12-14-2015, 14:45 | #16 (permalink) | |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
The Following User Says Thank You to xtc2clip For This Useful Post: |
12-15-2015, 21:34 | #17 (permalink) | |
Crazy Poster Join Date: Oct 2015 Location: Hungary
Member: 2472240 Status: Offline Thanks Meter: 6 | Quote:
Other device does not have this trouble. I do not understand what happened. Xtc2clip work properly! S-off and try another radio? | |
12-16-2015, 09:41 | #18 (permalink) | |
I tried the Direct Mode tab command as you can see in the picture, but I'm still getting (No sdcard supported) error message. I tried several times to reboot bootloader mode, etc .. but unfortunately no results. What can be wrong? What do you spoil? Thank you very much | |
12-18-2015, 04:17 | #22 (permalink) |
Freak Poster Join Date: Jul 2015
Member: 2424855 Status: Offline Thanks Meter: 17 | I experienced this case before on HTC One Sprint variant and that is baseband IC problem (hardware issue), even you try to write the IMEI, it cannot be detected in normal mode and no signal |
The Following User Says Thank You to hoang555 For This Useful Post: |
12-18-2015, 04:20 | #23 (permalink) |
12-18-2015, 04:26 | #24 (permalink) |
12-18-2015, 05:33 | #25 (permalink) |
Member: 2472240 Status: Offline Thanks Meter: 6 | Yes, hardware problems. In the meantime, I found a solution. The upper panel was damaged. I change up to another panel and it works perfectly. Xtc2clip work properly! Great tool! |
The Following User Says Thank You to szunyi77 For This Useful Post: |
12-18-2015, 12:25 | #27 (permalink) | |
Which I know helps! Other: Going back to the Y cable. So I did it. I hope you can help each other! It works great. (The USB port is connected to a charger for me .. but it works with a PC or Power bank also tried.) | |
12-22-2015, 10:14 | #30 (permalink) |
Member: 2472240 Status: Offline Thanks Meter: 6 | Hello So far there was no problem to open the ONE 7, but there is a machine and I can not open it. The SD card is displayed, but the following error continuously! The Clips contains the config.dat file, not the problem. Y cable is functioning correctly! I tried bootloader unlock-relock but no results. If you try the super Cid and S-off error can also stand above! What is wrong? |
