10-02-2016, 23:18 | #1 (permalink) |
Freak Poster Join Date: Feb 2015 Location: Syria-Aleppo
Member: 2346672 Status: Offline Sonork: 1671045 :Abdohurbli Thanks Meter: 25 | HTC M7_wls (bootloader) version: 0.5 (bootloader) version-bootloader: 1.55.5555 (bootloader) version-baseband: N/A (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 3.24.531.3 (bootloader) version-misc: UNKNOWN SHIP S-OFF (bootloader) serialno: FA35SS901094 (bootloader) imei: 355859056067488 (bootloader) meid: 99000146845583 (bootloader) product: m7_wls (bootloader) platform: HBOOT-8064 (bootloader) modelid: PN0720000/mbkp s1se=68 co-e'x0x (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 3789mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: dirty-412e361e (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! finished. total time: 0.206s I tried with This Firmware : PN07IMG_M7_WL_L50_SENSE60_SPCS_MR_Sprint_WWE_6.23. 651.7_R_Radio_1.01.20.1225_CNV_CNV_SPCS_4.38_003_r elease_447955_signed_2_4 But it keep Telling me this : Starting flash process... target rom version: 6.23.651.7 found large-zip header, file count: 5 processing file 1/5... sending 'zip' (46088 KB)... OKAY [ 2.835s] writing 'zip'... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... Error: If your phone is S-ON and bootloader is UNLOCKED you cannot flash this image. You should make S-OFF or lock/relock your bootloader FAILED (status read failed (Too many links)) finished. total time: 3.368s Flash process completed. Flash not successfull, reboot will not be done Even though that I tried with "CID 1111XXX" and Bootloader is reLocked ... What is the Mistake now ? where Should fine the Correct Flash Rom >? |
10-03-2016, 14:56 | #2 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Hello, You can't flash this rom directly, first you must flash partial flash. Also I would recommend to flash 3.xx.531.x version, reviwe the phone and then take OTA. |
The Following 2 Users Say Thank You to xtc2clip For This Useful Post: |
10-03-2016, 16:32 | #4 (permalink) |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Yes, search for "partial" on support and download it corresponding to your model. partial flashes are required to upgrade hboot in case of Android release update (e.g. 4.4->5, 5.x->6.x) |
10-03-2016, 17:05 | #5 (permalink) |
Member: 2346672 Status: Offline Sonork: 1671045 :Abdohurbli Thanks Meter: 25 | Thanks for Fast Replay Ok I get it I will search on Support (Even though it does't show This "Too large Image ") it's show Green bar then nth .. I will follow Your Steps ... thanks Again ! |
10-03-2016, 19:27 | #7 (permalink) |
Member: 2346672 Status: Offline Sonork: 1671045 :Abdohurbli Thanks Meter: 25 | yes sir, it also Failed ... The Same The Green Bar then Nth Show "No Error " This is the First Time I face Problem Like this .....Should I do something else ? Thanks for your Care And Respond |
