02-28-2019, 09:51 | #1 (permalink) | |
No Life Poster Join Date: Feb 2011 Location: (BaNgLaDeSh).(U.A.E,AD)
Member: 1511441 Status: Offline Sonork: 100.1604057 Thanks Meter: 1,162 | HTC U ultar how remove demo mode os mode Quote:
02-28-2019, 20:23 | #5 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Try change cid if not sucessful than buy power adapter its not expensive but lot usefull for new htc phones Sent from my iPhone using Tapatalk |
The Following User Says Thank You to deepakgarg For This Useful Post: |
03-03-2019, 07:10 | #6 (permalink) | |
Member: 1511441 Status: Offline Sonork: 100.1604057 Thanks Meter: 1,162 | Quote:
1. Checking phone connectivity...... Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage.. Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writecid 11111111 ... FAILWRITE CID PERMISSION ERROR FAILED (remote: WRITE CID PERMISSION ERROR) finished. total time: 0.010s htc_fastboot finished Operation completed! Releasing adapter. Request completed | |
03-03-2019, 17:57 | #12 (permalink) |
Member: 1511441 Status: Offline Sonork: 100.1604057 Thanks Meter: 1,162 | xtc clip connect in sd slot sd not mount xtc clip connect with OTG also OTG not mount thet memes xtc2clip have problem how to solve |
03-04-2019, 07:57 | #15 (permalink) |
Member: 220603 Status: Offline Thanks Meter: 1,164 | use normal sd card and check if phone can read it ? sd not mounted problem can be solved by user only connect clip in powered off phone make sure usb hub is not used only direct pc usb for phone and power adapter both put phone in download mode and connect to pc |
