And FRP remove via server failed. How fix it? |
2. You can use TrustedReboot and then do a factory reset. |
OK~I will try it. thx lot |
FACTORY_RESET NOT allow .... (GT_CONNECT_FAIL) https://ibb.co/iD5Noa |
Htc-u play,,,,twrp fail Starting flash process... target reported max download size of 1172000000 bytes sending 'recovery' (53572 KB)... OKAY [ 2.581s] writing 'recovery'... (bootloader) HOSD CL#867606 (bootloader) start@1 (bootloader) ERR partition_partial_update[ERR]: write failed. fd=17, n=- (bootloader) 1, No space left on device (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=2 (bootloader) 6214400 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=2 (bootloader) 7262976 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=2 (bootloader) 8311552 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=2 (bootloader) 9360128 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=3 (bootloader) 0408704 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=3 (bootloader) 1457280 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=3 (bootloader) 2505856 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=3 (bootloader) 3554432 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=3 (bootloader) 4603008 (bootloader) ERR partiti on_partial_update[ERR] lseek64 error!!, offset=3 (bootloader) 5651584 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=3 (bootloader) 6700160 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=3 (bootloader) 7748736 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=3 (bootloader) 8797312 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=3 (bootloader) 9845888 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=4 (bootloader) 0894464 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=4 (bootloader) 1943040 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=4 (bootloader) 2991616 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=4 (bootloader) 4040192 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=4 (bootloader) 5088768 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, off set=4 (bootloader) 6137344 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=4 (bootloader) 7185920 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=4 (bootloader) 8234496 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=4 (bootloader) 9283072 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=5 (bootloader) 0331648 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=5 (bootloader) 1380224 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=5 (bootloader) 2428800 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=5 (bootloader) 3477376 (bootloader) ERR partition_partial_update[ERR] lseek64 error!!, offset=5 (bootloader) 4525952 (bootloader) recovery@100% (bootloader) Update partition OK (bootloader) end@Done OKAY [ 2.541s] finished. total time: 5.122s Recovery flash process completed. Phone DISconnected |
HTC U Play S-OFF FAILED Is this model supported S-OFF? I only got success on U Ultra but U Play, already rooted by SuperSU 2.82. Checking for new version... Great, you are using latest version! Phone connected [HT6CG1600011] *** ADB mode Starting Ultra procedure Checking server connection... Communicating with the XTC 2 Clip ... Connecting to the server... Preparing enviroment... Communicating with phone... Starting operation Phone is in S-ON state Sorry, an error has occured, please report this code to support: ERROR:-1 |
After flashing twrp from HTC U Ultra (oce) in to HTC U Play phone freeze on entering in recovery and after 30 min it drop in to bootloop with vibro and MTK Preloader Port. Help please |
Exist firmware for FlashTool/MRT for unbrick from MTK Preloader Port? |
problem hello when i try trusted reboot: 1. Checking phone connectivity... Phone connection confirmed! HTC KEY CARD VERSION: 7 2. Checking Server connectivity... Server connection error #1. Please check firewall and/or internet connectivity! how to fix it? internet working ok xtc 2 tool too. |
hey guys.. after writing recoery file and goes to recovery it is BLACK SCREEN..anyone faced with this pb..? (bootloader) version-main: 1.62.401.1 twrp; twrp-3.1.0-0-oce twrp-3.1.1-0-oce twrp-3.2.1-0-oce |
no root required with power adapter |
good afternoon I have a little confluence when trying to do the s-off of a htc U play Starting Ultra procedure Checking server connection ... Communicating with the XTC 2 Clip ... Connecting to the server ... Preparing enviroment ... Communicating with phone ... Starting operation Phone is in S-ON state Sorry, an error has occured, please report this code to support: ERROR: -1 |
i have a set U ulta i do it soff but how get super cid camand not working fastboot oem writecid 11111111 |
