45FB2F83 (bootloader) INFO8EFE445B648705A2F52C243A781BD058 (bootloader) INFO61E54903DCDDE7B182288166498D43A9 (bootloader) INFO81D0CA7B99E575C85374C99A24E80F4F (bootloader) INFOD65AB158976428140734306DB9506295 (bootloader) INFOC1CD235FFD472876672183534F803C8F (bootloader) INFO42D68F99790B87A3AF96B88B636DBE1A (bootloader) INFO777FC53120E01FCFF1221EDA86E767D7 (bootloader) INFOFA592112D424450D64EB552BBFA5A9D4 (bootloader) INFO580EFD7E17E7177BED8AF3170BE0C597 (bootloader) INFO5BABABB3E573BA892B0A0EEADCA2CBFC (bootloader) INFO397D72065449FEB1DBA0DCA887F6F665 (bootloader) INFO1A7115A780A83BE2589ED104EFF3361F (bootloader) INFO<<<<< Identifier Token End >>>>> OKAY Execution time is 23(ms) any steps ? |
did u try this http://forum.gsmhosting.com/vbb/12707463-post293.html |
Hi, In case of problems you may also contact me on skype: xtc2clip I will manually process your bootloader unlock. |
matter of seconds with xtc2 clip.insert xtc clip in sd slot of phone reboot in factory reset mode do factory reset and done.great tool for htc. |
Do you refer to Desire 650 or other model? It should be FRP-free after this method. |
Yes I am asking about frp unlock for desire 650. Do I need to write anything on the xtc sd card? 从我的 iPhone 发送,使用 Tapatalk |
Also possible: 1) Reflash phone 2) Use FRP tab to remove it. |
Ok I try to reflash phone then do it one more time. As after factory reset, it still asked for google account. 从我的 iPhone 发送,使用 Tapatalk |
