02-13-2018, 22:53 | #1 (permalink) |
Freak Poster Join Date: May 2015
Member: 2400457 Status: Offline Sonork: khurram7280072 Thanks Meter: 10 | help for htc 831c ##3434## and out spc code and diag on and use step 4 unlock. Trying to connect in Sprint mode... Trying to connect on COM10 Checking server connection... Communicating with the XTC 2 Clip ... Connecting to the server... Please wait, generating unlock hash... Process finished SUCCESSFULLY Please restart your phone for the changes to take effect Note: If your phone is M7 - please do S-OFF first and then unlock again In case of calls/network problems, please do reset by: Open phone dialer, type ##786#, wait for the menu to appear Press MENU in top right corner and select RESET Enter SPC code Wait for the phone to verify the code and reboot Reading information... Using Fastboot mode... Reading common information (bootloader) version: 0.5 (bootloader) version-bootloader: 3.16.0.0000 (bootloader) version-baseband: 1.05.20.0321_2 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 1.54.651.8 (bootloader) version-misc: PVT SHIP S-OFF (bootloader) serialno: FA44CSF07915 (bootloader) imei: 990004990681532 (bootloader) imei2: Not Support (bootloader) meid: 99000499068153 (bootloader) product: m8_whl (bootloader) platform: hTCBmsm8974 (bootloader) modelid: 0P6B70000 (bootloader) cidnum: 11111111 (bootloader) battery-status: good (bootloader) battery-voltage: 0mV (bootloader) partition-layout: Generic (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: ab0efa49 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! Execution time is 26(ms) Reading CID information ... (bootloader) cid: 11111111 OKAY Execution time is 26(ms) Reading MEID information ... (bootloader) meid: 99000499068153 OKAY Execution time is 22(ms) Reading IMEI1 information ... (bootloader) imei: 990004990681532 OKAY Execution time is 22(ms) Reading IMEI2 information ... (bootloader) readimei2: Not Support OKAY Execution time is 20(ms) Reading secure flag information ... (bootloader) secure_flag: 0 OKAY Execution time is 22(ms) Reading serial number information ... (bootloader) [ERR] Command error !!! OKAY i work on ever procedure.... but last procedure i used *#*#4636#*#* use phone information i select GSM/WCDMA/LTE/auto set restart no success for incoming signal..show limited service.. plz help me for unlock working for signal htc 831c sprint Android version 4.4.2 rooted. ???????????????????????????????? Last edited by khurrampk; 02-13-2018 at 23:00. |
