Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > xtc2cliP
Old 10-17-2019, 10:34   #1 (permalink)
Member: 1692349
Sonork: d12
Thanks Meter: 2
htc u11 os needed urgently pls
please support i bricked my device i need os with cid CWS__001 please is urgent thnks s-off no supported already tried with power adapter,
Old 10-17-2019, 13:35   #2 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
1 u can change cid with power adapter without s-off
2 post info for flash file help
Old 10-17-2019, 15:29   #3 (permalink)
Member: 1692349
Sonork: d12
Thanks Meter: 2
i can't boot into recovery cos its bricked. oem not enabled so i can't unlock bootloader
here is the log
Using Fastboot mode...
Reading common information
(bootloader) kernel: lk
(bootloader) product: htc_ocnuhl
(bootloader) version: 1.0
(bootloader) max-download-size: 1560800000
(bootloader) serialno: FA75S1804869
(bootloader) slot-count: 0
(bootloader) current-slot:
(bootloader) imei: 356========
(bootloader) version-main: 2.33.401.10
(bootloader) boot-mode: download
(bootloader) version-baseband: 8998-002772-1711161638
(bootloader) version-bootloader: 1.0.0.0000
(bootloader) mid: 2PZC10000
(bootloader) cid: CWS__001
all:
finished. total time: 0.044s
htc_fastboot finished
Reading CID information
... (bootloader) cid: CWS__001
OKAY
finished. total time: 0.047s
Reading MEID information
... (bootloader) meid:
OKAY
finished. total time: 0.049s
Reading IMEI1 information
... (bootloader) imei: 35610=======
OKAY
finished. total time: 0.050s
Reading IMEI2 information
... (bootloader) imei2:
OKAY
finished. total time: 0.048s
Reading secure flag information
... (bootloader) Device security level S-ON, reboot count 0
OKAY
finished. total time: 0.083s
Reading serial number information
... (bootloader) Device Serial No. is FA75S1804869
OKAY
finished. total time: 0.042s
Reading color information
... (bootloader) COLOR ID: DEF00
OKAY
finished. total time: 0.060s
Read information completed.
Old 10-21-2019, 14:03   #4 (permalink)
Member: 2416253
Thanks Meter: 4,162
Hello,
We have this file on our support under no. 517952
Next time you can simply search by fw. version, which is 2.33.401.10 in your case.
Please refer to the support site for downloads.
Old 10-22-2019, 11:05   #5 (permalink)
Member: 1692349
Sonork: d12
Thanks Meter: 2
Originally Posted by xtc2clip View Post
Hello,
yes i saw this file
what i need is file with CID cws__001 thats what my device requires pls help if anyone can modify the RUU to include my CID i will e grateful
Old 10-22-2019, 11:07   #6 (permalink)
Member: 2324423
Sonork: 100.1669609
How To Remove Anti Theft Lock Itel a46 Model
Old 10-23-2019, 14:01   #7 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
Originally Posted by sunnycarlosmarx View Post
yes i saw this file
you can change cid via power adapter
Old 10-23-2019, 16:48   #8 (permalink)
Member: 2416253
Thanks Meter: 4,162
Or search for cws__001 on the support and download file for your CID.
Old 10-25-2019, 20:53   #9 (permalink)
Member: 1692349
Sonork: d12
Thanks Meter: 2
no file for htc u11 with cid cws__001
Old 10-25-2019, 20:56   #10 (permalink)
Member: 1692349
Sonork: d12
Thanks Meter: 2
in the process phone reboots then goes off. recovery is bricked, s-on, bootloader locked , oem not enabled
Old 10-27-2019, 16:00   #11 (permalink)
Member: 2416253
Thanks Meter: 4,162
I am not even sure this is the original CID, as there is no AT&T firmware for U11 UHL (Single sim), at least I don't see one.
What is the model ID written on the rear part of the phone? 2PZCxxxx? What is the value of xxxx on your phone?
Old 10-27-2019, 16:44   #12 (permalink)
Member: 1692349
Sonork: d12
Thanks Meter: 2
yes you are right i injected it to remove demo mode but forgot to write back stock recovery before i relocked the bootloader. now i cant access recovery i cant boot os mode to enable oem option i only have download and bootloader modes. if only i can get os with cid cws__001 the phone will come back to life. if theres anyway to modify ruu to inject this cid it will work....
http://forum.gsmhosting.com/vbb/f485...mid-s-2560826/
Old 10-27-2019, 17:01   #13 (permalink)
Member: 2416253
Thanks Meter: 4,162
There is no signed firmware with CWS CID and it cannot exist, because your current firmware is 2.xx.401.xx, which is Europe, not AT&T.
Your situation is hard, we need to think what we can do.
Old 10-27-2019, 18:24   #14 (permalink)
Member: 1692349
Sonork: d12
Thanks Meter: 2
thanks am waiting i have faith in u team
Old 11-02-2019, 08:07   #15 (permalink)
Member: 1692349
Sonork: d12
Thanks Meter: 2
still hopeful, i think this is possible
Page generated in 0.21013 seconds with 8 queries
