Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > xtc2cliP
Old 10-07-2018, 13:47   #1 (permalink)
Member: 2674678
Thanks Meter: 16
HTC m8_ul
cant write s-off, only Secutity level 1 or Security level 2
Reading information...
Using Fastboot mode...
Reading common information
(bootloader) version: 0.5
(bootloader) version-bootloader: 3.19.0.0000
(bootloader) version-baseband: 1.29.214500021.12G
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main: 6.12.401.4
(bootloader) version-misc: PVT SHIP S-ON
(bootloader) serialno: SH45BWM02058
(bootloader) imei: 35787
(bootloader) imei2: Not Support
(bootloader) meid: 00000000000000
(bootloader) product: m8_ul
(bootloader) platform: hTCBmsm8974
(bootloader) modelid: 0P6B10000
(bootloader) cidnum: HTC__102
(bootloader) battery-status: good
(bootloader) battery-voltage: 0mV
(bootloader) partition-layout: Generic
(bootloader) security: on
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
(bootloader) commitno-bootloader: 76df2b54
(bootloader) hbootpreupdate: 11
(bootloader) gencheckpt: 0
all: Done!
Execution time is 15(ms)
Reading CID information
... (bootloader) cid: HTC__102
OKAY
Reading MEID information
... (bootloader) meid: 00000000000000
OKAY
Reading IMEI1 information
... (bootloader) imei: 35787
OKAY
Execution time is 0(ms)
Reading IMEI2 information
... (bootloader) readimei2: Not Support
OKAY
Reading secure flag information
... (bootloader) secure_flag: 1
OKAY
Reading serial number information
... (bootloader) [ERR] Command error !!!
OKAY
Read information completed.
Sending oem writesecureflag 0
... (bootloader) SecuritySDInit: counter = 1
(bootloader) m8_init_sd, SD card already power on
(bootloader) [SPEW] GPIO 0 status is 0
(bootloader) sdhci_open: id=0
(bootloader) Initializing MMC host data structure and clock!
(bootloader) mmc slot#2 clock enabled
(bootloader) sdhci_set_clock: slot 2, freq 192000000
(bootloader) GPLL0 is enabled
(bootloader) clock_update_cfg_sd is done
(bootloader) sd clock set done
(bootloader) sdhci_set_bus_width: bus width 0
(bootloader) sdhci_clk_supply: freq 400000
(bootloader) Error: Command never completed
(bootloader) Error: Command timeout error
(bootloader) Error: Command completed with errors
(bootloader) The response for CMD8 does not match the supplied value
(bootloader) Decoded CID fields:
(bootloader) Manufacturer ID: 7f
(bootloader) OEM ID: 0x0
(bootloader) Product Name: 5270
(bootloader) Product revision: 5.2
(bootloader) Product serial number: B4E
(bootloader) Manufacturing date: 2 2015
(bootloader) sdhci_clk_supply: freq 50000000
(bootloader) sdhci_set_bus_width: bus width 1
(bootloader) Done initialization of the card
(bootloader) erase_grpsize: -16777216
(bootloader) erase_grpmult: 261078040
(bootloader) wp_grpsize: 1
(bootloader) wp_grpen: 1
(bootloader) perm_wp: 0
(bootloader) temp_wp: 0
(bootloader) [Tuxera][Error] No exFAT partition found
(bootloader) writesecureflag: KeyCard remain count 10000
(bootloader) PID:272
(bootloader) Start Verify: 1
(bootloader) [PGFS] partition_update_pgfs: pg1fs_security
(bootloader) TZ_HTC_SVC_ENC ret = 0
(bootloader) [PGFS] partition_update_pgfs: pg2fs_sec_recovery
OKAY
Execution time is 5(s)
Operation finished
neither direct mode or sd mode.
