05-18-2019, 02:08 | #1 (permalink) |
Junior Member Join Date: Aug 2013
Member: 1994696 Status: Offline Thanks Meter: 5 | HTC One A9 sensor broken and can't flash Starting flash process... target rom version: 2.18.617.56 found large-zip header, file count: 23 processing file 1/23... sending 'zip' (128671 KB)... OKAY [ 6.071s] writing 'zip'... (bootloader) HOSD CL#861328 (bootloader) GPT (gpt_main_32g.img) is up-to-dated. [17408] (bootloader) Perform pre-update (bootloader) WARN Skip partition_info due to unmatched partition name (bootloader) WARN Skip backup_android-info.txt due to unmatched partitio (bootloader) n name (bootloader) get 26 images from zip(zip_type=3) (bootloader) start@26 (bootloader) apppreload.img@BYPASS (bootloader) aboot_signed.img@100% (bootloader) cota.img@BYPASS (bootloader) sbl1-8952-1.img@100% (bootloader) hosd_signed.img@100% (bootloader) rpm-8952-1.img@100% (bootloader) boot_signed.img@BYPASS (bootloader) recovery_signed.img@BYPASS (bootloader) adsp.img@BYPASS (bootloader) dsp.img@BYPASS (bootloader) wcnss.img@BYPASS (bootloader) cradio.img@BYPASS (bootloader) rcdata.img@BYPASS (bootloader) rfg_3.img@BYPASS (bootloader) modemst1.img@BYPASS (bootloader) modemst2.img@BYPASS (bootloader) fsc.img@BYPASS (bootloader) tz-8952-1.img@100% (bootloader) hyp-8952-1.img@100% (bootloader) cmnlib32.img@100% (bootloader) keymaster.img@100% (bootloader) pg2fs_ship_signkey.img@100% (bootloader) sensor_hub.img@BYPASS (bootloader) tp_SYN3708.img@BYPASS (bootloader) splash1.nb0@BYPASS (bootloader) radio.img@BYPASS FAILED (remote: 90 hboot pre-update! please flush image again immediately ) finished. total time: 8.948s preupdate done, rebooting... Phone DISconnected resending command... sending 'zip' (128671 KB)... OKAY [ 6.053s] writing 'zip'... (bootloader) HOSD CL#861328 (bootloader) GPT (gpt_main_32g.img) is up-to-dated. [17408] (bootloader) WARN Skip partition_info due to unmatched partition name (bootloader) WARN Skip backup_android-info.txt due to unmatched partitio (bootloader) n name (bootloader) get 26 images from zip(zip_type=3) (bootloader) start@26 (bootloader) apppreload.img@22% (bootloader) apppreload.img@45% (bootloader) apppreload.img@68% (bootloader) apppreload.img@90% (bootloader) apppreload.img@100% (bootloader) aboot_signed.img@100% (bootloader) cota.img@100% (bootloader) sbl1-8952-1.img@100% (bootloader) hosd_signed.img@100% (bootloader) rpm-8952-1.img@100% (bootloader) boot_signed.img@100% (bootloader) recovery_signed.img@100% (bootloader) adsp.img@100% (bootloader) dsp.img@100% (bootloader) wcnss.img@100% (bootloader) cradio.img@100% (bootloader) rcdata.img@100% (bootloader) rfg_3.img@100% (bootloader) modemst1.img@100% (bootloader) modemst2.img@100% (bootloader) fsc.img@100% (bootloader) tz-8952-1.img@100% (bootloader) hyp-8952-1.img@100% (bootloader) cmnlib32.img@100% (bootloader) keymaster.img@100% (bootloader) pg2fs_ship_signkey.img@100% (bootloader) splash1.nb0@100% (bootloader) radio.img@100% (bootloader) sensor_hub.img@0% (bootloader) sensor_hub.img@0% (bootloader) sensor_hub.img@0% (bootloader) sensor_hub.img@0% (bootloader) sensor_hub.img@0% (bootloader) sensor_hub.img@0% (bootloader) sensor_hub.img@0% (bootloader) sensor_hub.img@0% (bootloader) sensor_hub.img@0% (bootloader) sensor_hub.img@0% (bootloader) ERR do_firmware_update_thread: child exited with non-zero s (bootloader) tatus: 255 (bootloader) ERR Flashing [sensor_hub.img] failed with status [255] (bootloader) ERR Faild to update firmware [sensor_hub.img] (bootloader) sensor_hub.img@FAIL (bootloader) tp_SYN3708.img@BYPASS (bootloader) Update zip file OK (bootloader) ERR WRITE ERROR, 33 (bootloader) end@Done FAILED (remote: 33 RU_UPDATE_FIRMWARE_FAIL ) finished. total time: 71.456s HBoot pre-update sequence Flash process completed. Flash not successfull, reboot will not be done Phone connected [HT695SZ01415] *** Fastboot mode |
