09-12-2017, 14:05 | #1 (permalink) |
No Life Poster Join Date: Oct 2006
Member: 380870 Status: Offline Thanks Meter: 159 | Htc M9 flash error [SOLVED] target rom version: 3.36.709.3 found large-zip header, file count: 8 processing file 1/8... sending 'zip' (277761 KB)... OKAY [ 16.150s] writing 'zip'... (bootloader) HOSD CL#839204 (bootloader) ERR check AES encrypted magic string failed. (bootloader) end@Done FAILED (remote: 12 RU_ZIP_ERROR ) finished. total time: 18.179s Flash process completed. Flash not successfull, reboot will not be done |
09-12-2017, 17:05 | #2 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Hello, You need to flash partial flash file first prior to upgrading to Android 7. Flash file no. 490768, then you can full flash. |
The Following User Says Thank You to xtc2clip For This Useful Post: |
09-13-2017, 11:12 | #6 (permalink) |
Member: 380870 Status: Offline Thanks Meter: 159 | cannot flash partial. i have this error Starting flash process... target reported max download size of 800000000 bytes sending 'zip' (135348 KB)... OKAY [ 8.395s] writing 'zip'... (bootloader) HOSD CL#839204 (bootloader) ERR CID not matched (bootloader) ERR [SD_UPDATE_ERR] CID NOT ALLOWED (bootloader) ERR [SD_UPDATE_ERR] sddownload failed: 7 (bootloader) ERR Update zip file failed. (bootloader) ERR ZIP signature checking failed... (bootloader) Update zip file OK (bootloader) ERR ZIP ERROR CODE, 7 (bootloader) end@Done FAILED (remote: 7 RU_CID_FAIL cid in android-info mismatched ) finished. total time: 12.572s Flash process completed. Flash not successfull, reboot will not be done |
09-13-2017, 11:55 | #8 (permalink) |
Member: 380870 Status: Offline Thanks Meter: 159 | i make s-off and super cid. partial flash ok. when try to flash full firmware get this. Starting flash process... target rom version: 3.36.709.3 found large-zip header, file count: 8 processing file 1/8... sending 'zip' (277761 KB)... OKAY [ 16.187s] writing 'zip'... (bootloader) HOSD CL#836547 (bootloader) ERR check AES encrypted magic string failed. (bootloader) end@Done FAILED (remote: 12 RU_ZIP_ERROR ) finished. total time: 18.223s Flash process completed. Flash not successfull, reboot will not be done |
09-13-2017, 15:41 | #9 (permalink) | |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Quote:
01-21-2018, 22:07 | #11 (permalink) | |
Freak Poster Join Date: Jan 2012
Member: 1713460 Status: Offline Thanks Meter: 28 | Quote:
Have same error but with Tmob USA phone Flash file no. 490768 is for MR HTC Europe 0PJA10000 Can I flash it in T-MOB010 0PJA12000 phone? | |
01-22-2018, 13:09 | #12 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
search HIMA_UL in support and choose any firmware to debrand you will need s-off and super cid Last edited by deepakgarg; 01-22-2018 at 13:14. | |
01-22-2018, 23:18 | #13 (permalink) | |
Currently flashed 3.xx and applied OTA and now 4.xx But it is boring procedure. There should be the same partial flash files for each MId, I guess | |
01-26-2018, 11:40 | #14 (permalink) | ||
