Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > xtc2cliP
Old 02-13-2018, 07:51   #1 (permalink)
Member: 17684
Sonork: 100.1612623
Thanks Meter: 33
Htc s-0ff problem
please help trying to s-off m8 and write cid 1111111 and this is result. Sending oem writesecureflag 0
... (bootloader) SecuritySDInit: counter = 2
(bootloader) m8_init_sd, SD card already power on
(bootloader) [SPEW] GPIO 0 status is 0
(bootloader) sdhci_open: id=0
(bootloader) Initializing MMC host data structure and clock!
(bootloader) mmc slot#2 clock enabled
(bootloader) sdhci_set_clock: slot 2, freq 192000000
(bootloader) GPLL0 is enabled
(bootloader) clock_update_cfg_sd is done
(bootloader) sd clock set done
(bootloader) sdhci_set_bus_width: bus width 0
(bootloader) sdhci_clk_supply: freq 400000
(bootloader) Error: Command never completed
(bootloader) Error: Command timeout error
(bootloader) Error: Command completed with errors
(bootloader) The response for CMD8 does not match the supplied value
(bootloader) Decoded CID fields:
(bootloader) Manufacturer ID: 7f
(bootloader) OEM ID: 0x0
(bootloader) Product Name: 5270
(bootloader) Product revision: 5.2
(bootloader) Product serial number: B4E
(bootloader) Manufacturing date: 2 2015
(bootloader) sdhci_clk_supply: freq 50000000
(bootloader) sdhci_set_bus_width: bus width 1
(bootloader) Done initialization of the card
(bootloader) erase_grpsize: -16777216
(bootloader) erase_grpmult: 261078040
(bootloader) wp_grpsize: 1
(bootloader) wp_grpen: 1
(bootloader) perm_wp: 0
(bootloader) temp_wp: 0
(bootloader) [Tuxera][Error] No exFAT partition found
(bootloader) [JAVACARD_ERR] get Decrease Renew Cycle fail, SW= 6986
(bootloader) writesecureflag: Permission denied, value 8
OKAY
Execution time is 4(s)
Operation finished
Old 02-13-2018, 07:55   #2 (permalink)
Member: 17684
Sonork: 100.1612623
Thanks Meter: 33
Write cid 1111111
also write cid result.Sending oem writecid 11111111
... (bootloader) SecuritySDInit: counter = 3
(bootloader) erase_grpmult: 261077976
(bootloader) Start Verify: 3
(bootloader) deinit_lcd
(bootloader) mipi display off
(bootloader) mdp_clock_off
(bootloader) disable_mmss_clk done
(bootloader) pll1_disable done
(bootloader) TZ_HTC_SVC_DISABLE ret = -1610744452 (0x9FFDFD7C)
(bootloader) [CRITICAL] SPMI write command failure: cmd_id = 0, error
(bootloader) = 4
(bootloader) = 4
(bootloader) [ERR] Cannot halt SPMI arbiter!!
(bootloader) [INFO] Rebooting device
Old 02-13-2018, 08:05   #3 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,073
did u connect clip to phones sd slot?
Old 02-13-2018, 08:06   #4 (permalink)
Member: 17684
Sonork: 100.1612623
Thanks Meter: 33
Info
reading info.Reading information...
Using Fastboot mode...
Reading common information
(bootloader) version: 0.5
(bootloader) version-bootloader: 3.19.0.0000
(bootloader) version-baseband: 1.29.214500021.12G
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main: 6.12.401.4
(bootloader) version-misc: PVT SHIP S-ON
(bootloader) serialno: SH43AWM04808
(bootloader) imei: 358714055637965
(bootloader) imei2: Not Support
(bootloader) meid: 00000000000000
(bootloader) product: m8_ul
(bootloader) platform: hTCBmsm8974
(bootloader) modelid: 0P6B10000
(bootloader) cidnum: HTC__J15
(bootloader) battery-status: good
(bootloader) battery-voltage: 0mV
(bootloader) partition-layout: Generic
(bootloader) security: on
(bootloader) build-mode: SHIP
(bootloader) boot-mode: FASTBOOT
(bootloader) commitno-bootloader: 76df2b54
(bootloader) hbootpreupdate: 11
(bootloader) gencheckpt: 0
all: Done!
Execution time is 31(ms)
Reading CID information
... (bootloader) cid: HTC__J15
OKAY
Execution time is 62(ms)
Reading MEID information
... (bootloader) meid: 00000000000000
OKAY
Reading IMEI1 information
... (bootloader) imei: 358714055637965
OKAY
Execution time is 46(ms)
Reading IMEI2 information
... (bootloader) readimei2: Not Support
OKAY
Reading secure flag information
... (bootloader) secure_flag: 3
OKAY
Reading serial number information
... (bootloader) [ERR] Command error !!!
OKAY
Read information completed.
Old 02-13-2018, 08:10   #5 (permalink)
Member: 17684
Sonork: 100.1612623
Thanks Meter: 33
yes
yes clip connected and detected in fastboot mode
Old 02-13-2018, 08:17   #6 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,073
try repair format clip and perform task again
Old 02-13-2018, 21:41   #7 (permalink)
Member: 738323
Sonork: 1618038
Thanks Meter: 37
unlock bootloader and rep......
Page generated in 0.25139 seconds with 7 queries
