01-12-2017, 13:27 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | HTC Desire 626s How To S-Off? Sir How To S-Off For Downgrading To 5.1.1 At The Moment Its On 6.0 It Locked To Network (MetroPCS) Want To Unlock But On 6.0 I Failed To Unlock It Via Special unlock / IMEI TAB And When Boot To FTM Mode Its Shows Error On Display But Nothing Happens Bootloader Info Code: Reading information... Using Fastboot mode... Reading common information (bootloader) version:0.5 (bootloader) ramdump-mode:false (bootloader) variant:MTP eMMC (bootloader) secure:yes (bootloader) version-baseband: (bootloader) version-bootloader: (bootloader) max-download-size: 0x10000000 (bootloader) partition-type:cache:ext4 (bootloader) partition-size:cache: 0x10000000 (bootloader) partition-type:userdata:ext4 (bootloader) partition-size:userdata: 0xf0000000 (bootloader) partition-type:system:ext4 (bootloader) partition-size:system: 0xa0000000 (bootloader) serialno:FA5CAB0XXXXX all: Execution time is 93(ms) Reading secure flag information ... (bootloader) read secure flag: 3 OKAY Execution time is 31(ms) Reading CID information ... FAILunknown command FAILED (remote: unknown command) Execution time is 15(ms) Reading MEID information ... FAILunknown command FAILED (remote: unknown command) Execution time is 15(ms) Read information failed Code: Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_a32eul (bootloader) version: 1.0 (bootloader) imei: 3526790768XXXXX (bootloader) version-main: 2.17.1550.1 (bootloader) boot-mode: download (bootloader) version-baseband: 01.01_U113251211_64.10.60616G (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 0PM911000 (bootloader) cid: METRO001 all: Execution time is 15(ms) Reading secure flag information ... (bootloader) Device security level S-ON OKAY Execution time is 1(s) Reading CID information ... (bootloader) cid: METRO001 OKAY Execution time is 15(ms) Reading MEID information ... (bootloader) meid: OKAY Execution time is 0(ms) Read information completed. |
01-12-2017, 17:12 | #2 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Hello, To S-OFF you need to use "Direct mode commands" tab and use "Write security" button. http://forum.gsmhosting.com/vbb/f961...6-etc-2022417/ |
12-24-2019, 17:46 | #3 (permalink) | |
No Life Poster Join Date: Dec 2011 Location: Where i Want
Member: 1699006 Status: Offline Thanks Meter: 179 | Quote:
I try Direct Mode, SD Card mode, Bootloader and Download mode Code: Sending oem writesecureflag 0 ... FAILunknown command FAILED (remote: unknown command) finished. total time: 0.021s htc_fastboot finished Operation finished | |
12-26-2019, 07:25 | #4 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | https://xtc2.net/images/m9_noclip.jpg Make sure sd mounted written in download mode than try again |
The Following User Says Thank You to deepakgarg For This Useful Post: |
12-26-2019, 21:09 | #5 (permalink) | |
Supporters dont answer, about you thanks for replay Best Regards | |
