Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 07-10-2015, 07:23   #1 (permalink)
sajidmirza's Avatar
Member: 256461
Sonork: 100.1608049
Thanks Meter: 90
htc one m7 error
I received this clip yesterday and successfully unlocked htc m8 sprint.
today i want to s-off and change cid for htc one M7 by Y cable ,it just searches for files and returns to bootloader mode.In xtc2clip software i ticked cid as super cid and s-off.
what am i doing wrong.
note:bootloader is locked
Old 07-10-2015, 09:32   #2 (permalink)
Member: 2416253
Thanks Meter: 4,162
It searches for files and find them or not? Can you make a photo of the phone after selecting simlock?
Old 07-13-2015, 07:36   #3 (permalink)
sajidmirza's Avatar
Member: 256461
Sonork: 100.1608049
Thanks Meter: 90
sorry i have returned it to customer.
but when i use simlock it said "sdcard init failed"
sajid mirza
Old 07-13-2015, 08:13   #4 (permalink)
Member: 1222089
Sonork: 100.1583019
Thanks Meter: 2,688
sajid mirza
Use good Y cable ., some y cable not work with some Sdcard readers ., so try to change the sd reader and or y cable and check it again
The Following User Says Thank You to Smart-gsm For This Useful Post:
Old 07-14-2015, 11:20   #5 (permalink)
GsmHgvnl's Avatar
Member: 82928
Thanks Meter: 17
which sd card readers is tested ?
Old 07-14-2015, 11:47   #6 (permalink)
Member: 2416253
Thanks Meter: 4,162
Well, almost all are working.
But it's just recommended to use branded readers like Kingston, etc., because cheap Chinese versions may not work as intended.
A bit more information is here:
http://forum.gsmhosting.com/vbb/f961...eader-1964692/
Old 08-04-2015, 20:45   #7 (permalink)
Member: 958481
Thanks Meter: 2
I got the same error with 2 different y-cables and 5 different sd card readers
Reading information...
Using Fastboot mode...
Reading common information
(bootloader) version: 0.5
(bootloader) version-bootloader: 1.56.0000
(bootloader) version-baseband: 4A.24.3263.09
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main: 4.19.531.10
(bootloader) version-misc: PVT SHIP S-ON
(bootloader) serialno: XXXXXXXXXXXXX
(bootloader) imei: XXXXXXXXXXXXXXXXXXX
(bootloader) meid: 00000000000000
(bootloader) product: m7_ul
(bootloader) platform: HBOOT-8064
(bootloader) modelid: PN0713000
(bootloader) cidnum: T-MOB010
(bootloader) battery-status: good
(bootloader) battery-voltage: 4274mV
(bootloader) partition-layout: Generic
(bootloader) security: on
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
(bootloader) commitno-bootloader: dirty-4dab9d12
(bootloader) hbootpreupdate: 11
(bootloader) gencheckpt: 0
Execution time is 41(ms)
all: Done!
8064 detected, reading IMEI2 ...
... (bootloader) [ERR] Command error !!!
Execution time is 2(ms)
OKAY
Reading secure flag information
... (bootloader) secure_flag: 3
OKAY
Reading CID information
... (bootloader) cid: T-MOB010
Execution time is 3(ms)
OKAY
Read information completed.
Reading information from service files on SD card...
Readed CID settings
Readed security flag settings
IMEI: XXXXXXXXXXXXXXXXXXXXX
Unlock code: 00000000
MCC-MNC: 000-00
Readed sim-lock config settings
Done
CID value has been set to super-cid. Please save to SD card and use in phone
Writing information to service files on SD card...
CID settings saved
Security settings saved
Sim-lock settings saved
Done.
Old 08-05-2015, 10:29   #8 (permalink)
Member: 2416253
Thanks Meter: 4,162
all: Done!
OKAY
OKAY
OKAY
Readed CID settings
MCC-MNC: 000-00
Done
CID settings saved
Done.
So, where is the "error" ?
And with M7 you can't do anything in direct mode, as you need to use Y cable.
You CANNOT communicate with phone from PC with an Y cable.
http://forum.gsmhosting.com/vbb/f961...-step-1964502/
Old 08-21-2015, 20:32   #9 (permalink)
Fatalfury's Avatar
Member: 810122
Thanks Meter: 65
Question can i just use the sdcard slot on my laptop and usb cable instead of a Y cable ?
Old 08-23-2015, 13:46   #10 (permalink)
Member: 2416253
Thanks Meter: 4,162
No, sorry, you cannot.
Page generated in 0.18491 seconds with 8 queries
