09-13-2018, 22:15 | #1 (permalink) |
Insane Poster Join Date: Mar 2015
Member: 2358990 Status: Offline Thanks Meter: 1 | HTC A9 error flashing her is logs operation Starting flash process... target rom version: 2.16.161.5 found large-zip header, file count: 21 processing file 1/21... sending 'zip' (98706 KB)... OKAY [ 8.282s] writing 'zip'... (bootloader) HOSD CL#722052 (bootloader) ERR check AES encrypted magic string failed. (bootloader) end@Done Flash process completed. Flash not successfull, reboot will not be done pls team i need ur help thx in advance wbr |
09-14-2018, 13:48 | #3 (permalink) |
Member: 2358990 Status: Offline Thanks Meter: 1 | here is the fastboot info Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_hiaeuhl (bootloader) version: 1.0 (bootloader) imei: 352636075175880 (bootloader) version-main: 1.62.161.2 (bootloader) boot-mode: download (bootloader) version-baseband: 1.1.U00036.1@60204 (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 2PQ910000 (bootloader) cid: VODAP001 all: Execution time is 1(s) Reading CID information ... (bootloader) cid: VODAP001 OKAY Execution time is 333(ms) Reading MEID information Reading IMEI1 information Reading IMEI2 information ... (bootloader) imei2: OKAY Execution time is 1(s) Reading secure flag information ... (bootloader) Device security level S-ON OKAY Execution time is 1(s) Reading serial number information ... (bootloader) Device Serial No. is HT62TBE00169 OKAY Execution time is 164(ms) Read information completed. thx |
09-14-2018, 15:47 | #6 (permalink) |
Member: 2358990 Status: Offline Thanks Meter: 1 | sam problem Starting flash process... target rom version: 1.62.161.2 found large-zip header, file count: 23 processing file 1/23... sending 'zip' (113705 KB)... FAILED (status read failed (Unknown error)) finished. total time: 7.548s Phone DISconnected Flash process completed. Flash not successfull, reboot will not be done Phone connected [HT62TBE00169] *** Fastboot mode |
09-14-2018, 18:13 | #7 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Logs are not same error changed for some reason phone disconnected during flashing Make sure battery is fully charged and bootloader is locked Sent from my iPhone using Tapatalk |
The Following User Says Thank You to deepakgarg For This Useful Post: |
