HTC U ultar how remove demo mode fastboot mode have supper cid 1111 but os mode no os mode Quote:
no help.................................... |
did you try change cid with power adapter ? |
no i change cid using xtc2 clip i don't have power adapter |
Try change cid if not sucessful than buy power adapter its not expensive but lot usefull for new htc phones Sent from my iPhone using Tapatalk |
1. Checking phone connectivity...... Warning! Your phone does not see the XTC 2 Clip, please try to reconnect it, and then reboot to download/fastboot mode. In case of failure again, check your flex cable for damage.. Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection confirmed! 3. Checking PowerAdapter connectivity... Process started PowerAdapter connected, processing request to adapter... Starting operation... Sending oem writecid 11111111 ... FAILWRITE CID PERMISSION ERROR FAILED (remote: WRITE CID PERMISSION ERROR) finished. total time: 0.010s htc_fastboot finished Operation completed! Releasing adapter. Request completed |
i'm waiting for help from term |
Phone did not detect clip connected as u can see in log warning message Sent from my iPhone using Tapatalk |
clip connect is ok but sd not mount https://i.postimg.cc/Fs6v47gG/photo-...3-13-26-41.jpg |
press reboot to bootloader than check if sd mounted or not if not make clip repair than try |
how to repair clip................. |
xtc clip connect in sd slot sd not mount xtc clip connect with OTG also OTG not mount thet memes xtc2clip have problem how to solve |
https://i.postimg.cc/Px48s83x/screenshot.png image2015.img image2017.img Win32DiskImager i did it but sd not mount |
i waste time & money |
use normal sd card and check if phone can read it ? sd not mounted problem can be solved by user only connect clip in powered off phone make sure usb hub is not used only direct pc usb for phone and power adapter both put phone in download mode and connect to pc |
