07-17-2017, 16:58 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | HTC ONE M9 OPJA200 after flash non official firmware imei and baseband gone-help me Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_himauhl (bootloader) version: 1.0 (bootloader) imei: 355378060810711 (bootloader) version-main: 1.32.401.8 (bootloader) boot-mode: download (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 0PJA10000 (bootloader) cid: 11111111 all: Execution time is 15(ms) Reading secure flag information ... (bootloader) Device security level S-OFF OKAY Execution time is 93(ms) Reading CID information ... (bootloader) cid: 11111111 OKAY Execution time is 15(ms) Reading MEID information ... (bootloader) meid: 99000502696354 OKAY Execution time is 46(ms) Read information completed. i tried officail firmware flashing-error as below why above error-help me for flashing officail firmware-i think after flash imei and baseband ok. help me for the steps |
07-18-2017, 05:43 | #4 (permalink) | |
Member: 946381 Status: Offline Thanks Meter: 150 | Quote:
Starting flash process... target reported max download size of 800000000 bytes sending 'zip' (135348 KB)... OKAY [ 8.625s] writing 'zip'... (bootloader) HOSD CL#506785 (bootloader) GPT is up-to-dated. [17408] (bootloader) Perform pre-update (bootloader) start@24 (bootloader) apppreload.img@BYPASS (bootloader) aboot_signed.img@100% (bootloader) dzdata_32g.img@BYPASS (bootloader) sbl1-8994-1.img@100% (bootloader) sdi.img@100% (bootloader) hosd_signed.img@100% (bootloader) rpm-8994-1.img@100% (bootloader) pmic-8994-1.img@100% (bootloader) boot_signed.img@BYPASS (bootloader) recovery_signed.img@BYPASS (bootloader) adsp.img@BYPASS (bootloader) cpe.img@BYPASS (bootloader) rcdata.img@BYPASS (bootloader) modem_st1.img@BYPASS (bootloader) modem_st2.img@BYPASS (bootloader) tz-8994-1.img@100% (bootloader) hyp-8994-1.img@100% (bootloader) bootlocker.img@BYPASS (bootloader) pg2fs_ship_signkey.img@BYPASS (bootloader) sensor_hub.img@BYPASS (bootloader) tp_SYN3351.img@BYPASS (bootloader) tp_MXM11876.img@BYPASS (bootloader) splash1.nb0@BYPASS (bootloader) radio.img@BYPASS FAILED (remote: FAIL90 hboot pre-update! please flush image again immediate) finished. total time: 9.500s Phone DISconnected HBoot pre-update sequence Flash process completed. Restarting phone... Phone connected [FA53YFJ00334] *** Fastboot mode THEN I FULL flash-logs as below Starting flash process... target rom version: 4.28.401.3 found large-zip header, file count: 7 processing file 1/7... sending 'zip' (134760 KB)... OKAY [ 8.922s] writing 'zip'... (bootloader) HOSD CL#836547 (bootloader) GPT (gpt_main_32g.img) is up-to-dated. [17408] (bootloader) WARN Skip cmnlib32.img due to unmatched partition name (bootloader) WARN Skip cmnlib64.img due to unmatched partition name (bootloader) WARN Skip keymaster.img due to unmatched partition name (bootloader) WARN Skip bootlocker.img due to unmatched partition name (bootloader) WARN Skip cir.img due to unmatched partition name (bootloader) WARN Skip backup_android-info.txt due to unmatched partitio (bootloader) n name (bootloader) get 23 images from zip(zip_type=3) (bootloader) start@23 (bootloader) apppreload.img@22% (bootloader) apppreload.img@45% (bootloader) apppreload.img@68% (bootloader) apppreload.img@90% (bootloader) apppreload.img@100% (bootloader) aboot_signed.img@100% (bootloader) cota.img@100% (bootloader) sbl1-8994-1.img@100% (bootloader) sdi.img@100% (bootloader) hosd_signed.img@100% (bootloader) rpm-8994-1.img@100% (bootloader) pmic-8994-1.img@100% (bootloader) boot_signed.img@100% (bootloader) recovery_signed.img@100% (bootloader) adsp.img@100% (bootloader) cpe.img@100% (bootloader) rcdata.img@100% (bootloader) modem_st1.img@100% (bootloader) modem_st2.img@100% (bootloader) tz-8994-1.img@100% (bootloader) hyp-8994-1.img@100% (bootloader) pg2fs_ship_signkey.img@100% (bootloader) splash1.nb0@100% (bootloader) radio.img@100% (bootloader) sensor_hub.img@0% (bootloader) sensor_hub.img@0% (bootloader) sensor_hub.img@10% (bootloader) sensor_hub.img@20% (bootloader) sensor_hub.img@30% (bootloader) sensor_hub.img@40% (bootloader) sensor_hub.img@45% (bootloader) sensor_hub.img@55% (bootloader) sensor_hub.img@65% (bootloader) sensor_hub.img@75% (bootloader) sensor_hub.img@85% (bootloader) sensor_hub.img@95% (bootloader) sensor_hub.img@100% (bootloader) tp_SYN3351.img@BYPASS (bootloader) tp_MXM11876.img@BYPASS (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 79.938s] finished. total time: 88.859s processing file 2/7... sending 'zip' (447928 KB)... OKAY [ 27.766s] writing 'zip'... (bootloader) HOSD CL#836547 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_00@8% (bootloader) system.img_00@16% (bootloader) system.img_00@24% (bootloader) system.img_00@32% (bootloader) system.img_00@41% (bootloader) system.img_00@49% (bootloader) system.img_00@57% (bootloader) system.img_00@65% (bootloader) system.img_00@74% (bootloader) system.img_00@82% (bootloader) system.img_00@90% (bootloader) system.img_00@98% (bootloader) system.img_00@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 21.703s] finished. total time: 49.469s processing file 3/7... sending 'zip' (432520 KB)... OKAY [ 26.969s] writing 'zip'... (bootloader) HOSD CL#836547 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_01@8% (bootloader) system.img_01@16% (bootloader) system.img_01@24% (bootloader) system.img_01@33% (bootloader) system.img_01@41% (bootloader) system.img_01@49% (bootloader) system.img_01@58% (bootloader) system.img_01@66% (bootloader) system.img_01@74% (bootloader) system.img_01@82% (bootloader) system.img_01@91% (bootloader) system.img_01@99% (bootloader) system.img_01@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 17.828s] finished. total time: 44.797s processing file 4/7... sending 'zip' (471561 KB)... OKAY [ 29.328s] writing 'zip'... (bootloader) HOSD CL#836547 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_02@8% (bootloader) system.img_02@16% (bootloader) system.img_02@24% (bootloader) system.img_02@32% (bootloader) system.img_02@41% (bootloader) system.img_02@49% (bootloader) system.img_02@57% (bootloader) system.img_02@65% (bootloader) system.img_02@74% (bootloader) system.img_02@82% (bootloader) system.img_02@90% (bootloader) system.img_02@98% (bootloader) system.img_02@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 18.469s] finished. total time: 47.797s processing file 5/7... sending 'zip' (409251 KB)... OKAY [ 25.500s] writing 'zip'... (bootloader) HOSD CL#836547 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_03@8% (bootloader) system.img_03@16% (bootloader) system.img_03@24% (bootloader) system.img_03@33% (bootloader) system.img_03@41% (bootloader) system.img_03@49% (bootloader) system.img_03@58% (bootloader) system.img_03@66% (bootloader) system.img_03@74% (bootloader) system.img_03@82% (bootloader) system.img_03@91% (bootloader) system.img_03@99% (bootloader) system.img_03@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 18.250s] finished. total time: 43.750s processing file 6/7... sending 'zip' (204212 KB)... OKAY [ 13.297s] writing 'zip'... (bootloader) HOSD CL#836547 (bootloader) get 1 images from zip(zip_type=3) (bootloader) start@1 (bootloader) system.img_04@15% (bootloader) system.img_04@30% (bootloader) system.img_04@45% (bootloader) system.img_04@61% (bootloader) system.img_04@76% (bootloader) system.img_04@91% (bootloader) system.img_04@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 10.625s] finished. total time: 23.922s processing file 7/7... sending 'zip' (13483 KB)... OKAY [ 1.828s] writing 'zip'... (bootloader) HOSD CL#836547 (bootloader) get 2 images from zip(zip_type=3) (bootloader) start@2 (bootloader) dzdata_32g.img@100% (bootloader) boot_signed.img@100% (bootloader) Update zip file OK (bootloader) end@Done OKAY [ 6.141s] finished. total time: 7.969s rompack updated Flash process completed. Restarting phone... rebooting... Execution time is 46(ms) Phone DISconnected still big problem """"imei and baseband unknown"""-now phone in officail firmware-but same problem as in non officail firmware imei and baseband unknown what i do as a next step? help me | |
07-19-2017, 06:23 | #6 (permalink) |
Member: 946381 Status: Offline Thanks Meter: 150 | tried as ur pm message-error as below C:\android>fastboot oem erase modemst1 ... (bootloader) [ERR] Command error !!! OKAY [ 0.047s] finished. total time: 0.047s C:\android>fastboot oem erase modemst1 ... (bootloader) [ERR] Command error !!! OKAY [ 0.000s] finished. total time: 0.000s C:\android>fastboot oem erase modemst2 ... (bootloader) [ERR] Command error !!! OKAY [ 0.000s] finished. total time: 0.000s info as below Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_himauhl (bootloader) version: 1.0 (bootloader) serialno: FA53YFJ00334 (bootloader) current-slot: (bootloader) imei: 355378060810711 (bootloader) version-main: 4.28.401.3 (bootloader) boot-mode: download (bootloader) version-baseband: 01.01_U114401011_117.00.61117G_2_F (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 0PJA10000 (bootloader) cid: 11111111 all: Execution time is 15(ms) Reading secure flag information ... (bootloader) Device security level S-OFF OKAY Execution time is 15(ms) Reading CID information ... (bootloader) cid: 11111111 OKAY Execution time is 93(ms) Reading MEID information ... (bootloader) meid: 99000502696354 OKAY Execution time is 1(s) Read information completed. what i do as a next step? |
07-01-2018, 10:25 | #8 (permalink) |
Junior Member Join Date: Jul 2012 Location: Kathmandu
Member: 1787230 Status: Offline Thanks Meter: 4 | IMEI and Baseband Unknown. exactly same problem with me. Please help me to solve.. oem erase modem command is not working with me too. Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_himauhl (bootloader) version: 1.0 (bootloader) serialno: FA53YFJ00672 (bootloader) current-slot: (bootloader) imei: 355378060824944 (bootloader) version-main: 4.14.401.7 (bootloader) boot-mode: download (bootloader) version-baseband: 01.01_U114401011_117.00.61117G_2_F (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 0PJA10000 (bootloader) cid: 11111111 all: Execution time is 15(ms) Reading CID information ... (bootloader) cid: 11111111 OKAY Execution time is 12(ms) Reading MEID information ... (bootloader) meid: OKAY Execution time is 11(ms) Reading IMEI1 information ... (bootloader) imei: 355378060824944 OKAY Execution time is 11(ms) Reading IMEI2 information ... (bootloader) imei2: OKAY Execution time is 12(ms) Reading secure flag information ... (bootloader) Device security level S-OFF OKAY Execution time is 11(ms) Reading serial number information ... (bootloader) Device Serial No. is FA53YFJ00672 OKAY Execution time is 15(ms) Read information completed. |
07-01-2018, 10:38 | #9 (permalink) | |
Freak Poster Join Date: Nov 2015 Location: Taipei, Taiwan
Member: 2487890 Status: Offline Thanks Meter: 72 | Quote:
Code: fastboot reboot-bootloader fastboot erase persist | |
