04-30-2018, 08:57 | #1 (permalink) |
Junior Member Join Date: Apr 2018
Member: 2829988 Status: Offline Thanks Meter: 1 | htc one a9 s-off help Direct mode write security S-Off Sending oem writesecureflag 0 ... (bootloader) HTC KEY CARD VERSION: 6 FAILPERMISSION DENY (NOT_FIND_SMART_IO) FAILED (remote: PERMISSION DENY (NOT_FIND_SMART_IO)) Execution time is 7(ms) Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage. Operation finished |
04-30-2018, 09:46 | #2 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
05-10-2018, 09:34 | #9 (permalink) |
Member: 2829988 Status: Offline Thanks Meter: 1 | Reading information... Using Fastboot mode... Reading common information (bootloader) version:0.5 (bootloader) ramdump-mode:false (bootloader) variant:MTP eMMC (bootloader) secure:yes (bootloader) version-baseband: (bootloader) version-bootloader: (bootloader) max-download-size: 0x20000000 (bootloader) partition-type:cache:ext4 (bootloader) partition-size:cache: 0x10000000 (bootloader) partition-type:userdata:ext4 (bootloader) partition-size:userdata: 0x638000000 (bootloader) partition-type:system:ext4 (bootloader) partition-size:system: 0xc6000000 (bootloader) serialno:HT5ASSZ05238 all: Execution time is 78(ms) Reading CID information ... FAILunknown command FAILED (remote: unknown command) Execution time is 15(ms) Reading MEID information ... FAILunknown command FAILED (remote: unknown command) Execution time is 15(ms) Reading IMEI1 information ... FAILunknown command FAILED (remote: unknown command) Execution time is 31(ms) Reading IMEI2 information ... FAILunknown command FAILED (remote: unknown command) Execution time is 12(ms) Reading secure flag information ... (bootloader) read secure flag: 3 OKAY Execution time is 31(ms) Reading serial number information ... FAILunknown command FAILED (remote: unknown command) Execution time is 15(ms) Read information completed. |
05-10-2018, 10:00 | #10 (permalink) |
Member: 220603 Status: Offline Thanks Meter: 1,164 | Is your phone stuck at logo ? if you insert clip in sdslot and turn on phone in download mode..can u see sd card mounted written on screen |
05-13-2018, 09:20 | #11 (permalink) |
Member: 2829988 Status: Offline Thanks Meter: 1 | [QUOTE=deepakgarg;13125280]Is your phone stuck at logo ? if you insert clip in sdslot and turn on phone in download mode..can u see I see SD not mounted OTG not mounted File not found. I was able to unlock many phones in the past suddently for years haven't use it and come back it have problem. |
