11-06-2015, 14:21 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Ghana Age: 39
Member: 153893 Status: Offline Thanks Meter: 266 | Htc desire610 unlocked not done help me pls urgent needed thank u |
11-06-2015, 15:22 | #3 (permalink) | |
Member: 153893 Status: Offline Thanks Meter: 266 | Quote:
and here is the method i used ON software i select SD mode editor super CID 0-Security off(S-OFF) 0-Unlocked Save to drive Please connect phone in FASTBOOT (vol_down + pwr) OR powered ON (OS) mode to enable buttons, waiting for the phone ... Checking for new version... Phone DISconnected Great, you are using latest version! CID value has been set to super-cid. Please save to SD card and use in phone CID value has been set to super-cid. Please save to SD card and use in phone Writing information to service files on SD card... CID settings saved Security settings saved WARNING: No IMEI specified, sim-lock settings are not saved Done. ON phone HBOOT then select sim lock Done press v+ to reboot and i av use this method unlocked some before but i dont know why this 5pcs non cant unlocked and i got same complain from a frd | |
11-06-2015, 16:51 | #5 (permalink) | |
logs Writing information to service files on SD card... CID settings saved Security settings saved Sim-lock settings saved Done. Writing information to service files on SD card... pls any other solution | |
11-06-2015, 17:19 | #6 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
http://forum.gsmhosting.com/vbb/f961...ocess-1966745/ | |
11-10-2015, 10:41 | #7 (permalink) | |
Member: 153893 Status: Offline Thanks Meter: 266 | Quote: thank u | |
11-10-2015, 19:44 | #8 (permalink) |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Sorry, we cannot get "New" Desire 610, because we need to know the software version, etc. Full phone information. If you still have it - please provide. Also you didn't explain what is the problem - furthermore, if you would follow the lock procedure, your code would be reset. And since you was able to unlock it with original code - it means that the procedure didn't work for some reason, so if you can provide more information - we will be grateful and will check it for sure. |
11-11-2015, 12:21 | #9 (permalink) | |
Welcome to XTC 2 Clip! Web: XTC 2 Clip Email: [email protected] Support forum: xtc2cliP - GSM-Forum Please connect phone in FASTBOOT (vol_down + pwr) OR powered ON (OS) mode to enable buttons, waiting for the phone ... Checking for new version... Phone DISconnected Great, you are using latest version! CID value has been set to super-cid. Please save to SD card and use in phone CID value has been set to super-cid. Please save to SD card and use in phone Writing information to service files on SD card... CID settings saved Security settings saved Sim-lock settings saved Done. Phone logs trying to Unlocked *** locked *** A3_UL PVT SHIP S-ON HBOOT-3.19.0.0000 RADIO-1.101.1372.19.1121 OpenDSP-v28.2.2.00546.0331 os-1.53.502.12 eMMC-boot 1024MB Nov 27 2014,23:42:53.0 SIMLOCK SD init OK Open MCCMNC file fail Open CID file fail Open IMEI file fail Open atsdeb file fail Open SF file fail Open NAME file fail Check keycard failed Process done, reboot device? <VOL UP> Yes | |
11-11-2015, 14:21 | #10 (permalink) |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | As you see, the process was not successfull. Please check this: http://forum.gsmhosting.com/vbb/f961...ailed-1983030/ |
11-11-2015, 16:25 | #11 (permalink) | |
thankx once again for the help and quick reply | |
The Following User Says Thank You to godwin For This Useful Post: |
