10-07-2018, 13:47 | #1 (permalink) |
Freak Poster Join Date: Jan 2017
Member: 2674678 Status: Offline Thanks Meter: 17 | HTC m8_ul Reading information... Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 1.29.214500021.12G (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 6.12.401.4 (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: SH45BWM02058 (bootloader) imei: 35787 (bootloader) imei2: Not Support (bootloader) meid: 00000000000000 (bootloader) product: m8_ul (bootloader) platform: hTCBmsm8974 (bootloader) modelid: 0P6B10000 (bootloader) cidnum: HTC__102 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 76df2b54 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! Execution time is 15(ms) Reading CID information ... (bootloader) cid: HTC__102 OKAY Execution time is 15(ms) Reading MEID information ... (bootloader) meid: 00000000000000 OKAY Execution time is 15(ms) Reading IMEI1 information ... (bootloader) imei: 35787 OKAY Execution time is 0(ms) Reading IMEI2 information ... (bootloader) readimei2: Not Support OKAY Execution time is 15(ms) Reading secure flag information ... (bootloader) secure_flag: 1 OKAY Execution time is 15(ms) Reading serial number information ... (bootloader) [ERR] Command error !!! OKAY Execution time is 15(ms) Read information completed. Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 1 (bootloader) m8_init_sd, SD card already power on (bootloader) [SPEW] GPIO 0 status is 0 (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: -16777216 (bootloader) erase_grpmult: 261078040 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) writesecureflag: KeyCard remain count 10000 (bootloader) PID:272 (bootloader) Start Verify: 1 (bootloader) [PGFS] partition_update_pgfs: pg1fs_security (bootloader) TZ_HTC_SVC_ENC ret = 0 (bootloader) [PGFS] partition_update_pgfs: pg2fs_sec_recovery OKAY Execution time is 5(s) Operation finished neither direct mode or sd mode. |
10-07-2018, 18:20 | #5 (permalink) |
Member: 2674678 Status: Offline Thanks Meter: 17 | And in Phone Softwarenumber is from t-mobile, but today I flashes a ruu 6.12.401.4 https://ibb.co/dbxtW9 And can't boot to recovery. |
10-08-2018, 13:31 | #6 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | |
10-08-2018, 13:32 | #7 (permalink) | |
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
10-08-2018, 14:39 | #8 (permalink) |
Member: 2674678 Status: Offline Thanks Meter: 17 | https://ibb.co/nmKUOpi flashed twrp recovery and got this error, and instaled a custom rom. i tryed with another HTC m8 and s-off works perfectly with direct mode. |
10-08-2018, 19:06 | #9 (permalink) |
Member: 2674678 Status: Offline Thanks Meter: 17 | i flashed 0P6BIMG_M8_UL_M60_SENSE70_MR_TMO_DE_6.12.111.4_Rad io_1.29.214500021.12G_20.72.4196t.01_F_release_460 604_signed_2_4. no recovery and the log Starting flash process... target rom version: 6.12.111.4 found large-zip header, file count: 6 processing file 1/6... sending 'zip' (53966 KB)... OKAY [ 2.383s] writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) signature checking... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) radio_batt_level: NOT IMPLEMENTED! (bootloader) SecuritySDInit: counter = 1 (bootloader) m8_init_sd, SD card already power on (bootloader) [SPEW] GPIO 0 status is 1 (bootloader) [SD_ERR] No sd card inserted! (bootloader) Smart SD detect failed so disable detect (bootloader) [JAVACARD_ERR] SD/USBDISK Init error (bootloader) g_cKeyCardSecurityLevel=[255] (bootloader) zip header checking... (bootloader) zip info parsing... (bootloader) checking model ID... (bootloader) checking custom ID... (bootloader) checking main version... (bootloader) [INFO] CheckMainVer: image_main_version[6.12.111.4] (bootloader) [INFO] CheckMainVer: setting_main_version[6.12.401.4] (bootloader) Version String: 6.12.111.4 (bootloader) extraction: 111 (bootloader) Version String: 6.12.401.4 (bootloader) extraction: 401 (bootloader) checking hboot version... (bootloader) Version String: 6.12.401.4 (bootloader) extraction: 401 (bootloader) CheckZipHbootVer