Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > xtc2cliP
Old 04-12-2018, 16:32   #1 (permalink)
Member: 887688
Sonork: talibans
Thanks Meter: 35
htc u11 frp [SOLVED]
htc u11 with frp
i have xtc2clip and power adapter
cannot remove frp
Security checking failed GT_CONNECT_FAIL
What is corect procedure to remove FRP?
what are they doing wrong?
please help me
Old 04-12-2018, 17:38   #2 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,073
connect phone according to power adapter procedure than press trusted reboot
once reboot completes make factory reset from phone screen
Old 04-12-2018, 18:39   #3 (permalink)
Member: 887688
Sonork: talibans
Thanks Meter: 35
what means: trusted reboot?
explain more please, i need help!
Old 04-12-2018, 18:44   #4 (permalink)
Member: 887688
Sonork: talibans
Thanks Meter: 35
1. Please wait, copying files, it may take up to 1 minute
Files were copied successfully. Please follow instructions to service your phone
(htc 10/ htc kddi (unlock))
2 . insert sd adapter from xtc2clip to phone
3. power phone with volume down, and navigate do download mode, confirm with power button
4 . phone ghive an error (Security checking failed GT_CONNECT_FAIL_)
this is corect procedure????
Old 04-12-2018, 19:34   #5 (permalink)
Member: 887688
Sonork: talibans
Thanks Meter: 35
ok , after read more 4 hours....
1. insert power adapter to xtc, copy necesary file,
2. power phone with vol - and poweer
3. i go in xtc2clip software-poWer adapter TAB- PRESS trusted reboot BUTTON
1. Checking phone connectivity...
Phone connection confirmed!
HTC KEY CARD VERSION: 7
2. Checking Server connectivity...
Server connection confirmed!
3. Checking PowerAdapter connectivity...
Process started
PowerAdapter connected, processing request to adapter...
Starting operation...
Sending oem reboot-download
... OKAY
Execution time is 5(ms)
Waiting for the phone to reboot...
Phone DISconnected
Building connection
Initiating communication
Building connection
Data exchange sequence.
Requesting information from server
Phone connected [FA76L1800667] *** Fastboot mode
Request sent, waiting 3 seconds for reply...
Phone connected
Waiting 3 seconds more...
Processing...
Data exchange completed
Building connection
Building connection
Processing...
Data exchange sequence....
Sending oem readimei
Building connection
Building connection
Processing...
Data exchange sequence.....
... (bootloader) imei: 356124080391335
OKAY
Execution time is 6(s)
Operation completed!
Releasing adapter.
Request completed
4. FACTORY REBOOT apear on lcd , navigate with vol - to factory reboot
and on lcd screen apear:
SD MOUNT
OTG NOT MOUNT
File NOT FOUND
FACTORY RESET...
FACTORY_RESET NOT ALLOW....(GT_CONNECT_FAIL)
and factory reset option dispear from MENU
not working ... but WHY?
wHAT IS WRONG?
Old 04-12-2018, 19:53   #6 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,073
Can u check with update client 1.4 if clip detected and update required or not ??
If all fine than repair clip as instructions given in help and faq thread
Sent from my iPhone using Tapatalk
Old 04-12-2018, 20:07   #7 (permalink)
Member: 2416253
Thanks Meter: 3,760
Hello,
You are doing everything fine, but factory reset option doesn't work in U11 at all (it's functionality is just removed from the code), so you need to use FRP tab to remove it.
Old 04-12-2018, 20:14   #8 (permalink)
Member: 887688
Sonork: talibans
Thanks Meter: 35
Thanks for replying
30 minutes ago I formatted xtc2clip, I wrote the image,I repair clip, I tried the same error
now I'm home, tomorrow I will try with client 1.4,and I will post the result
a good evening, thank you for your help
Old 04-12-2018, 20:38   #9 (permalink)
Member: 2416253
Thanks Meter: 3,760
Originally Posted by talibans View Post
Thanks for replying
The log you have posted is from "PowerAdapter" tab, you don't need it, use FRP tab please and report in case of any problems.
Old 04-13-2018, 06:34   #10 (permalink)
Member: 887688
Sonork: talibans
Thanks Meter: 35
ok I use "FRP " Tab
but I need xtc2clip with old card
or I need to use power adapter instead of the card ?
Old 04-13-2018, 07:58   #11 (permalink)
Member: 887688
Sonork: talibans
Thanks Meter: 35
Starting FRP unlock procedure
Phone detected, reading token...
Token detected successfully
Removing FRP ...
Error: The unlock token was not accepted by the phone. Try to re-calculate it again.
after one day i m not able to remove FRP
no any tutorial.....
phone conect in download mode?
phone need S-OFF?????
can somebody help me with litle tutorial?
thanks
PS.
i TRY RECALCULATE AGAIN !
Checking server connection...
Communicating with the XTC 2 Clip ...
Connecting to the server...
Waiting for the server to process request, it may take up to 5 minutes...
Waiting 10 second more...
Your request was processed successfully! Unlock token has been obtained
Removing FRP ...
Old 04-13-2018, 10:35   #12 (permalink)
Member: 887688
Sonork: talibans
Thanks Meter: 35
128 views, and and no answer
please ii need help , the customer has the phone in service for 2 days, and we did not solve anything
Old 04-13-2018, 18:41   #13 (permalink)
Member: 887688
Sonork: talibans
Thanks Meter: 35
frp NOT solved
xtc2clip please help me , i need to reset frp
Old 04-13-2018, 18:48   #14 (permalink)
Member: 2416253
Thanks Meter: 3,760
Sorry for late answer sir.
Please try now.
Old 04-13-2018, 19:03   #15 (permalink)
Member: 887688
Sonork: talibans
Thanks Meter: 35
frp not solved
ERROR: Clip communication error 10
ERROR: Cannot open smart_io.crd
Page generated in 0.40758 seconds with 7 queries
