Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > xtc2cliP
Old 11-06-2017, 17:03   #1 (permalink)
IM8
Member: 694535
Thanks Meter: 59
htc desire 650 frp remove please help
eading information...
Using Fastboot mode...
Reading common information
(bootloader) version: 0.5
(bootloader) version-bootloader: 3.19.0.0000
(bootloader) version-baseband: [email protected]
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main: 1.02.401.3
(bootloader) version-misc: PVT SHIP S-ON
(bootloader) serialno: FA73V1200052
(bootloader) imei: 3551260821xxxx
(bootloader) imei2: 3551950000xxx
(bootloader) meid: 00000000000000
(bootloader) product: a17_uhl
(bootloader) platform: hTCBmsm8226
(bootloader) modelid: 2PYR12000
(bootloader) cidnum: HTC__034
(bootloader) battery-status: good
(bootloader) battery-voltage: 0mV
(bootloader) partition-layout: Generic
(bootloader) security: on
(bootloader) build-mode: SHIP
(bootloader) boot-mode: RUU
(bootloader) commitno-bootloader: f36e56e3
(bootloader) hbootpreupdate: 11
(bootloader) gencheckpt: 0
all: Done!
Starting FRP unlock procedure
Phone detected, reading token...
Flashing cannot be done in this mode, please reboot to RUU mode (use RUU button) and repeat flashing!
Error: Unexpected token format (1): ... (bootloader) INFO< Please cut following message >
(bootloader) INFO<<<< Identifier Token Start >>>>
(bootloader) INFO57463454F595E18B6F7CFA05448F04E5
(bootloader) INFO15530D9D584EDE34B0DE21094E9B29B1
(bootloader) INFO1321E54C84357556A588EA618B6A4CD6
(bootloader) INFOD4DD585538870F2558D3131E45FB2F83
(bootloader) INFO8EFE445B648705A2F52C243A781BD058
(bootloader) INFO61E54903DCDDE7B182288166498D43A9
(bootloader) INFO81D0CA7B99E575C85374C99A24E80F4F
(bootloader) INFOD65AB158976428140734306DB9506295
(bootloader) INFOC1CD235FFD472876672183534F803C8F
(bootloader) INFO42D68F99790B87A3AF96B88B636DBE1A
(bootloader) INFO777FC53120E01FCFF1221EDA86E767D7
(bootloader) INFOFA592112D424450D64EB552BBFA5A9D4
(bootloader) INFO580EFD7E17E7177BED8AF3170BE0C597
(bootloader) INFO5BABABB3E573BA892B0A0EEADCA2CBFC
(bootloader) INFO397D72065449FEB1DBA0DCA887F6F665
(bootloader) INFO1A7115A780A83BE2589ED104EFF3361F
(bootloader) INFO<<<<< Identifier Token End >>>>>
OKAY
Execution time is 23(ms)
any steps ?
Old 11-07-2017, 14:48   #2 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,041
did u try this
Success stories :)
Old 11-07-2017, 16:28   #3 (permalink)
Member: 2416253
Thanks Meter: 3,656
Hi,
In case of problems you may also contact me on skype: xtc2clip
I will manually process your bootloader unlock.
Old 01-13-2018, 13:12   #4 (permalink)
Member: 811049
Thanks Meter: 9
matter of seconds with xtc2 clip.insert xtc clip in sd slot of phone reboot in factory reset mode do factory reset and done.great tool for htc.
The Following User Says Thank You to Mian Jahangir I For This Useful Post:
Old 01-21-2018, 07:45   #5 (permalink)
Member: 721542
Thanks Meter: 46
its still locked by that way.
Old 01-21-2018, 12:47   #6 (permalink)
Member: 2416253
Thanks Meter: 3,656
Hello,
Do you refer to Desire 650 or other model?
It should be FRP-free after this method.
Old 01-21-2018, 13:02   #7 (permalink)
Member: 721542
Thanks Meter: 46
Yes I am asking about frp unlock for desire 650. Do I need to write anything on the xtc sd card?
从我的 iPhone 发送,使用 Tapatalk
Old 01-21-2018, 13:53   #8 (permalink)
Member: 2416253
Thanks Meter: 3,656
No, no need, with clip connected you will have "factory reset" option, and this should reset FRP.
Also possible:
1) Reflash phone
2) Use FRP tab to remove it.
Old 01-21-2018, 21:45   #9 (permalink)
Member: 721542
Thanks Meter: 46
Ok I try to reflash phone then do it one more time. As after factory reset, it still asked for google account.
Old 01-22-2018, 06:25   #10 (permalink)
Member: 721542
Thanks Meter: 46
Also possible:
1) Reflash phone
it works after i reflash it, thanks
Page generated in 0.29050 seconds with 7 queries