in... (bootloader) CheckHbootPlatform: device pid: 272 (bootloader) CheckHbootPlatform: target-image platform accepted (bootloader) [INFO] CheckHbootVer: image_hboot_version[3.19.0.0000] (bootloader) [INFO] CheckHbootVer: setting_hboot_version[3.19.0.0000] (bootloader) [INFO] CheckHbootVer: image_hboot_version[3.19.0.0000] (bootloader) [INFO] CheckHbootVer: setting_hboot_version[3.19.0.0000] (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 Processing [hboot], please wait... (bootloader) CheckHbootPlatform: device pid: 272 (bootloader) CheckHbootPlatform: target-image platform accepted (bootloader) total_image_number=8 Processing [hboot], please wait... (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) ...... Successful (bootloader) current_image_number=0 (bootloader) current_image_number=1 (bootloader) current_image_number=2 (bootloader) current_image_number=3 (bootloader) current_image_number=4 (bootloader) current_image_number=5 (bootloader) current_image_number=6 (bootloader) current_image_number=7 FAILED (remote: 90 hboot pre-update! please flush image again immediately) finished. total time: 6.892s preupdate done, rebooting... Phone DISconnected Phone connected [SH45BWM02058] *** Fastboot mode resending command... sending 'zip' (53966 KB)... OKAY [ 2.517s] writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) signature checking... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) radio_batt_level: NOT IMPLEMENTED! (bootloader) SecuritySDInit: counter = 1 (bootloader) m8_init_sd, SD card already power on (bootloader) [SPEW] GPIO 0 status is 1 (bootloader) [SD_ERR] No sd card inserted! (bootloader) Smart SD detect failed so disable detect (bootloader) [JAVACARD_ERR] SD/USBDISK Init error (bootloader) g_cKeyCardSecurityLevel=[255] (bootloader) zip header checking... (bootloader) zip info parsing... (bootloader) checking model ID... (bootloader) checking custom ID... (bootloader) checking main version... (bootloader) [INFO] CheckMainVer: image_main_version[6.12.111.4] (bootloader) [INFO] CheckMainVer: setting_main_version[6.12.401.4] (bootloader) Version String: 6.12.111.4 (bootloader) extraction: 111 (bootloader) Version String: 6.12.401.4 (bootloader) extraction: 401 (bootloader) checking hboot version... (bootloader) Version String: 6.12.401.4 (bootloader) extraction: 401 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) total_image_number=17 Processing [sbl1], please wait... (bootloader) [INFO] Image[sbl1] size: 316538 (bootloader) [INFO] Extracting image[sbl1] 0-100% (bootloader) [INFO] Writing partition[sbl1] 0%-100% (bootloader) Start Verify: 0 (bootloader) signature checking... (bootloader) TZ_HTC_SVC_VERIFY_BOOTLOADER ret = 0 (bootloader) ...... Successful (bootloader) current_image_number=0 Processing [sbl1], please wait... (bootloader) [INFO] Image[sbl1] size: 316538 (bootloader) [INFO] Extracting image[sbl1] 0-100% (bootloader) [INFO] Writing partition[sbl1] 0%-100% (bootloader) Start Verify: 0 (bootloader) signature checking... (bootloader) TZ_HTC_SVC_VERIFY_BOOTLOADER ret = -1 (bootloader) verified fail (bootloader) ..... Bypassed (bootloader) current_image_number=1 Processing [sbl1], please wait... (bootloader) [INFO] Image[sbl1] size: 316538 (bootloader) [INFO] Extracting image[sbl1] 0-100% (bootloader) [INFO] Writing partition[sbl1] 0%-100% (bootloader) Start Verify: 0 (bootloader) signature checking... (bootloader) TZ_HTC_SVC_VERIFY_BOOTLOADER ret = -1 (bootloader) verified fail (bootloader) ..... Bypassed (bootloader) current_image_number=2 Processing [sdi], please wait... (bootloader) [INFO] Image[sdi] size: 11770 (bootloader) [INFO] Extracting image[sdi] 0-100% (bootloader) [INFO] Writing partition[sdi] 0%-100% (bootloader) Start Verify: 0 (bootloader) ...... Successful (bootloader) current_image_number=3 Processing [rpm], please wait... (bootloader) [INFO] Image[rpm] size: 194816 (bootloader) [INFO] Extracting image[rpm] 0-100% (bootloader) [INFO] Writing partition[rpm] 0%-100% (bootloader) Start Verify: 0 (bootloader) ...... Successful (bootloader) current_image_number=4 