05-21-2018, 13:08 | #1 (permalink) |
No Life Poster Join Date: Oct 2017
Member: 2766801 Status: Offline Thanks Meter: 182 | htc m9 flash fail help Starting flash process... target rom version: 3.35.161.12 found large-zip header, file count: 8 processing file 1/8... sending 'zip' (133005 KB)... OKAY [ 8.973s] writing 'zip'... (bootloader) HOSD CL#859282 (bootloader) ERR check AES encrypted magic string failed. (bootloader) end@Done FAILED (remote: 12 RU_ZIP_ERROR ) finished. total time: 11.000s Flash process completed. guys whats the cause? how do i flash it successfully? |
05-21-2018, 14:54 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: cameroon
Member: 260658 Status: Offline Thanks Meter: 184 | Same probleme here, please help Starting flash process... target rom version: 4.28.401.3 found large-zip header, file count: 7 processing file 1/7... sending 'zip' (134760 KB)... OKAY [ 8.756s] writing 'zip'... (bootloader) HOSD CL#702159 (bootloader) ERR check AES encrypted magic string failed. (bootloader) end@Done FAILED (remote: 12 RU_ZIP_ERROR ) finished. total time: 10.786s Flash process completed. Flash not successfull, reboot will not be done |
05-21-2018, 14:54 | #4 (permalink) |
05-21-2018, 15:02 | #6 (permalink) |
Member: 260658 Status: Offline Thanks Meter: 184 | eading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_himauhl (bootloader) version: 1.0 (bootloader) imei: 357226065480212 (bootloader) version-main: 3.42.708.3 (bootloader) boot-mode: download (bootloader) version-baseband: 01.01_U11440801_97.04.60111G_F (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: OPJA11000 (bootloader) cid: 11111111 all: Execution time is 25(ms) Reading CID information ... (bootloader) cid: 11111111 OKAY Execution time is 66(ms) Reading MEID information ... (bootloader) meid: OKAY Execution time is 13(ms) Reading IMEI1 information ... (bootloader) imei: 357226065480212 OKAY Execution time is 21(ms) Reading IMEI2 information ... (bootloader) imei2: OKAY Execution time is 19(ms) Reading secure flag information ... (bootloader) Device security level S-OFF OKAY Execution time is 77(ms) Reading serial number information ... (bootloader) Device Serial No. is FA54JYJ00436 OKAY Execution time is 12(ms) Read information completed. |
05-21-2018, 15:23 | #7 (permalink) |
Member: 2766801 Status: Offline Thanks Meter: 182 | Device in fastboot Reading information... Using Fastboot mode... Reading common information (bootloader) version:0.5 (bootloader) ramdump-mode:false (bootloader) variant:MTP eMMC (bootloader) secure:yes (bootloader) version-baseband: (bootloader) version-bootloader: (bootloader) max-download-size: 0x20000000 (bootloader) partition-type:cache:ext4 (bootloader) partition-size:cache: 0x14000000 (bootloader) partition-type:userdata:ext4 (bootloader) partition-size:userdata: 0x5e0000000 (bootloader) partition-type:system:ext4 (bootloader) partition-size:system: 0x118000000 (bootloader) serialno:FA597YJ02384 all: Execution time is 153(ms) Reading CID information ... FAILunknown command FAILED (remote: unknown command) Execution time is 7(ms) Reading MEID information ... FAILunknown command FAILED (remote: unknown command) Execution time is 14(ms) Reading IMEI1 information ... FAILunknown command FAILED (remote: unknown command) Execution time is 3(ms) Reading IMEI2 information ... FAILunknown command FAILED (remote: unknown command) Execution time is 4(ms) Reading secure flag information ... (bootloader) read secure flag: 3 OKAY Execution time is 18(ms) Reading serial number information ... FAILunknown command FAILED (remote: unknown command) Execution time is 17(ms) Read information completed. |
05-21-2018, 15:24 | #8 (permalink) |
Member: 2766801 Status: Offline Thanks Meter: 182 | Device in Download Mode Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_himauhl (bootloader) version: 1.0 (bootloader) serialno: FA597YJ02384 (bootloader) current-slot: (bootloader) imei: 357226069769917 (bootloader) version-main: 4.17.161.11 (bootloader) boot-mode: download (bootloader) version-baseband: 01.01_U114401031_124.01.70203G_F (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 0PJA10000 (bootloader) cid: VODAP102 all: Execution time is 7(ms) Reading CID information ... (bootloader) cid: VODAP102 OKAY Execution time is 61(ms) Reading MEID information ... (bootloader) meid: OKAY Execution time is 7(ms) Reading IMEI1 information ... (bootloader) imei: 357226069769917 OKAY Execution time is 6(ms) Reading IMEI2 information ... (bootloader) imei2: OKAY Execution time is 14(ms) Reading secure flag information ... (bootloader) Device security level S-ON OKAY Execution time is 20(ms) Reading serial number information ... (bootloader) Device Serial No. is FA597YJ02384 OKAY Execution time is 7(ms) Read information completed. |
05-21-2018, 16:39 | #9 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
05-21-2018, 16:39 | #10 (permalink) | |
The Following User Says Thank You to deepakgarg For This Useful Post: |
