02-18-2019, 15:16 | #1 (permalink) |
Freak Poster Join Date: Jan 2017
Member: 2674678 Status: Offline Thanks Meter: 17 | HTC M8s [SOLVED] Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 1.0.U20410.1@50408 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 1.21.111.1 (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: FA56SYS03351 (bootloader) imei: 3580310******** (bootloader) imei2: Not Support (bootloader) meid: 00000000000000 (bootloader) product: m8ql_ul (bootloader) platform: hTCBmsm8939 (bootloader) modelid: 0PKV10000 (bootloader) cidnum: T-MOB101 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 7900fbfd (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 (bootloader) mfg-name: 0001 all: Done! finished. total time: 0.016s htc_fastboot finished Reading CID information ... (bootloader) cid: T-MOB101 OKAY finished. total time: 0.000s htc_fastboot finished Reading MEID information ... (bootloader) meid: 00000000000000 OKAY finished. total time: 0.000s htc_fastboot finished Reading IMEI1 information ... (bootloader) imei: 358031******** OKAY finished. total time: 0.000s htc_fastboot finished Reading IMEI2 information ... (bootloader) readimei2: Not Support OKAY finished. total time: -0.000s htc_fastboot finished Reading secure flag information ... (bootloader) secure_flag: 3 OKAY finished. total time: -0.000s htc_fastboot finished Reading serial number information ... (bootloader) [ERR] Command error !!! OKAY finished. total time: 0.000s htc_fastboot finished Reading color information ... (bootloader) [ERR] Command error !!! OKAY finished. total time: 0.016s htc_fastboot finished Read information completed. When i try to relock bootloader: F:\HTC\HTC M8s>fastboot oem lock ... (bootloader) [PGFS] partition_update_pgfs: pg1fs_security (bootloader) TZ_HTC_SVC_ENC ret = 0 (bootloader) [PGFS] partition_update_pgfs: pg2fs_sec_recovery (bootloader) Lock successfully... (bootloader) deinit_lcd (bootloader) mipi display off (bootloader) TZ_HTC_SVC_DISABLE ret = 536739196 (0x1FFDFD7C) (bootloader) [ERR] Failed to disable wdog debug: 15 (bootloader) [INFO] Calling SCM to disable SPMI PMIC arbiter (bootloader) [ERR] Cannot halt SPMI arbiter!! (bootloader) [INFO] Rebooting device FAILED (status read failed (No such file or directory)) finished. total time: 1.422s When try to flash recovery: F:\HTC\HTC M8s>fastboot flash recovery D:\OUT\firmware\recovery_signed.img target reported max download size of 16777216 bytes Invalid sparse file format at header magi error: write_sparse_skip_chunk: don't care size 8395008 is not a multiple of the block size 4096 sending sparse 'recovery' (14598 KB)... error: write_sparse_skip_chunk: don't care size 8395008 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 8395008 is not a multiple of the block size 4096 OKAY [ 1.860s] writing 'recovery'... FAILED (remote: image error! (BootMagic check fail)) finished. total time: 1.875s when i try to flash twrp: :\HTC\HTC M8s>fastboot flash recovery "F:\HTC\HTC M8s\twrp-recovery-2.8.7.0-m8s-qlul\recovery.img" target reported max download size of 16777216 bytes Invalid sparse file format at header magi error: write_sparse_skip_chunk: don't care size 5261312 is not a multiple of the block size 4096 sending sparse 'recovery' (16382 KB)... error: write_sparse_skip_chunk: don't care size 5261312 is not a multiple of the block size 4096 error: write_sparse_skip_chunk: don't care size 5261312 is not a multiple of the block size 4096 OKAY [ 2.030s] writing 'recovery'... FAILED (remote: image error! (BootMagic check fail)) finished. total time: 2.045s so pleas help whats wrong with this model ? |
02-18-2019, 22:15 | #5 (permalink) |
Member: 2674678 Status: Offline Thanks Meter: 17 | I don't have a emmc repair box. But I have another repair box, have the problem completely dissolved, take hydrochloric acid and carefully put the HTC M8s into it, and looks at how the problem is resolved. |
