04-07-2016, 16:34 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Left out from our gsm field Age: 29
Member: 2386560 Status: Offline Sonork: NOW I DON'T USE IT Thanks Meter: 561 | HTC M8 supercid, s.off failed why???? HTC M8 supercid, s.off failed why???? Sending oem writesecureflag 0 ... (bootloader) [PGFS] partition_update_pgfs: pg1fs_security (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) Failed Reading block @ 2082 (bootloader) [SD_ERR] sd_read_sector: read sector failed (2082 2) (bootloader) [PG_ERROR] htc_pg_hdr_get(118): (bootloader) sd_read_sector error (bootloader) [PG_ERROR] htc_pg_part_hdr_get(170): (bootloader) htc_pg_hdr_get failed (bootloader) TZ_HTC_SVC_ENC ret = 0 (bootloader) [PGFS] partition_update_pgfs: pg2fs_sec_recovery (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) Failed Reading block @ 262656 (bootloader) [SD_ERR] sd_read_sector: read sector failed (262656 2) (bootloader) [PG_ERROR] htc_pg_hdr_get(118): (bootloader) sd_read_sector error (bootloader) [PG_ERROR] htc_pg_part_hdr_get(170): (bootloader) htc_pg_hdr_get failed (bootloader) Update pg2fs_sec_recovery fail (-1) Execution time is 10049(ms) OKAY Operation finished Sending oem writecid 11111111 ... (bootloader) Start Verify: 0 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) Failed Writing block @ 245728 (bootloader) [SD_ERR] sd_write_sector: write sector failed (245728 2) (bootloader) Input CID is super CID (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) Failed Reading block @ 786432 (bootloader) [SD_ERR] sd_read_sector: read sector failed (786432 256) (bootloader) [ERR] partition_read_emmc(589): error -1 (bootloader) Start Verify: 0 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) Failed Writing block @ 786432 (bootloader) [SD_ERR] sd_write_sector: write sector failed (786432 256) Execution time is 15056(ms) OKAY Operation finished rep must be |
04-07-2016, 17:08 | #2 (permalink) |
Freak Poster Join Date: Feb 2016 Location: karnataka, mysore
Member: 2528503 Status: Offline Sonork: 1670792 Thanks Meter: 70 | you cannot s-off directly for m8 you need y cable to s-off go to sd mode editor tab ,make super cid & s-off enable then save to drive then perform the operation via y cable |
04-07-2016, 18:58 | #3 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | M8 has SD slot, so it can be used with direct mode. Please do this: http://forum.gsmhosting.com/vbb/f961...t-etc-1964648/ and then repeat S-OFF. |
The Following User Says Thank You to xtc2clip For This Useful Post: |
04-07-2016, 19:57 | #4 (permalink) | |
Member: 2386560 Status: Offline Sonork: NOW I DON'T USE IT Thanks Meter: 561 | Quote:
04-07-2016, 20:02 | #5 (permalink) |
Member: 2386560 Status: Offline Sonork: NOW I DON'T USE IT Thanks Meter: 561 | Bro M8 supported to direct mode operation......who told u M8 not supported in directly mode.....1st read all post posted by xtc2clip clip ..... |
04-08-2016, 10:43 | #6 (permalink) |
Member: 2386560 Status: Offline Sonork: NOW I DON'T USE IT Thanks Meter: 561 | after file repair system also not sucess Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 2 (bootloader) m8whl_init_sd, SD card already power on (bootloader) [SPEW] GPIO 0 status is 0 (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: -16777216 (bootloader) erase_grpmult: 261078256 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) writesecureflag: KeyCard remain count 10000 (bootloader) PID:267 (bootloader) Start Verify: 3 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) Failed Writing block @ 245728 (bootloader) [SD_ERR] sd_write_sector: write sector failed (245728 2) (bootloader) [PGFS] partition_update_pgfs: pg1fs_security (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) Failed Reading block @ 2082 (bootloader) [SD_ERR] sd_read_sector: read sector failed (2082 2) (bootloader) [PG_ERROR] htc_pg_hdr_get(118): (bootloader) sd_read_sector error (bootloader) [PG_ERROR] htc_pg_part_hdr_get(170): (bootloader) htc_pg_hdr_get failed (bootloader) TZ_HTC_SVC_ENC ret = 0 (bootloader) [PGFS] partition_update_pgfs: pg2fs_sec_recovery Operation finished |
04-08-2016, 15:24 | #9 (permalink) | |
thanks sir 4 saving my time | |
The Following User Says Thank You to vickyjadhav6161 For This Useful Post: |