Old 10-07-2018, 13:50   #2 (permalink)
Member: 2674678
Thanks Meter: 16
https://ibb.co/n3RKKU
Old 10-07-2018, 17:50   #3 (permalink)
Member: 2674678
Thanks Meter: 16
so whats wrong here ???
https://ibb.co/cBCP4U
Old 10-07-2018, 18:01   #4 (permalink)
Member: 2674678
Thanks Meter: 16
https://ibb.co/mHogjU
https://ibb.co/eyzyW9
https://ibb.co/chL5B9
https://ibb.co/dWaSPU
Old 10-07-2018, 18:20   #5 (permalink)
Member: 2674678
Thanks Meter: 16
And in Phone Softwarenumber is from t-mobile, but today I flashes a ruu 6.12.401.4
https://ibb.co/dbxtW9
And can't boot to recovery.
Old 10-08-2018, 13:31   #6 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,147
one of images shows keycard error
FAQ: "Check keycard failed"
Old 10-08-2018, 13:32   #7 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,147
did u try flashing back previous firmware that was on phone
Old 10-08-2018, 14:39   #8 (permalink)
Member: 2674678
Thanks Meter: 16
https://ibb.co/nmKUOpi flashed twrp recovery and got this error, and instaled a custom rom.
i tryed with another HTC m8 and s-off works perfectly with direct mode.
Old 10-08-2018, 19:06   #9 (permalink)
Member: 2674678
Thanks Meter: 16
i flashed 0P6BIMG_M8_UL_M60_SENSE70_MR_TMO_DE_6.12.111.4_Rad io_1.29.214500021.12G_20.72.4196t.01_F_release_460 604_signed_2_4.
no recovery
and the log
Starting flash process...
target rom version: 6.12.111.4
found large-zip header, file count: 6
processing file 1/6...
sending 'zip' (53966 KB)...
OKAY [ 2.383s]
writing 'zip'...
(bootloader) adopting the signature contained in this image...
(bootloader) signature checking...
(bootloader) rom parsing start ...
(bootloader) rom parsing finish ...
(bootloader) radio_batt_level: NOT IMPLEMENTED!
(bootloader) [SPEW] GPIO 0 status is 1
(bootloader) [SD_ERR] No sd card inserted!
(bootloader) Smart SD detect failed so disable detect
(bootloader) [JAVACARD_ERR] SD/USBDISK Init error
(bootloader) g_cKeyCardSecurityLevel=[255]
(bootloader) zip header checking...
(bootloader) zip info parsing...
(bootloader) checking model ID...
(bootloader) checking custom ID...
(bootloader) checking main version...
(bootloader) [INFO] CheckMainVer: image_main_version[6.12.111.4]
(bootloader) [INFO] CheckMainVer: setting_main_version[6.12.401.4]
(bootloader) Version String: 6.12.111.4
(bootloader) extraction: 111
(bootloader) Version String: 6.12.401.4
(bootloader) extraction: 401
(bootloader) checking hboot version...
(bootloader) CheckZipHbootVer in...
(bootloader) CheckHbootPlatform: device pid: 272
(bootloader) CheckHbootPlatform: target-image platform accepted
(bootloader) [INFO] CheckHbootVer: image_hboot_version[3.19.0.0000]
(bootloader) [INFO] CheckHbootVer: setting_hboot_version[3.19.0.0000]
(bootloader) Start Verify: 0
Processing [hboot], please wait...
(bootloader) total_image_number=8
(bootloader) ...... Successful
(bootloader) current_image_number=0
(bootloader) current_image_number=1
(bootloader) current_image_number=2
(bootloader) current_image_number=3
(bootloader) current_image_number=4
(bootloader) current_image_number=5
(bootloader) current_image_number=6
(bootloader) current_image_number=7
FAILED (remote: 90 hboot pre-update! please flush image again immediately)
finished. total time: 6.892s
preupdate done, rebooting...
Phone DISconnected
Phone connected [SH45BWM02058] *** Fastboot mode
resending command...
OKAY [ 2.517s]
writing 'zip'...
(bootloader) total_image_number=17
Processing [sbl1], please wait...
(bootloader) [INFO] Image[sbl1] size: 316538
(bootloader) [INFO] Extracting image[sbl1] 0-100%
(bootloader) [INFO] Writing partition[sbl1] 0%-100%
(bootloader) TZ_HTC_SVC_VERIFY_BOOTLOADER ret = 0
(bootloader) TZ_HTC_SVC_VERIFY_BOOTLOADER ret = -1
(bootloader) verified fail
(bootloader) ..... Bypassed
Processing [sdi], please wait...
