03-12-2016, 00:37 | #1 (permalink) |
Insane Poster Join Date: Nov 2015
Member: 2484103 Status: Offline Thanks Meter: 3 | Htc one a9 from sprint wont get data connection AnywAy ,it will recognise my sim and get the network signal,I will be able to do calls and send messages. With one sim card after setting the apn I will get even 4g LTE ,with another carrier with the same bands and coverage on my country won't get data connection. Any idea ??everything else works fine |
03-12-2016, 20:43 | #4 (permalink) |
Freak Poster Join Date: Aug 2013 Location: California
Member: 2013942 Status: Offline Thanks Meter: 33 | Just a guess, but from my tests from doing the HTC A9 from Sprint. Upon changing the IMEI the MEID must match as well. (Sometimes I don't believe the program writes MEID to the device all the time, at least for me.) So I would say to write back the original imei from the HTC then read the SPC from the device using the program. Then you will need to write the IMEI you want back on the device. (The SPC is needed because I used WS to write the MEID.) After both MEID and IMEI is wrote on the device perfectly try again with the Hands Free Activation (Assuming your using Sprint Service..) But I've not been able to get the HTC A9 to work Domestically with the program. I'm guessing it only Unlocks them for international use. not USA. Could be wrong.. ( My post about HTC A9 Unlock ) Maybe that helps??? |
03-13-2016, 00:20 | #5 (permalink) |
Member: 2484103 Status: Offline Thanks Meter: 3 | thannks for the reply,i checked the imei and meid twice,its the same one,i get data and network signal with iusacll,but when i try with my sim from telcel it will only get data connection but no data. |
03-14-2016, 15:25 | #6 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | We are currently investigating this problem and hope to have first results by the end of this week. |
The Following 3 Users Say Thank You to xtc2clip For This Useful Post: |
03-14-2016, 20:31 | #7 (permalink) |
Member: 2484103 Status: Offline Thanks Meter: 3 | I noticed that with the carrier that is working with the phone shows a lock and I can't delete the apn .with the other carrier when I pop the sim all the apns are gone except the one that is not working |
04-06-2016, 10:33 | #11 (permalink) |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Yes, as I wrote in separate thread I'm getting data on A9 with no problem, it's HDSPA, not LTE, but A9 Sprint LTE is not supposed to work on the frequencies in my country. So I'm a bit lost here, as i can't check why the data is not working in USA. However I'm going to try to integrate firmware from European A9 into Sprint mode to see if its possible. |
The Following User Says Thank You to xtc2clip For This Useful Post: |
04-06-2016, 11:01 | #12 (permalink) | |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | Quote:
04-07-2016, 18:43 | #15 (permalink) |
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Depends on "how different". If I'm getting 2G internet and other's don't get any data connection (however I can assume that USA operators may not have 2G ?) then something is wrong here. |
