Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 07-02-2015, 10:25   #1 (permalink)
Member: 1222089
Sonork: 100.1583019
Thanks Meter: 2,688
Thumbs up GUIDE: HTC Desire C CID Change SD Mode With XTC2clip
How to Use SD mode
Connect Xtc2clip to computer using good Sd card Reader , once your computer detect the removeable disk in my computer , Open xtc2clip tools, press SD Editor, Tick CID & Enter CID and Press Save to Drive ., When Setting done ., Remove XTC2clip from Computer ., Connect Xtc2clip MicroSD Flex Connector and insert in your Phone ., and phone in Bootloader mode by Pressing (Volume Down + power Button ) than Select Simlock Option in it
Here the Some Screenshots
The Following User Says Thank You to Smart-gsm For This Useful Post:
Old 07-02-2015, 10:38   #2 (permalink)
Member: 2111288
Sonork: 12345
Thanks Meter: 16
TNX to share log BR
share log other ...
TNX
BR Farzam
The Following User Says Thank You to farzam7 For This Useful Post:
Old 07-14-2015, 10:26   #3 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,063
htc one v
i did same but in bootloader not showing cid 11111111 ?
Old 07-14-2015, 11:00   #4 (permalink)
Member: 2416253
Thanks Meter: 4,162
Originally Posted by maplegsm View Post
htc one v
CID is displayed in S-OFF only.
Old 07-14-2015, 11:31   #5 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,063
showing S-OFF .....;(
Old 07-14-2015, 11:48   #6 (permalink)
Member: 2416253
Thanks Meter: 4,162
So what's the problem at all? Some hboots may not show CID, some may.
Does your phone shows the CID you want when reading phone information?
Or does your customer require to have his CID shown in boot mode?
Old 07-14-2015, 12:29   #7 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,063
ok i need its stock rom i checked but not found ant stock rom link
and second thing is y software is not detecting the set ?
Old 07-15-2015, 10:59   #8 (permalink)
Member: 2416253
Thanks Meter: 4,162
Are you using Windows 8? I found out with one customer that the detection may fail on some Windows 8 systems.
The Following 4,294,967,295 Users Say Thank You to xtc2clip For This Useful Post:
Old 07-22-2015, 15:36   #9 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,063
Question
winxp but facing this problem
Old 07-22-2015, 15:41   #10 (permalink)
Member: 2416253
Thanks Meter: 4,162
I have seen yesterday a customer "facing this problem" which turned out to have wrong drivers installed.
If you want I can check via teamviewer.
Old 10-02-2015, 12:45   #11 (permalink)
Member: 2417766
Thanks Meter: 2
hello anytime i try to copy the files for htc 626s to clip it says wrong volume in drive e insert volume into drive e
Old 12-16-2015, 18:27   #12 (permalink)
Member: 2093446
Thanks Meter: 4
in bootloader when i go to simlock it shows " sd init fail" what is reason and solution?
tnx...
Old 12-16-2015, 19:52   #13 (permalink)
Member: 2416253
Thanks Meter: 4,162
tnx...
The reason is that your clip is not properly connected.
Please use appropriate threads next time. Your post will be deleted tomorrow.
Page generated in 0.20399 seconds with 8 queries