Processing [boot], please wait... (bootloader) [INFO] Image[boot] size: 10340608 (bootloader) [INFO] Extracting image[boot] 0-100% (bootloader) [INFO] Writing partition[boot] 0%-100% (bootloader) Start Verify: 0 (bootloader) ...... Successful (bootloader) current_image_number=5 Processing [recovery], please wait... (bootloader) [INFO] Image[recovery] size: 18831616 (bootloader) [INFO] Extracting image[recovery] 0-100% (bootloader) [INFO] Writing partition[recovery] 0%-100% (bootloader) Start Verify: 0 (bootloader) ...... Successful (bootloader) current_image_number=6 Processing [adsp], please wait... (bootloader) [INFO] Image[adsp] size: 9614336 (bootloader) [INFO] Extracting image[adsp] 0-100% (bootloader) [INFO] Writing partition[adsp] 0%-100% (bootloader) Start Verify: 0 (bootloader) ...... Successful (bootloader) current_image_number=7 Processing [wcnss], please wait... (bootloader) [INFO] Image[wcnss] size: 4592640 (bootloader) [INFO] Extracting image[wcnss] 0-100% (bootloader) [INFO] Writing partition[wcnss] 0%-100% (bootloader) Start Verify: 0 (bootloader) ...... Successful (bootloader) current_image_number=8 Processing [tz], please wait... (bootloader) [INFO] Image[tz] size: 366426 (bootloader) [INFO] Extracting image[tz] 0-100% (bootloader) [INFO] Writing partition[tz] 0%-100% (bootloader) Start Verify: 0 (bootloader) ...... Successful (bootloader) current_image_number=9 Processing [pg2fs_spcustom], please wait... (bootloader) [INFO] Image[pg2fs_spcustom] size: 4188160 (bootloader) [INFO] Extracting image[pg2fs_spcustom] 0-100% (bootloader) [INFO] Writing partition[pg2fs_spcustom] 0%-100% (bootloader) [PGFS] partition_update_pgfs: pg2fs_spcustom (bootloader) ...... Successful (bootloader) current_image_number=10 Processing [sensor_hub], please wait... (bootloader) [INFO] Image[sensor_hub] size: 209760 (bootloader) [INFO] Extracting image[sensor_hub] 0-100% (bootloader) [INFO] Writing partition[sensor_hub] 0%-100% (bootloader) Start Verify: 0 (bootloader) Continue to update Sensor hub FW, return value = -2 (bootloader) ...... Successful (bootloader) current_image_number=11 Processing [tp], please wait... (bootloader) [INFO] Image[tp] size: 95772 (bootloader) [INFO] Extracting image[tp] 0-100% (bootloader) [INFO] Writing partition[tp] 0%-100% (bootloader) Start Verify: 0 (bootloader) [TP]<2>This firmware is not for us, bypass (bootloader) ..... Bypassed (bootloader) current_image_number=12 Processing [tp], please wait... (bootloader) [INFO] Image[tp] size: 95767 (bootloader) [INFO] Extracting image[tp] 0-100% (bootloader) [INFO] Writing partition[tp] 0%-100% (bootloader) Start Verify: 0 (bootloader) [TP]The firmware version are the same, bypass update: On-chi (bootloader) p: 1594356, Img: 1594356 (bootloader) ..... Bypassed (bootloader) current_image_number=13 Processing [sp1], please wait... (bootloader) [INFO] Image[sp1] size: 4194304 (bootloader) [INFO] Extracting image[sp1] 0-100% (bootloader) [INFO] Writing partition[sp1] 0%-100% (bootloader) Start Verify: 0 (bootloader) ...... Successful (bootloader) current_image_number=14 Processing [radio], please wait... (bootloader) [INFO] Image[radio] size: 46834688 (bootloader) [INFO] Extracting image[radio] 0-100% (bootloader) [INFO] Writing partition[radio] 0%-100% (bootloader) Start Verify: 0 (bootloader) trying to rename MBA (bootloader) Skip: MODEM B14 (bootloader) Skip: MODEM B08 (bootloader) Skip: MODEM B16 (bootloader) Skip: MODEM B01 (bootloader) Skip: MODEM MDT (bootloader) Skip: MODEM B25 (bootloader) Skip: MODEM B15 (bootloader) Skip: MODEM B13 (bootloader) Skip: MODEM B21 (bootloader) Skip: MODEM B11 (bootloader) Skip: MODEM B17 (bootloader) Skip: MODEM B26 (bootloader) Skip: MODEM B04 (bootloader) Skip: MODEM B27 (bootloader) Skip: MODEM B20 (bootloader) Skip: MODEM B19 (bootloader) Skip: MODEM B10 (bootloader) Skip: MODEM B18 (bootloader) Skip: MODEM B02 (bootloader) Skip: MODEM B22 (bootloader) Skip: MODEM B03 (bootloader) Skip: MODEM B05 (bootloader) Skip: MODEM B00 (bootloader) MBA file: (25)A7B80E1 B00 found (bootloader) MBA file: (26)A7B80E1 MDT found (bootloader) MBA file: (27)A7B40E1 MDT found (bootloader) MBA file: (28)A7BC0E1 MDT found (bootloader) MBA file: (29)A7BC0E1 B00 found (bootloader) MBA file: (30)A7B40E1 B00 found (bootloader) Skip: MDATA CFG (bootloader) Skip: UDATA CFG (bootloader) Skip: RADIOVERCFG (bootloader) Rename(0) 7B80E1.B00 to MBA.B00 successed (bootloader) Rename(1) 7B80E1.MDT to MBA.MDT successed (bootloader) renameMBAInRadio: 0 (bootloader) Erase modem_st1/modem_st2 due to radio image update! (bootloader) ...... Successful (bootloader) current_image_number=15 Processing [rcdata], please wait... (bootloader) [INFO] Image[rcdata] size: 185 (bootloader) [INFO] Extracting image[rcdata] 0-100% (bootloader) [INFO] Writing partition[rcdata] 0%-100% (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) Erase modem_st1/modem_st2 due to rfg_1 image update (bootloader) ...... Successful (bootloader) current_image_number=16 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 OKAY [ 67.511s] finished. total time: 70.028s processing file 2/6... sending 'zip' (510888 KB)... OKAY [ 15.630s] writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) signature checking... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) radio_batt_level: NOT IMPLEMENTED! (bootloader) [JAVACARD_ERR] SD/USBDISK Init error (bootloader) g_cKeyCardSecurityLevel=[255] (bootloader) zip header checking... (bootloader) zip info parsing... (bootloader) checking model ID... (bootloader) checking custom ID... (bootloader) checking main version... (bootloader) [INFO] CheckMainVer: image_main_version[6.12.111.4] (bootloader) [INFO] CheckMainVer: setting_main_version[6.12.111.4] (bootloader) Version String: 6.12.111.4 (bootloader) extraction: 111 (bootloader) Version String: 6.12.111.4 (bootloader) extraction: 111 (bootloader) checking hboot version... (bootloader) Version String: 6.12.111.4 (bootloader) extraction: 111 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) total_image_number=1 Processing [system], please wait... (bootloader) [INFO] Image[system] size: 838860800 (bootloader) [INFO] Extracting image[system] 0-100% (bootloader) [INFO] Writing partition[system] 0%-100% (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) ...... Successful (bootloader) current_image_number=0 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 OKAY [ 56.164s] finished. total time: 71.794s processing file 3/6... sending 'zip' (554593 KB)... OKAY [ 16.939s] writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) signature checking... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) radio_batt_level: NOT IMPLEMENTED! (bootloader) [JAVACARD_ERR] SD/USBDISK Init error (bootloader) g_cKeyCardSecurityLevel=[255] (bootloader) zip header checking... (bootloader) zip info parsing... (bootloader) checking model ID... (bootloader) checking custom ID... (bootloader) checking main version... (bootloader) [INFO] CheckMainVer: image_main_version[6.12.111.4] (bootloader) [INFO] CheckMainVer: setting_main_version[6.12.111.4] (bootloader) Version String: 6.12.111.4 (bootloader) extraction: 111 (bootloader) Version String: 6.12.111.4 (bootloader) extraction: 111 (bootloader) checking hboot version... (bootloader) Version String: 6.12.111.4 (bootloader) extraction: 111 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) total_image_number=1 Processing [system], please wait... (bootloader) [INFO] Image[system] size: 838860800 (bootloader) [INFO] Extracting image[system] 0-100% (bootloader) [INFO] Writing partition[system] 0%-100% (bootloader) Start Verify: 0 (bootloader) ...... Successful (bootloader) current_image_number=0 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 OKAY [ 56.581s] finished. total time: 73.520s processing file 4/6... sending 'zip' (408798 KB)... OKAY [ 12.481s] writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) signature checking... