10-01-2018, 09:48 | #1 (permalink) |
No Life Poster Join Date: Feb 2016 Location: GREAT Country Pakistan
Member: 2537939 Status: Offline Sonork: 100.1670350 Thanks Meter: 708 | M8 ul unlocking problem [SOLVED] Reading information... Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 3.19.0.0000 (bootloader) version-baseband: 1.29.214500021.12G (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 6.12.161.4 (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: SH43TWM06634 (bootloader) imei: 358714056997681 (bootloader) imei2: Not Support (bootloader) meid: 00000000000000 (bootloader) product: m8_ul (bootloader) platform: hTCBmsm8974 (bootloader) modelid: 0P6B10000 (bootloader) cidnum: VODAP001 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: 76df2b54 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! Execution time is 15(ms) Reading CID information ... (bootloader) cid: VODAP001 OKAY Execution time is 0(ms) Reading MEID information ... (bootloader) meid: 00000000000000 OKAY Execution time is 15(ms) Reading IMEI1 information ... (bootloader) imei: 358714056997681 OKAY Execution time is 0(ms) Reading IMEI2 information ... (bootloader) readimei2: Not Support OKAY Execution time is 15(ms) Reading secure flag information ... (bootloader) secure_flag: 3 OKAY Execution time is 15(ms) Reading serial number information ... (bootloader) [ERR] Command error !!! OKAY Execution time is 0(ms) Read information completed. Writing information to service files on SD card... IMEI settings saved CID settings saved Security settings saved WARNING: No IMEI specified, sim-lock settings are not saved Done. Phone DISconnected |
10-01-2018, 13:31 | #2 (permalink) | |
Freak Poster Join Date: Jul 2008 Location: GSM,Pakistan
Member: 811049 Status: Offline Thanks Meter: 99 | htc one m8 ul unlocking problem Quote:
1. Checking phone connectivity....... Phone connection confirmed! Requested card version not detected, version 6 will be used 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 3 (bootloader) m8_init_sd, SD card already power on (bootloader) [SPEW] GPIO 0 status is 0 (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: -16777216 (bootloader) erase_grpmult: 261078040 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) Error: DATA time out error (bootloader) Error: Command completed with errors (bootloader) Failed Reading block @ 0 (bootloader) [SD_ERR] sd_read_sector: read sector failed (0 1) (bootloader) [Tuxera][Error] Failed to read MBR (bootloader) Error: DATA time out error (bootloader) Error: Command completed with errors (bootloader) Failed Reading block @ 0 (bootloader) [SD_ERR] sd_read_sector: read sector failed (0 1) (bootloader) [FAT_ERROR] fat_open_file: load bpb fail(-5) (bootloader) [JAVACARD_ERR] SMART_IO.CRD cann't find (bootloader) writesecureflag: Permission denied, value 1 OKAY Execution time is 44(s) Operation completed! Releasing adapter. Request completed Phone DISconnected | |
10-01-2018, 19:26 | #4 (permalink) |
No Life Poster Join Date: Jun 2015
Member: 2416253 Status: Offline Thanks Meter: 4,162 | Hello, PowerAdapter is NOT for this model. You got it all wrong. Don't use PA and use regular smartcard, that's all. @Mian Jahangir I - you probably need to repair your FS: http://forum.gsmhosting.com/vbb/f961...t-etc-1964648/ |
10-02-2018, 08:06 | #5 (permalink) | |
Member: 2537939 Status: Offline Sonork: 100.1670350 Thanks Meter: 708 | Quote:
i dont have any power adapter kindly give us a proper way how to solve this already format fs | |
The Following User Says Thank You to lerner_ For This Useful Post: |
10-02-2018, 10:02 | #7 (permalink) | |
PA but failed to S-Off OR CID TO SUPER CID 1111111111.ANY GUIDE /help thanks. | |
10-04-2018, 08:16 | #10 (permalink) |
Member: 811049 Status: Offline Thanks Meter: 99 | direct mode error log. Sending oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 2 (bootloader) m8_init_sd, SD card already power on (bootloader) [SPEW] GPIO 0 status is 0 (bootloader) sdhci_open: id=0 (bootloader) Initializing MMC host data structure and clock! (bootloader) mmc slot#2 clock enabled (bootloader) sdhci_set_clock: slot 2, freq 192000000 (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdhci_set_bus_width: bus width 0 (bootloader) sdhci_clk_supply: freq 400000 (bootloader) Error: Command never completed (bootloader) Error: Command timeout error (bootloader) Error: Command completed with errors (bootloader) The response for CMD8 does not match the supplied value (bootloader) Decoded CID fields: (bootloader) Manufacturer ID: 7f (bootloader) OEM ID: 0x0 (bootloader) Product Name: 5270 (bootloader) Product revision: 5.2 (bootloader) Product serial number: B4E (bootloader) Manufacturing date: 2 2015 (bootloader) sdhci_clk_supply: freq 50000000 (bootloader) sdhci_set_bus_width: bus width 1 (bootloader) Done initialization of the card (bootloader) erase_grpsize: -16777216 (bootloader) erase_grpmult: 261078040 (bootloader) wp_grpsize: 1 (bootloader) wp_grpen: 1 (bootloader) perm_wp: 0 (bootloader) temp_wp: 0 (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) [JAVACARD_ERR] Smart card response error (ea). (bootloader) writesecureflag: Permission denied, value 4 OKAY Execution time is 4(s) Operation finished |
