10-26-2015, 15:19 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: searching .... Age: 16
Member: 484060 Status: Offline Sonork: 100.1596821 Thanks Meter: 406 | HTC 816D All Test Report 1 Short Done By xtc2Clip All Test 1 Short Done By xtc2Clip Reading Info Code: Reading information... Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 1.31.50.1103 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 1.61.720.1 (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: FA48LMZ01266 (bootloader) imei: 3527950627xxxxx (bootloader) imei2: 3527950627xxxxx (bootloader) meid: A1000037D9AC70 (bootloader) product: a5_dwg (bootloader) platform: hTCBmsm8226 (bootloader) modelid: 0P9C51000 (bootloader) cidnum: HTC__038 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: be7179e5 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 Execution time is 15(ms) all: Done! Reading secure flag information ... (bootloader) secure_flag: 3 Execution time is 15(ms) OKAY Reading CID information ... (bootloader) cid: HTC__038 Execution time is 0(ms) OKAY Reading MEID information ... (bootloader) meid: A1000037Dxxxxx Execution time is 0(ms) OKAY Read information completed. Code: Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 3 (bootloader) a5dwg_init_sd, SD card already power on (bootloader) a5dwg_init_sd, SD card io already power on (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) clock_config_mmc: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) Decoded CSD fields: (bootloader) cmmc_structure: 0 (bootloader) card_cmd_class: 5f5 (bootloader) write_blk_len: 512 (bootloader) read_blk_len: 512 (bootloader) r2w_factor: 4 (bootloader) sector_size: 128 (bootloader) c_size_mult:2 (bootloader) c_size: 506 (bootloader) nsac_clk_cycle: 100 (bootloader) taac_ns: 70000 (bootloader) tran_speed: 26000 kbps (bootloader) erase_blk_len: 0 (bootloader) read_blk_misalign: 0 (bootloader) write_blk_misalign: 0 (bootloader) read_blk_partial: 1 (bootloader) write_blk_partial: 0 (bootloader) Card Capacity: 4153344 Bytes (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: 49152 (bootloader) erase_grpmult: 257380728 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) writesecureflag: KeyCard remain count 10000 (bootloader) PID:290 (bootloader) Start Verify: 3 (bootloader) [PGFS] partition_update_pgfs: pg1fs_security Execution time is 4187(ms) OKAY Operation finished Phone DISconnected Code: 10/26/2015 6:27:13 PM Operation finished 10/26/2015 6:27:17 PM Phone DISconnected 10/26/2015 6:27:22 PM Phone connected [FA48LMZ01266] *** Fastboot mode 10/26/2015 6:34:46 PM Sending oem writeimei 3555880477xxxxx 10/26/2015 6:34:47 PM ... (bootloader) Start Verify: 0 Execution time is 31(ms) Code: 10/26/2015 6:34:47 PM Operation finished 10/26/2015 6:34:52 PM Sending oem writeimei2 3555880477xxxxx 10/26/2015 6:34:52 PM ... (bootloader) Start Verify: 0 Execution time is 15(ms) write meid Code: 10/26/2015 6:34:52 PM Operation finished 10/26/2015 6:37:21 PM Sending oem writemeid A0000023Dxxxxx 10/26/2015 6:37:21 PM ... (bootloader) Start Verify: 0 Execution time is 15(ms) Code: Sending oem writecid 11111111 ... (bootloader) Start Verify: 0 (bootloader) Input CID is super CID (bootloader) Start Verify: 0 Execution time is 46(ms) OKAY Operation finished $ktelecom |
The Following User Says Thank You to $ktelecom For This Useful Post: |