(bootloader) [INFO] Image[sdi] size: 11770
(bootloader) [INFO] Extracting image[sdi] 0-100%
(bootloader) [INFO] Writing partition[sdi] 0%-100%
Processing [rpm], please wait...
(bootloader) [INFO] Image[rpm] size: 194816
(bootloader) [INFO] Extracting image[rpm] 0-100%
(bootloader) [INFO] Writing partition[rpm] 0%-100%
Processing [boot], please wait...
(bootloader) [INFO] Image[boot] size: 10340608
(bootloader) [INFO] Extracting image[boot] 0-100%
(bootloader) [INFO] Writing partition[boot] 0%-100%
Processing [recovery], please wait...
(bootloader) [INFO] Image[recovery] size: 18831616
(bootloader) [INFO] Extracting image[recovery] 0-100%
(bootloader) [INFO] Writing partition[recovery] 0%-100%
Processing [adsp], please wait...
(bootloader) [INFO] Image[adsp] size: 9614336
(bootloader) [INFO] Extracting image[adsp] 0-100%
(bootloader) [INFO] Writing partition[adsp] 0%-100%
Processing [wcnss], please wait...
(bootloader) [INFO] Image[wcnss] size: 4592640
(bootloader) [INFO] Extracting image[wcnss] 0-100%
(bootloader) [INFO] Writing partition[wcnss] 0%-100%
(bootloader) current_image_number=8
Processing [tz], please wait...
(bootloader) [INFO] Image[tz] size: 366426
(bootloader) [INFO] Extracting image[tz] 0-100%
(bootloader) [INFO] Writing partition[tz] 0%-100%
(bootloader) current_image_number=9
Processing [pg2fs_spcustom], please wait...
(bootloader) [INFO] Image[pg2fs_spcustom] size: 4188160
(bootloader) [INFO] Extracting image[pg2fs_spcustom] 0-100%
(bootloader) [INFO] Writing partition[pg2fs_spcustom] 0%-100%
(bootloader) [PGFS] partition_update_pgfs: pg2fs_spcustom
(bootloader) current_image_number=10
Processing [sensor_hub], please wait...
(bootloader) [INFO] Image[sensor_hub] size: 209760
(bootloader) [INFO] Extracting image[sensor_hub] 0-100%
(bootloader) [INFO] Writing partition[sensor_hub] 0%-100%
(bootloader) Continue to update Sensor hub FW, return value = -2
(bootloader) current_image_number=11
Processing [tp], please wait...
(bootloader) [INFO] Image[tp] size: 95772
(bootloader) [INFO] Extracting image[tp] 0-100%
(bootloader) [INFO] Writing partition[tp] 0%-100%
(bootloader) [TP]<2>This firmware is not for us, bypass
(bootloader) current_image_number=12
(bootloader) [INFO] Image[tp] size: 95767
(bootloader) [TP]The firmware version are the same, bypass update: On-chi
(bootloader) p: 1594356, Img: 1594356
(bootloader) current_image_number=13
Processing [sp1], please wait...
(bootloader) [INFO] Image[sp1] size: 4194304
(bootloader) [INFO] Extracting image[sp1] 0-100%
(bootloader) [INFO] Writing partition[sp1] 0%-100%
(bootloader) current_image_number=14
Processing [radio], please wait...