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) radio_batt_level: NOT IMPLEMENTED! (bootloader) [JAVACARD_ERR] SD/USBDISK Init error (bootloader) g_cKeyCardSecurityLevel=[255] (bootloader) zip header checking... (bootloader) zip info parsing... (bootloader) checking model ID... (bootloader) checking custom ID... (bootloader) checking main version... (bootloader) [INFO] CheckMainVer: image_main_version[6.12.111.4] (bootloader) [INFO] CheckMainVer: setting_main_version[6.12.111.4] (bootloader) Version String: 6.12.111.4 (bootloader) extraction: 111 (bootloader) Version String: 6.12.111.4 (bootloader) extraction: 111 (bootloader) checking hboot version... (bootloader) Version String: 6.12.111.4 (bootloader) extraction: 111 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) total_image_number=1 Processing [system], please wait... (bootloader) [INFO] Image[system] size: 838860800 (bootloader) [INFO] Extracting image[system] 0-100% (bootloader) [INFO] Writing partition[system] 0%-100% (bootloader) Start Verify: 0 (bootloader) ...... Successful (bootloader) current_image_number=0 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 OKAY [ 47.914s] finished. total time: 60.395s processing file 5/6... sending 'zip' (287 KB)... OKAY [ 0.215s] writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) signature checking... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) radio_batt_level: NOT IMPLEMENTED! (bootloader) [JAVACARD_ERR] SD/USBDISK Init error (bootloader) g_cKeyCardSecurityLevel=[255] (bootloader) zip header checking... (bootloader) zip info parsing... (bootloader) checking model ID... (bootloader) checking custom ID... (bootloader) checking main version... (bootloader) [INFO] CheckMainVer: image_main_version[6.12.111.4] (bootloader) [INFO] CheckMainVer: setting_main_version[6.12.111.4] (bootloader) Version String: 6.12.111.4 (bootloader) extraction: 111 (bootloader) Version String: 6.12.111.4 (bootloader) extraction: 111 (bootloader) checking hboot version... (bootloader) Version String: 6.12.111.4 (bootloader) extraction: 111 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) total_image_number=1 Processing [system], please wait... (bootloader) [INFO] Image[system] size: 301989888 (bootloader) [INFO] Extracting image[system] 0-100% (bootloader) [INFO] Writing partition[system] 0%-100% (bootloader) Start Verify: 0 (bootloader) ...... Successful (bootloader) current_image_number=0 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 OKAY [ 8.232s] finished. total time: 8.447s processing file 6/6... sending 'zip' (53726 KB)... OKAY [ 2.522s] writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) signature checking... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) radio_batt_level: NOT IMPLEMENTED! (bootloader) [JAVACARD_ERR] SD/USBDISK Init error (bootloader) g_cKeyCardSecurityLevel=[255] (bootloader) zip header checking... (bootloader) zip info parsing... (bootloader) checking model ID... (bootloader) checking custom ID... (bootloader) checking main version... (bootloader) [INFO] CheckMainVer: image_main_version[6.12.111.4] (bootloader) [INFO] CheckMainVer: setting_main_version[6.12.111.4] (bootloader) Version String: 6.12.111.4 (bootloader) extraction: 111 (bootloader) Version String: 6.12.111.4 (bootloader) extraction: 111 (bootloader) checking hboot version... (bootloader) Version String: 6.12.111.4 (bootloader) extraction: 111 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) total_image_number=2 Processing [dzdata], please wait... (bootloader) [INFO] Image[dzdata] size: 28230480 (bootloader) [INFO] Extracting image[dzdata] 0-100% (bootloader) [INFO] Writing partition[dzdata] 0%-100% (bootloader) Start Verify: 0 (bootloader) ...... Successful (bootloader) current_image_number=0 Processing [boot], please wait... (bootloader) [INFO] Image[boot] size: 10340608 (bootloader) [INFO] Extracting image[boot] 0-100% (bootloader) [INFO] Writing partition[boot] 0%-100% (bootloader) Start Verify: 0 (bootloader) ...... Successful (bootloader) current_image_number=1 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 (bootloader) Start Verify: 0 OKAY [ 11.940s] finished. total time: 14.462s rompack updated HBoot pre-update sequence Flash process completed. |
