Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 02-28-2019, 09:51   #1 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
HTC U ultar how remove demo mode
fastboot mode have supper cid 1111 but os mode no
os mode
Reading information...
Using ADB mode...
CID list: [HTC__001,HTC__034,HTC__M27,HTC__002]
Main CID: [HTC__001]
Model ID (MID): [2PZF10000]
Project: [OCEAN_NOTE_UHL_N70_SENSE80GP]
System version: [1.64.401.3]
Chipset: [msm8996]
Memory: [4GB]
Hardware: [htc_oce]
Serial no: [FA7291701641]
Release: [htc/oceuhl_00401/htc_oceuhl:7.0/NRD90M/946680.3:user/release-keys]
Bluetooth chipset: [Broadcom BCM4359]
Buildline: [OceanNoteUHL_HTC_WWE_N70_CRC_Sense80GP_Stable]
Sense version: [8.0]
SKU: [HTC Europe]
Signed: [release-keys]
Android version: [7.0]
Android patch [2017-07-01]
Disk encryption: [encrypted]
Device: [htc_oceuhl]
Bootloader unlockable: [1]
Running as: shell
Read information completed.
Old 02-28-2019, 15:53   #2 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
no help....................................
Old 02-28-2019, 15:57   #3 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
did you try change cid with power adapter ?
Old 02-28-2019, 16:32   #4 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
no
i change cid using xtc2 clip
i don't have power adapter
Old 02-28-2019, 20:23   #5 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
Try change cid if not sucessful than buy power adapter its not expensive but lot usefull for new htc phones
Sent from my iPhone using Tapatalk
The Following User Says Thank You to deepakgarg For This Useful Post:
Old 03-03-2019, 07:10   #6 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
1. Checking phone connectivity......
Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage..
Phone connection confirmed!
HTC KEY CARD VERSION: 7
2. Checking Server connectivity...
Server connection confirmed!
3. Checking PowerAdapter connectivity...
Process started
PowerAdapter connected, processing request to adapter...
Starting operation...
Sending oem writecid 11111111
... FAILWRITE CID PERMISSION ERROR
FAILED (remote: WRITE CID PERMISSION ERROR)
finished. total time: 0.010s
htc_fastboot finished
Operation completed!
Releasing adapter.
Request completed
Old 03-03-2019, 09:04   #7 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
i'm waiting for help from term
Old 03-03-2019, 09:06   #8 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
Phone did not detect clip connected as u can see in log warning message
Old 03-03-2019, 14:05   #9 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
clip connect is ok but sd not mount
Old 03-03-2019, 14:07   #10 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
press reboot to bootloader than check if sd mounted or not
if not make clip repair than try
Old 03-03-2019, 14:32   #11 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
with computer clip connect ok
how to repair clip.................
Old 03-03-2019, 17:57   #12 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
xtc clip connect in sd slot sd not mount
xtc clip connect with OTG also OTG not mount
thet memes xtc2clip have problem how to solve
Old 03-03-2019, 18:17   #13 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
image2015.img
image2017.img
Win32DiskImager i did it but sd not mount
Old 03-04-2019, 06:47   #14 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
i waste time & money
Old 03-04-2019, 07:57   #15 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
use normal sd card and check if phone can read it ?
sd not mounted problem can be solved by user only
connect clip in powered off phone
make sure usb hub is not used only direct pc usb for phone and power adapter both
put phone in download mode and connect to pc
Page generated in 0.27296 seconds with 8 queries
