Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 03-04-2019, 08:20   #16 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
Originally Posted by deepakgarg View Post
use normal sd card and check if phone can read it ?
sd not mounted problem can be solved by user only
connect clip in powered off phone
make sure usb hub is not used only direct pc usb for phone and power adapter both
put phone in download mode and connect to pc
xtc clip have problem
i'm not use usb hub
phone sd & otg both mount in download mode only xtc clip not mount
Old 03-04-2019, 08:32   #17 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
try changing flex sometimes it helps too
Old 03-04-2019, 08:51   #18 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
bro my xtc clip have problem now i try to other htc 10 phone using 3flex sd not mount
xtc clip with computer is oky
Old 03-04-2019, 08:57   #19 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
new phone m10 is sd not mount
but old phone oky
Old 03-04-2019, 09:13   #20 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
for htc 10
http://forum.gsmhosting.com/vbb/f961...lease-2263404/
Old 03-04-2019, 09:40   #21 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
yes this is correct solution m10 is mount but m10 is just for check
plz need for htc U ulta
Old 03-04-2019, 09:57   #22 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
can i use m10 file for u ultra
now u ultra also mount sd
Old 03-04-2019, 10:07   #23 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
yes it should work now
try change cid
Old 03-04-2019, 10:23   #24 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
operation done download mode cid 11111 but os mode no
try change cid
1. Checking phone connectivity.......
Phone connection confirmed!
HTC KEY CARD VERSION: 7
2. Checking Server connectivity...
Server connection confirmed!
3. Checking PowerAdapter connectivity...
PowerAdapter connected, processing request to adapter...
Process started
Starting operation...
Sending oem writecid 11111111
Building connection
Initiating communication
Building connection
Data exchange sequence.
Request sent, waiting for reply ... 4 second(s)
Processing...
Data exchange completed
Data exchange sequence.....(bootloader) cid: 11111111
OKAY
finished. total time: 15.054s
htc_fastboot finished
Operation completed!
Releasing adapter.
Request completed
os mode cid still
Reading information...
Using ADB mode...
CID list: [HTC__001,HTC__034,HTC__M27,HTC__002]
Main CID: [HTC__001]
Model ID (MID): [2PZF10000]
Project: [OCEAN_NOTE_UHL_N70_SENSE80GP]
System version: [1.64.401.3]
Chipset: [msm8996]
Memory: [4GB]
Hardware: [htc_oce]
Serial no: [FA7291701641]
Release: [htc/oceuhl_00401/htc_oceuhl:7.0/NRD90M/946680.3:user/release-keys]
Bluetooth chipset: [Broadcom BCM4359]
Buildline: [OceanNoteUHL_HTC_WWE_N70_CRC_Sense80GP_Stable]
Sense version: [8.0]
SKU: [HTC Europe]
Signed: [release-keys]
Android version: [7.0]
Android patch [2017-07-01]
Disk encryption: [encrypted]
Device: [htc_oceuhl]
Bootloader unlockable: [1]
Running as: shell
Read information completed.
Old 03-04-2019, 13:46   #25 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
Originally Posted by riajul1988 View Post
i waste time & money
no more help
maybe it's truth
Old 03-06-2019, 06:45   #26 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
xtc2 team I'm still waiting if got solution please send me
Old 03-06-2019, 16:24   #27 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
most probably diag files created problem
need to confirm with product supporter exact model to be used from special unlock tab for clip detection in download mode
Old 03-07-2019, 15:40   #28 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello!
Sorry for late answer.
We haven't seen such cases yet, when main CID remains old in OS mode, we will investigate this, but, what are you trying to achieve?
CID is used only to limit firmware flashing, in your case CID in download mode is super-cid, CID in OS mode has no effect (sometimes it has effect on OTA firmware, but superCID doesn't give any privileges).
Did you try to do factory reset after changing CID to superCID ?
Old 03-08-2019, 13:08   #29 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,162
Originally Posted by xtc2clip View Post
Hello!
yes i do factory reset from download , from recovery mode & from os mode be-cos i want to remove demo mode
Old 03-29-2019, 18:46   #30 (permalink)
Member: 2494408
Thanks Meter: 110
easy .................................................. ......
Page generated in 0.79359 seconds with 8 queries
