Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > xtc2cliP
Old 07-03-2015, 16:19   #1 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 23,903
Htc one x counter blocked network cell tell
I have few phones which have counter blocked (phone show network lock )but when I try to enter code which I get from online site but phone make emergency call can I solved such problem with xtc clip ? Already order will get on Monday
Old 07-03-2015, 16:33   #2 (permalink)
Member: 2416253
Thanks Meter: 4,053
Yes, you should do regular unlock for this.
Please don't forget that One X has no sdcard slot, so you'd need an Y cable.
Old 07-06-2015, 13:01   #3 (permalink)
Member: 399832
are you share htc x pj46100 becoz i am trying but its not working
Old 07-06-2015, 15:22   #4 (permalink)
Member: 2416253
Thanks Meter: 4,053
What exactly is 'not working' ?
Old 07-07-2015, 07:48   #5 (permalink)
Member: 399832
here is some simple which i want to share with you
i am using this cable :Y-Cable dla HTC 8X, Titan, Radar, Mozart, Thropy, HD7, 7Pro
using SD Editor save the setting which i need into Drive
power off the phone connect the card reader using y cables which already share
connect phone with cable connect usb cable into computer and put phone in bootloader mod using keys
this is the right method ?
Old 07-07-2015, 10:33   #6 (permalink)
Member: 2416253
Thanks Meter: 4,053
Yes, absolutely. Does the phone see files when you go to simlock? What happens when you go to simlock?
Old 07-07-2015, 10:46   #7 (permalink)
Member: 399832
SD init faile !!!!
Old 07-07-2015, 11:14   #8 (permalink)
Member: 2416253
Thanks Meter: 4,053
SD init faile !!!!
In this case I think the cable is damaged.
You can also use any microsd card instead of the clip, if it still give you 'sd init failed' - change your cable.
Old 07-07-2015, 12:11   #9 (permalink)
Member: 399832
its new pack cable by gpg ? still have problem inside the cable ?
Old 07-07-2015, 12:26   #10 (permalink)
Member: 2416253
Thanks Meter: 4,053
You should contact the seller of your cable for support.
As I said - you can try the cable with any sd reader and sd card to make sure it's detected.
You can also contact Smart-Gsm he is supposed to have a stock of Y-cables produced by us.
By the way - you can try to change the microSD reader, sometime this may help also.
The Following 2 Users Say Thank You to xtc2clip For This Useful Post:
Old 07-07-2015, 13:15   #11 (permalink)
Member: 399832
ok done
super cid done
s-off done
network lock still show network lock
Old 07-07-2015, 13:17   #12 (permalink)
Member: 2416253
Thanks Meter: 4,053
ok done
super cid done
s-off done
Some models doesn't allow "direct" unlock.
Instead lock the phone (with lock flag set to 1), power on phone and enter unlock code (00000000) or other that you've choosen in software when creating config.dat
Old 07-07-2015, 13:35   #13 (permalink)
Member: 399832
here is some image want to share , i am unable to enter code check the images
Old 07-07-2015, 13:44   #14 (permalink)
Member: 2416253
Thanks Meter: 4,053
1. First, according to first image your phone wasn't relocked, as your flag was set to 0, not to 1. Please re-check.
2. If you pull the ring instead of the phone icon you should see an enter code menu.
Old 07-07-2015, 14:03   #15 (permalink)
Member: 399832
ok i add new pic check out its lock to 1
about 2nd option when i pull the ring instead of the phone icon its show emergency dialer as you can see in my up post
Page generated in 0.37596 seconds with 7 queries
