htc one m9 sprint can't flash any firmware Hello to all ! Need some help with this htc one m9 sprint ! Phone is new ! Stuck on bootloader, bootloader unlocked , s-off , download mode ok ,no recovery , can't flash any firmware ! Unknown history ! error : reboot reason: 0X77665533 reboot messages:(RPM) auth failed! Thanks ! Reading information... Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_himawhl (bootloader) version: 1.0 (bootloader) imei: 99000xxxxxxxxxxx (bootloader) version-main: 3.41.651.4 (bootloader) boot-mode: download (bootloader) version-baseband: 3.00.C1144084@60114 (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 0PJA20000 (bootloader) cid: SPCS_001 all: finished. total time: 0.004s Reading CID information ... (bootloader) cid: SPCS_001 OKAY [ 0.976s] finished. total time: 0.976s Reading MEID information ... (bootloader) meid: 99000xxxxxxxxxxx OKAY [ 0.005s] finished. total time: 0.005s Reading IMEI1 information ... (bootloader) imei: 99000xxxxxxxxxxx OKAY [ 0.003s] finished. total time: 0.003s Reading IMEI2 information ... (bootloader) imei2: OKAY [ 0.004s] finished. total time: 0.004s Reading secure flag information ... (bootloader) Device security level S-OFF OKAY [ 0.007s] finished. total time: 0.007s Reading serial number information ... (bootloader) Device Serial No. is HT57xxxxxxxx OKAY [ 0.004s] finished. total time: 0.004s Read information completed. ------------------------------------------------------------- Starting flash process... target rom version: 3.41.651.4 found large-zip header, file count: 8 processing file 1/8... sending 'zip' (88850 KB)... OKAY [ 5.230s] writing 'zip'... (bootloader) HOSD CL#695981 (bootloader) GPT is up-to-dated. [17408] (bootloader) Perform pre-update (bootloader) start@21 (bootloader) splash1.nb0@BYPASS (bootloader) adsp.img@BYPASS (bootloader) rfg_1.img@BYPASS (bootloader) sensor_hub.img@BYPASS (bootloader) tp_MXM11876.img@BYPASS (bootloader) sdi.img@100% (bootloader) sbl1-8994-1.img@100% (bootloader) tp_SYN3351.img@BYPASS (bootloader) pmic-8994-1.img@100% (bootloader) cpe.img@BYPASS (bootloader) pg2fs_ship_signkey.img@BYPASS (bootloader) apppreload.img@BYPASS (bootloader) rpm-8994-1.img@100% (bootloader) tz-8994-1.img@100% (bootloader) hyp-8994-1.img@100% (bootloader) cota.img@BYPASS (bootloader) aboot_signed.img@100% (bootloader) hosd_signed.img@100% (bootloader) recovery_signed.img@BYPASS (bootloader) boot_signed.img@BYPASS (bootloader) radio.img@BYPASS Phone DISconnected FAILED (remote: 90 hboot pre-update! please flush image again immediately ) finished. total time: 7.830s preupdate done, rebooting... resending command... < waiting for device > sending 'zip' (88850 KB)... Phone connected [HT57xxxxxxxx] *** Fastboot mode OKAY [ 1.963s] writing 'zip'... FAILED (remote: Flash zip not support in BL, please go download mode) finished. total time: 1.988s HBoot pre-update sequence Flash process completed. Flash not successfull, reboot will not be done Phone DISconnected Phone connected [HT57xxxxxxxx] *** Fastboot mode ------------------------------------------------------------- Starting flash process... target rom version: 3.41.651.4 found large-zip header, file count: 8 processing file 1/8... sending 'zip' (88850 KB)... OKAY [ 5.251s] writing 'zip'... (bootloader) HOSD CL#695981 (bootloader) GPT is up-to-dated. [17408] (bootloader) Perform pre-update (bootloader) start@21 (bootloader) splash1.nb0@BYPASS (bootloader) adsp.img@BYPASS (bootloader) rfg_1.img@BYPASS (bootloader) sensor_hub.img@BYPASS (bootloader) tp_MXM11876.img@BYPASS (bootloader) sdi.img@100% (bootloader) sbl1-8994-1.img@100% (bootloader) tp_SYN3351.img@BYPASS (bootloader) pmic-8994-1.img@100% (bootloader) cpe.img@BYPASS (bootloader) pg2fs_ship_signkey.img@BYPASS (bootloader) apppreload.img@BYPASS (bootloader) rpm-8994-1.img@100% (bootloader) tz-8994-1.img@100% (bootloader) hyp-8994-1.img@100% (bootloader) cota.img@BYPASS (bootloader) aboot_signed.img@100% (bootloader) hosd_signed.img@100% (bootloader) recovery_signed.img@BYPASS (bootloader) boot_signed.img@BYPASS (bootloader) radio.img@BYPASS FAILED (remote: 90 hboot pre-update! please flush image again immediately ) finished. total time: 7.877s preupdate done, rebooting... Phone DISconnected resending command... < waiting for device > sending 'zip' (88850 KB)... Phone connected [HT57xxxxxxxx] *** Fastboot mode OKAY [ 5.257s] writing 'zip'... (bootloader) HOSD CL#695981 (bootloader) GPT is up-to-dated. [17408] (bootloader) Perform pre-update (bootloader) start@21 (bootloader) splash1.nb0@BYPASS (bootloader) adsp.img@BYPASS (bootloader) rfg_1.img@BYPASS (bootloader) sensor_hub.img@BYPASS (bootloader) tp_MXM11876.img@BYPASS (bootloader) sdi.img@100% (bootloader) sbl1-8994-1.img@100% (bootloader) tp_SYN3351.img@BYPASS (bootloader) pmic-8994-1.img@100% (bootloader) cpe.img@BYPASS (bootloader) pg2fs_ship_signkey.img@BYPASS (bootloader) apppreload.img@BYPASS (bootloader) rpm-8994-1.img@100% (bootloader) tz-8994-1.img@100% (bootloader) hyp-8994-1.img@100% (bootloader) cota.img@BYPASS (bootloader) aboot_signed.img@100% (bootloader) hosd_signed.img@100% (bootloader) recovery_signed.img@BYPASS (bootloader) boot_signed.img@BYPASS (bootloader) radio.img@BYPASS FAILED (remote: 90 hboot pre-update! please flush image again immediately ) finished. total time: 6.901s preupdate done, rebooting... Phone DISconnected resending command... < waiting for device > ------------------------------------------------------------ |
Hello, Can't understand, does it reboot to bootloader mode after first flash attempt? Please try to flash from SD (NOT from XTC 2 Clip please, it won't fit!). Rename flash file to 0PJAIMG.zip and put to SD card. |
from sd with :0PJAIMG_HIMA_WHL_N70_SENSE80_SPCS_MR_Sprint_WWE_4 .27.651.4_Radio_4.00.C1310411@70106_CNV_1.75_003_r elease_500478_signed_2_4.zip Renamed to 0PJAIMG.zip i got error : 12 RU_ZIP_ERROR 12 RU_ZIP_ERROR FAIL 12 RU_ZIP_ERROR -------------------------------------------------- from sd with :0PJAIMG_HIMA_WHL_M60_SENSE70_SPCS_MR_Sprint_WWE_3 .41.651.4_Radio_3.00.C1144084@60114_CNV_CNV_HIMA_S PCS_1.27_003_release_470409_signed_2_4.zip Renamed to 0PJAIMG.zip is rebooting to bootloader and stuck there ! |
One M9 Telstra WWE MR 1 3.10.84 v7.0 211 MB 4.30.841.1 i need this rom |
Using Fastboot mode... Reading common information (bootloader) kernel: lk (bootloader) product: htc_himauhl (bootloader) version: 1.0 (bootloader) serialno: FA536YJ13604 (bootloader) current-slot: (bootloader) imei: 358509062038581 (bootloader) version-main: 4.30.841.1 (bootloader) boot-mode: download (bootloader) version-baseband: 01.01_U114401011_117.00.61117G_2_F (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 0PJA10000 (bootloader) cid: TELST001 Poslano sa mog SM-G935F koristeći Tapatalk |