(bootloader) [INFO] Image[radio] size: 46834688
(bootloader) [INFO] Extracting image[radio] 0-100%
(bootloader) [INFO] Writing partition[radio] 0%-100%
(bootloader) trying to rename MBA
(bootloader) Skip: MODEM B14
(bootloader) Skip: MODEM B08
(bootloader) Skip: MODEM B16
(bootloader) Skip: MODEM B01
(bootloader) Skip: MODEM MDT
(bootloader) Skip: MODEM B25
(bootloader) Skip: MODEM B15
(bootloader) Skip: MODEM B13
(bootloader) Skip: MODEM B21
(bootloader) Skip: MODEM B11
(bootloader) Skip: MODEM B17
(bootloader) Skip: MODEM B26
(bootloader) Skip: MODEM B04
(bootloader) Skip: MODEM B27
(bootloader) Skip: MODEM B20
(bootloader) Skip: MODEM B19
(bootloader) Skip: MODEM B10
(bootloader) Skip: MODEM B18
(bootloader) Skip: MODEM B02
(bootloader) Skip: MODEM B22
(bootloader) Skip: MODEM B03
(bootloader) Skip: MODEM B05
(bootloader) Skip: MODEM B00
(bootloader) MBA file: (25)A7B80E1 B00 found
(bootloader) MBA file: (26)A7B80E1 MDT found
(27)A7B40E1 MDT found
(bootloader) MBA file: (28)A7BC0E1 MDT found
(bootloader) MBA file: (29)A7BC0E1 B00 found
(bootloader) MBA file: (30)A7B40E1 B00 found
(bootloader) Skip: MDATA CFG
(bootloader) Skip: UDATA CFG
(bootloader) Skip: RADIOVERCFG
(bootloader) Rename(0) 7B80E1.B00 to MBA.B00 successed
(bootloader) Rename(1) 7B80E1.MDT to MBA.MDT successed
(bootloader) renameMBAInRadio: 0
(bootloader) Erase modem_st1/modem_st2 due to radio image update!
(bootloader) current_image_number=15
Processing [rcdata], please wait...
(bootloader) [INFO] Image[rcdata] size: 185
(bootloader) [INFO] Extracting image[rcdata] 0-100%
(bootloader) [INFO] Writing partition[rcdata] 0%-100%
(bootloader) Erase modem_st1/modem_st2 due to rfg_1 image update
(bootloader) current_image_number=16
OKAY [ 67.511s]
finished. total time: 70.028s
processing file 2/6...
sending 'zip' (510888 KB)...
OKAY [ 15.630s]
writing 'zip'...
(bootloader) [INFO] CheckMainVer: setting_main_version[6.12.111.4]
Processing [system], please wait...
(bootloader) [INFO] Image[system] size: 838860800
(bootloader) [INFO] Extracting image[system] 0-100%
(bootloader) [INFO] Writing partition[system] 0%-100%
OKAY [ 56.164s]
finished. total time: 71.794s
processing file 3/6...
sending 'zip' (554593 KB)...
OKAY [ 16.939s]
writing 'zip'...
OKAY [ 56.581s]
finished. total time: 73.520s
processing file 4/6...
sending 'zip' (408798 KB)...
OKAY [ 12.481s]
writing 'zip'...
OKAY [ 47.914s]
finished. total time: 60.395s
processing file 5/6...
sending 'zip' (287 KB)...
OKAY [ 0.215s]
writing 'zip'...
(bootloader) [INFO] Image[system] size: 301989888
OKAY [ 8.232s]
finished. total time: 8.447s
processing file 6/6...
sending 'zip' (53726 KB)...
OKAY [ 2.522s]
writing 'zip'...
(bootloader) total_image_number=2
Processing [dzdata], please wait...
(bootloader) [INFO] Image[dzdata] size: 28230480
(bootloader) [INFO] Extracting image[dzdata] 0-100%
(bootloader) [INFO] Writing partition[dzdata] 0%-100%
OKAY [ 11.940s]
finished. total time: 14.462s
rompack updated
HBoot pre-update sequence
Flash process completed.
Old 10-09-2018, 09:34   #10 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,147
what was previous phone condition?
what is current condition ? phone turns on in os mode or not ?
Old 10-10-2018, 20:51   #11 (permalink)
Member: 2674678
Thanks Meter: 16
It was t-mob germany, the only was it is in bootloader do not show s-off , stock Recovery is going, I can change cid, I am wondering it shows s-on.
Old 10-12-2018, 17:01   #12 (permalink)
Member: 2416253
Thanks Meter: 4,108
I have seen such behavior only on damaged/wear EMMC.
Does it work at all?
Old 10-13-2018, 14:49   #13 (permalink)
Member: 2674678
Thanks Meter: 16
Yes, it works all boot normal.
Page generated in 0.45768 seconds with 7 queries
