04-03-2016, 00:02 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: uk
Member: 322130 Status: Offline Thanks Meter: 57 | htc one sv flash error Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 2.21.0000 (bootloader) version-baseband: 1.18.40a.00.05 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 3.11.61.10 (bootloader) version-misc: PVT SHIP S-OFF (bootloader) serialno: HT31JTP01920 (bootloader) imei: 352803050830422 (bootloader) meid: (bootloader) product: k2_ul (bootloader) platform: HBOOT-8930 (bootloader) modelid: PL8010000 (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 4015mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: dirty-2bb255c2 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 Execution time is 79(ms) all: Done! Reading secure flag information ... (bootloader) secure_flag: 0 Execution time is 14(ms) OKAY Reading CID information ... (bootloader) cid: 11111111 Execution time is 13(ms) OKAY Reading MEID information ... (bootloader) meid: 35280305083042 Execution time is 12(ms) OKAY Read information completed. Sending oem rebootRUU ... (bootloader) Start Verify: 0 (bootloader) SD: write failed in CMD25. Execution time is 1246(ms) OKAY Operation finished Phone Disconnected |
04-04-2016, 10:31 | #2 (permalink) | |
Banned Join Date: Nov 2012 Location: unknown
Member: 1837438 Status: Offline Sonork: unknown Thanks Meter: 659 | Quote:
br, habeeb kambrath | |
04-06-2016, 18:55 | #6 (permalink) |
Member: 322130 Status: Offline Thanks Meter: 57 | Sending oem rebootRUU ... (bootloader) Start Verify: 0 (bootloader) SD: write failed in CMD25. Execution time is 1246(ms) OKAY Operation finished Phone Disconnected |
04-07-2016, 13:12 | #10 (permalink) |
Member: 322130 Status: Offline Thanks Meter: 57 | Terminal For advanced users only. Please issue command without the exe name, e.g.: Fastboot mode: oem readimei oem readsecureflag Adb mode: shell getprop all The terminal is smart. It will autodetect the mode and use appropriate software. In other words if your phone is in ADB mode, you can use 'shell getprop' and in fastboot mode simply write 'getvar all' Enjoy *** Command started *** ... (bootloader) SD: write failed in CMD25. (bootloader) [PG_ERROR] htc_pg_part_update(982): (bootloader) sd_write_sector failed (bootloader) [PG_ERROR] htc_pg_part_traverse(930): (bootloader) fn return error (bootloader) Lock successfully... (bootloader) mipi_dsi_panel_off (bootloader) **** This command mode dma test is failed **** (bootloader) pm8038_vreg_disable function, vreg_id = 1 (bootloader) TZ_HTC_SVC_DISABLE ret = -131073 (0xFFFDFFFF) Execution time is 2281(ms) FAILED (status read failed (Too many links)) *** Command finished *** |
04-07-2016, 13:59 | #11 (permalink) | |
